05-06-2008, 11:39 | #1 (permalink) |
Freak Poster Join Date: Jun 2002 Age: 53
Member: 13382 Status: Offline Thanks Meter: 9 | SE testpoint doesn’t work The K320, W200 test point doesn’t work, even though I have fixed the cable. I have also tried the k320, that reads well the info, but the test point doesn’t work here either. I made an attempt with my colleague’s box and my cable, but without luck; then his cable with my box, again without luck. His stuff works well with all kind of phones. Mine not; just with the Siemens part with Axx, Cxx, Mxx. please help Last edited by ocikem; 05-06-2008 at 11:48. |
05-06-2008, 12:53 | #3 (permalink) | |
No Life Poster Join Date: Aug 2006 Location: Turkey
Member: 337837 Status: Offline Thanks Meter: 538 | Quote:
CHECK YOUR TP CABLE MAYBE IT IS DEMAGE | |
05-06-2008, 13:42 | #5 (permalink) | |
Registered User Join Date: Dec 2007 Location: fazal Haroonabad Pakistan Age: 46
Member: 650213 Status: Offline Sonork: 100.1581739:333 Thanks Meter: 133 | Quote:
tespoint cable is ok but u r use fault brother . when w200 is connected then use access mode tespoint and go to security , Execute security by pass then show the pic testpoint connect to pin27 and with mouse click on show testpoint bottom start same as satge2 to testpoint on pin 37 U r br wait working same as simens br but in se click on start by mouse | |
05-06-2008, 16:23 | #6 (permalink) |
Member: 13382 Status: Offline Thanks Meter: 9 | |
The Following User Says Thank You to ocikem For This Useful Post: |
05-07-2008, 12:36 | #9 (permalink) | |
No Life Poster Join Date: Dec 2005
Member: 214480 Status: Offline Thanks Meter: 2,087 | Quote:
Can you send ALL *.log files from DBSS (Program Files->DreamBox)? | |
05-07-2008, 16:48 | #10 (permalink) | |
Member: 13382 Status: Offline Thanks Meter: 9 | Quote:
www.fprima.ro/File/dbsserr.log | |
05-07-2008, 16:54 | #11 (permalink) | ||
No Life Poster Join Date: Mar 2006 Location: dreambox
Member: 241271 Status: Offline Thanks Meter: 30 | Quote: Quote:
05-13-2008, 21:47 | #13 (permalink) |
Member: 13382 Status: Offline Thanks Meter: 9 | hy Dreambox suporter, today tested W200, cid52 log: www.fprima.ro/File/dbsserr_w220.log www.fprima.ro/File/dbss_w200.log tespoint 100% OK Last edited by ocikem; 05-13-2008 at 21:52. |
05-14-2008, 09:50 | #14 (permalink) | ||||
About K510. I see important 2 messages in your last logs: Quote:
Help d500 keypad works then doesn,t work ?? | moj | Samsung Hardware Repair | 2 | 06-30-2006 03:08 |
SE K750i Speaker doesn´t work. | chochol | Sony Ericsson Hardware Repair | 0 | 03-14-2006 01:47 |
Still reseting of hidden lifetimer doesn`t work for SE T200... | Bogi | Cruiser Suite | 2 | 06-01-2004 16:21 |
Pc Suite 4 doesn´t Work | Cosmar | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-29-2002 19:05 |
Logoprogram of NDS3.0 doesn´t work (connection error) | MyKe | Nokia Multimedia | 1 | 10-31-1999 21:23 |
