06-20-2008, 06:09 | #1 (permalink) |
No Life Poster Join Date: Aug 2006 Location: Philippines
Member: 329609 Status: Offline Thanks Meter: 245 | Siemens A57 "wrong software' here's read info via tp: Code: -- Reading Info--------------------------------------------------------------- User selected phone A57 using Test Point boot mode Power On the phone .. Warning : Aborted by user. --- Reading Info--------------------------------------------------------------- User selected phone A57 using Test Point boot mode Power On the phone ... OK Hint : Please connect the probe with a button to testpoint as shown in the description and wait. Hint : Now the probe might be disconnected Sending loader ... OK Loading application ...OK Testing RAM... OK Flash Chip = Micron MT28F640J3, size 8192 Kb Phone ID = 441E7DF8 Flash IMEI = 354246-00-149984-8 Manufacturer SIEMENS Model A57 Language lg1 Version 2 Phone IMEI = 354246-00-149984-8 SPLock CRC = FAILED Warning : setting default lock data Done. |
06-20-2008, 09:29 | #2 (permalink) |
No Life Poster Join Date: Dec 2005
Member: 214480 Status: Offline Thanks Meter: 2,087 | Hello! First of all try to do "Repair Security Data" with marked the "Use IMEI from flash OTP" checkbox. If this will not help you - try this solution: 1. Choose the required phone model from the scrolling list and select a correct access mode. (See “Access modes” description). 2. Select Map tab. 3. Click "Read All phone settings" button. 4. Select Flash tab. 5. Open fullflash file from boot-loader.com 6. Click "Write Selected Blocks" button. 7. Select Security tab. 8. To update or restore IMEI (International Mobile Equipment Identifier), mark the "Use IMEI from flash OTP" checkbox. 9. Click "Repair Security Data" button. 10. Write firmware with correct language pack NOTE: If checkbox "Do not update/repair security area" in "Option" is checked, all network locks will remain saved. Otherwise all locks will be unlocked. |
The Following User Says Thank You to GSM Dream For This Useful Post: |
Siemens CFX65 "wrong Battery" solution???? | ReyTech | NON Siemens Brand (ODM Phones) | 8 | 08-06-2013 13:26 |
A57 "wrong software" tried everything but still the same??? | ReyTech | SIEM Service Tools | 16 | 10-20-2005 17:10 |
siemens a57 unlock code | dashnor | E-Gold Based Phones | 1 | 11-27-2004 14:14 |
NEW Siemens A57, Nokia 3410 for sale | SPUnlock_SK | Sell ur Old and Used Stuff | 0 | 11-19-2004 18:42 |
Unlock Siemens A57 pls | unicos | E-Gold Based Phones | 3 | 10-02-2004 11:49 |
