08-13-2008, 17:03 | #1 (permalink) |
No Life Poster Join Date: Mar 2008 Location: The Twilight Zone
Member: 736073 Status: Offline Thanks Meter: 81 | sl75 don't power on I have a siemens SL75 i tried to unlock and now the phone not power on I tried to flash a firmware from the support but still the same . please help me to revive it , i think i need a full flash but there isn't in the support . tanks --- Writing Flash-------------------------------------------------------------- User selected phone SL75 using Normal boot mode Power On the phone ... OK Testing RAM ...OK Flash Chip = AMD S29WS256N, size 32768 Kb Flash Chip = AMD S29GL512N, size 65536 Kb Flash IMEI = 359083-00-077485-4 Phone ID = B57EE3D6 Bootcore = SIEMENS SL75 Firmware = SIEMENS SL75 v10 lg3 File name : C:\_flashes\dreambox\sl75\sl75_399100.update.firmw are.dtf Writting speed is 83197 cps Warning : Repair IMEI after FullFlash is not checked Done. after the flash the phone make a "bip" when i press power button , and i tried to repair security data with "use imei from flash OTP" but give me an error --- Repareing------------------------------------------------------------------ User selected phone SL75 using Normal boot mode Power On the phone ... OK Testing RAM ...OK Flash Chip = AMD S29WS256N, size 32768 Kb Flash Chip = AMD S29GL512N, size 65536 Kb Flash IMEI = 359083-00-077485-4 Phone ID = B57EE3D6 Bootcore = SIEMENS SL75 Firmware = SIEMENS SL75 v39 lg91 Warning : EELITE is corrupted Phone IMEI = invalid IMEI SPLock FAILED Warning : setting default lock data Setting IMEI = 359083-00-077485-4 New SKey = 00000000 New Boot Key = D000BF68-F7127A79-6AF049B3-A8588A28 New Boot Hash = FFC24682-77B5F198-1CBC1108-8EA522CD Error : Failed. thank in advance |
08-14-2008, 11:11 | #4 (permalink) |
Freak Poster Join Date: May 2003 Location: Brazil Age: 67
Member: 27956 Status: Offline Thanks Meter: 11 | michel, after I update my dreambox v2.4 to v3.5 all SL75 AMD based donīt works with this box. Yours is: Flash Chip = AMD S29WS256N, size 32768 Kb Flash Chip = AMD S29GL512N, size 65536 Kb fullflash is 96Mb Even Intel based I did not revive on it. Flash Chip = Intel 28F256L18T, size 32768 Kb Flash Chip = Intel 28F256V18T, size 32768 Kb Flash Chip = Intel 28F256V18B, size 32768 Kb fullflash is 64Mb Better you see this http://forum.gsmhosting.com/vbb/show...255534&page=34 I had 5 x75 phones killed by this box and all are working now by this alternative solution. |
08-15-2008, 00:21 | #6 (permalink) |
No Life Poster Join Date: Jul 2005 Age: 37
Member: 164786 Status: Offline Thanks Meter: 56 | paulo_mineiro, i flashed without problems and intel sl75 and repaired security today, but i get troubles with amd sl75. i installed dbss in a new computer and used external power source at 4.2v and get logs and videos. i'm sending now to GSM Dream via PM. In latest version, I can't complete flash if "Repair Security..." and "Repair setup table" are enabled. Disabling, I can flash, but get "Write #06" when repairing security. We are waiting for the real solution for this problem. GSM Dream, please check your PM. |
08-15-2008, 02:18 | #7 (permalink) |
Member: 164786 Status: Offline Thanks Meter: 56 | i solved my problem... it's like paulo_mineiro ways, but I used DBSS to flash phone, not x65flasher...
Now my phone is working, but hanging on shutdown. Let's go back to 2007 to solve this problem: http://forum.gsmhosting.com/vbb/show...1&postcount=16 After this, no problem. But we are waiting for a real solution from Dream Box Team. |
The Following User Says Thank You to paullovinicius For This Useful Post: |
08-15-2008, 14:36 | #8 (permalink) |
Member: 736073 Status: Offline Thanks Meter: 81 | hi , thanks for the solution, but i have a problem , when i recalc the flash and ask me for the full flash bin , ichoose the dagos file, but appers in the papua a mensage "Not proper file C:\_flashes\dreambox\sl75\A0000000.bin! Required FullFlesh bin file!" , what can i do?? please helppp |
08-15-2008, 15:53 | #9 (permalink) | |
Member: 164786 Status: Offline Thanks Meter: 56 | Quote:
08-15-2008, 16:09 | #10 (permalink) |
Member: 736073 Status: Offline Thanks Meter: 81 | hi paullovinicius that problem i just resolved , but now im flashing with dbss and appears an error , i fallow your solution step by step but i don't now what is wrong. I use the papua just fine , and created the fullflash bin without problem please helpme thanks Power On the phone ... OK Warning : Bootcore allows boot in normal mode or is erased. Warning : Boot using Normal mode. Power On the phone ... OK Testing RAM ...OK Flash Chip = AMD S29WS256N, size 32768 Kb Flash Chip = AMD S29GL512N, size 65536 Kb Flash IMEI = 359083-00-077485-4 Phone ID = B57EE3D6 Bootcore = SIEMENS SL75 Firmware = SIEMENS SL75 v47 lg3 File name : C:\x65PapuaUtilsV079d\S65lg3.bin Warning : Repair Setup Table after FullFlash is not checked Address : 2000000 (80366 cps) Error : Write #06 Error : Failed. |
08-15-2008, 17:48 | #11 (permalink) |
Member: 736073 Status: Offline Thanks Meter: 81 | i flash your file to my phone , no problem , but still not power on , i think because the imei isn't the same . what can i do? Writing Flash-------------------------------------------------------------- User selected phone SL75 using Format Bootcore boot mode Power On the phone ... OK Warning : Bootcore allows boot in normal mode or is erased. Warning : Boot using Normal mode. Power On the phone ... OK Testing RAM ...OK Flash Chip = AMD S29WS256N, size 32768 Kb Flash Chip = AMD S29GL512N, size 65536 Kb Flash IMEI = 359083-00-077485-4 Phone ID = B57EE3D6 Bootcore = SIEMENS SL75 Firmware = SIEMENS SL75 v47 lg4 File name : C:\x65PapuaUtilsV079d\SL75_lg3_v10_357017001025488 _0814-2049-recalced.bin Warning : Repair Setup Table after FullFlash is not checked Writting speed is 119200 cps Warning : Repair IMEI after FullFlash is not checked Done. --- Reading Info--------------------------------------------------------------- User selected phone SL75 using Normal boot mode Power On the phone ... OK Testing RAM ...OK Flash Chip = AMD S29WS256N, size 32768 Kb Flash Chip = AMD S29GL512N, size 65536 Kb Flash IMEI = 359083-00-077485-4 Phone ID = B57EE3D6 Bootcore = SIEMENS SL75 Firmware = SIEMENS SL75 v47 lg3 File name : C:\x65PapuaUtilsV079d\S65lg3.bin Warning : Repair Setup Table after FullFlash is not checked Address : 2000000 (80366 cps) Error : Write #06 Error : Failed. thanks for your support and patience |
08-15-2008, 21:42 | #13 (permalink) | |
I forgot to say this... paulo_mineiro, i repeat: my phone is 100% now... the customer already get back it. | |
08-15-2008, 22:53 | #14 (permalink) | |
Member: 27956 Status: Offline Thanks Meter: 11 | Quote:
Even A52, A55, C75, CX75, etc my old dream box canīt find by TP(egold) and Auto/firmware bug(sgold). My solution is cut TP(a52,a55) and papuas(easer than open phone) | |
08-16-2008, 04:41 | #15 (permalink) | |
The second was AMD. Problem when flashing without automatic repair options was enable and when was doing "Repair Security". I flashed bootloader.com fullflash with that options disabled, after I readed and saved in BIN format, then recalc'd with papuasutils1.1b and flashed back using dbss 3.6.2. After, flashed with v35 firmware upgrade from bootloader.com(with automatic repair options disabled). And finish using WINSUP 4.18 to flash original XFS file. Bugs in DBSS with SL75 with AMD Flashes: -when flashing with options "Repair IMEI..." and "Repair setup table..." enabled. -when unlocking(get Error #06 then EEPROM will be corrupted) -when flashing only EEPROM area(same...) -when using "Calibrate Battery" Other bug: DBSS can't recognize original XFS files! You can try with this file: http://allsiemens.com/flash/xfs/SL75...35_xfs.zip.htm Again, no problems unlocking/flashing/repairing security in SL75 with Intel flash. No problems with A52 TP and Auto/Firmware Bug Access Mode here. | |
W302 sony ericsson don't power on, only red blinking on charger | Boshko_Alfa | Sony Ericsson | 10 | 12-01-2010 08:46 |
gx25 don't power on and don't charge | duvud67 | Sharp | 0 | 04-15-2006 09:15 |
C4 don't power on with 5V on PCB | GoGy | SagMaster Team OLD Products | 10 | 05-13-2005 08:57 |
n3330, don't power on, power switch ok | pali | Nokia Hardware & Hardware Repair | 6 | 07-28-2002 08:48 |
C35 don't power on ! 1st must connect charger after that ON ??? | Svetli | Siemens Hardware Repair Area | 2 | 04-14-2002 09:01 |
