06-03-2007, 21:42 | #1 (permalink) |
Registered User Join Date: Sep 2003 Location: Palestine Age: 50
Member: 39208 Status: Offline Thanks Meter: 152 | siemens m65 dead, unable to repair... i have a dead siemens m65 dead, i full flash it from support site, repair security data, unlock but still dead, when i press pwr key i hear a "tik" not a "Bzz" her is a log from dream BOX, PLS HELP ME -- Loading Flash File--------------------------------------------------------- User selected phone M65 using Test Point boot mode Loading "C:\Program Files\DreamBox\flashes\m65\M65_430300.fullflash.dt f"... Language : lg3 1. English (en-en) 2. Polish (pl) 3. Russian (ru) 4. Latvian (lv) 5. Lithuanian (lt) 6. Estonia (et) 7. Ukraine (uk) Done. --- Writing Flash-------------------------------------------------------------- User selected phone M65 using Test Point boot mode Warning : You should conect power to your phone Power On the phone ... OK Hint : Now the probe might be disconnected Sending loader ... OK Testing RAM ...OK Flash Chip = Intel 28F256L18T, size 32768 Kb Flash IMEI = 353667-00-228845-3 Phone ID = 06C9374A Bootcore = SIEMENS M65 Firmware = SIEMENS M65 v44 lg1 File name : C:\Program Files\DreamBox\flashes\m65\M65_430300.fullflash.dt f Writting speed is 64654 cps Phone IMEI = 353667-00-651463-1 Warning : Flash IMEI is not equal to Phone IMEI! Warning : Phone software could not work properly! Warning : Please, fix Phone IMEI! SPLock CRC = FAILED Warning : setting default lock data Setting IMEI = 353667-00-228845-3 Writting speed is 148 cps Done. then irepair security area --- Repareing------------------------------------------------------------------ User selected phone M65 using Test Point boot mode Power On the phone ... OK Hint : Now the probe might be disconnected Sending loader ... OK Testing RAM ...OK Flash Chip = Intel 28F256L18T, size 32768 Kb Flash IMEI = 353667-00-228845-3 Phone ID = 06C9374A Bootcore = SIEMENS M65 Firmware = SIEMENS M65 v43 lg3 Phone IMEI = 000000-00-000000-0 Warning : Flash IMEI is not equal to Phone IMEI! Warning : Phone software could not work properly! Warning : Please, fix Phone IMEI! SPLock CRC = OK Phone Code = < NOT SET > : FF Setting IMEI = 353667-00-228845-3 New SKey = 00000000 New Boot Key = EDA03717-4CEE25B0-ECF0F5AC-4C441F5B New Boot Hash = 1CCC33E1-8A067188-BC206CA9-7D894A6D Default Boot Mode = Normal Writting speed is 114 cps Done. then i unlock it Power On the phone ... OK Hint : Now the probe might be disconnected Sending loader ... OK Testing RAM ...OK Flash Chip = Intel 28F256L18T, size 32768 Kb Flash IMEI = 353667-00-228845-3 Phone ID = 06C9374A Bootcore = SIEMENS M65 Firmware = SIEMENS M65 v43 lg3 Phone IMEI = 353667-00-228845-3 SPLock CRC = OK Phone Code = < NOT SET > : FF Writting speed is 150 cps Done. i try different full flashes but the same |
The Following User Says Thank You to Byte For This Useful Post: |
06-04-2007, 04:48 | #2 (permalink) |
No Life Poster Join Date: May 2001 Location: Bulgaria Age: 56
Member: 4627 Status: Offline Sonork: 57528:debeliamark Thanks Meter: 1,034 | Format file system ... must work ... if still can't power on - then for sure you have HW fault. On M65 mostly users break bottom screw holders on board and phone PCB is not good protected and not lie of the root well... so probably CPU / Flash IC or RAM must be checked/resoldered before repeat SW repair. Last edited by debeliamark; 06-04-2007 at 05:04. |
The Following User Says Thank You to debeliamark For This Useful Post: |
06-04-2007, 12:15 | #3 (permalink) |
No Life Poster Join Date: Mar 2006 Location: dreambox
Member: 241271 Status: Offline Thanks Meter: 30 | Hello, Byte! Please, check phone battery. Probably it is empty. If battery is ok, try to format file system (A, B). |
The Following User Says Thank You to DreamSupporter For This Useful Post: |
is it legal to use imei from dead phone or which is unable to repair? | k babu | UCT (Universal China Tool) by ET | 4 | 12-02-2009 07:39 |
V3x Dead: Unable to repair...Need Suggestions | gesundheit | Smart-Clip | 4 | 07-04-2007 06:53 |
Unable to repair IMEI 099999-00-123456-0-09 on T290i? | byteforce | Cruiser Suite | 3 | 02-25-2006 11:51 |
Siemens M65 v50 - how to repair? | zahyr | S-Gold Based Phones | 2 | 01-26-2006 13:50 |
Please help... 6110 have 4 locks after nk_calc - unable to repair :-( | uu1dx | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 23 | 03-04-2002 23:52 |
