08-01-2008, 06:29 | #1 (permalink) |
Freak Poster Join Date: Apr 2008
Member: 742276 Status: Offline Thanks Meter: 9 | Success repair GDFS K610 but still error? Code: --- Security Bypass------------------------------------------------------------ User selected phone K610 using Security Bypass boot mode 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) Sending Application ... NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 354638-01-295518-2 OTP CID = 51 EROM Color = 4 : RED EROM CID = 52 Baseband Chip ID = 9900 Phone ID = 23804E6915E02548 Flash Chip : Intel 48F50xxM0Y0 Flash Chip ID : 887E0089 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) Sending Application ... NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 354638-01-295518-2 OTP CID = 51 EROM Color = 4 : RED EROM CID = 52 Baseband Chip ID = 9900 Phone ID = 23804E6915E02548 Finalizing ... Done. --- Unlock and Repair---------------------------------------------------------- User selected phone K610 using Security Bypass boot mode 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) Sending Application ... NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 354638-01-295518-2 OTP CID = 51 EROM Color = 4 : RED EROM CID = 52 Baseband Chip ID = 9900 Phone ID = 23804E6915E02548 Reading GDFS... Testing security ... GDFS 0013 Hash Failed GDFS 0006 Hash Failed GDFS 000E Hash Failed GDFS 001C Hash Failed Unlocking ... Testing security ... GDFS 0013 Hash OK GDFS 0006 Hash OK GDFS 000E Hash OK GDFS 001C Hash OK Generating GDFS... Writing GDFS... Done. --- Reading Info--------------------------------------------------------------- User selected phone K610 using Normal boot mode 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 354638-01-295518-2 OTP CID = 51 EROM Color = 4 : RED EROM CID = 52 Starting CS Loader GDFS Service ... Error : Failed. --- Reading Info--------------------------------------------------------------- User selected phone K610 using Security Bypass boot mode 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) Sending Application ... NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 354638-01-295518-2 OTP CID = 51 EROM Color = 4 : RED EROM CID = 52 Baseband Chip ID = 9900 Phone ID = 23804E6915E02548 Flash Chip : Intel 48F50xxM0Y0 Flash Chip ID : 887E0089 Reading GDFS... Testing security ... GDFS 0013 Hash OK GDFS 0006 Hash OK GDFS 000E Hash OK GDFS 001C Hash OK Done. --- Reading Info--------------------------------------------------------------- User selected phone K610 using DCU60 boot mode 1) Turn OFF the phone. 2) Hold <C> button and connect the phone to DCU60 cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 354638-01-295518-2 OTP CID = 51 EROM Color = 4 : RED EROM CID = 52 Starting CS Loader GDFS Service ... Error : Failed. |
08-01-2008, 07:28 | #4 (permalink) |
Member: 742276 Status: Offline Thanks Meter: 9 | @jhepoy_org: I tried using SETOOL, gives same gdfs read error @SANGURAN_BOX: I tried writing with good gdfs from the stickied thread, and then unlock repair gdfs, result is still the same Now when i assemble phone and put battery, the phone is completely dead without red blink (before it came with red blink) |
08-07-2008, 08:46 | #6 (permalink) |
Insane Poster Join Date: Feb 2008 Location: malaysia
Member: 710424 Status: Offline Sonork: (msn)herozero8888@hotmail Thanks Meter: 0 | GSM DREAM GIve ME SOLUTION PLS>>>TWO TIME OSO STILL SAME PROBLEM.... Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) Sending Application ... NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 352826-01-958492-1 OTP CID = 51 EROM Color = 4 : RED EROM CID = 52 Baseband Chip ID = 9900 Phone ID = 23803A6215C001EA Flash Chip : Intel 48F50xxM0Y0 Flash Chip ID : 887E0089 Generating GDFS... Writing GDFS... Done. -- Unlock and Repair---------------------------------------------------------- User selected phone W850 using Security Bypass boot mode 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) Sending Application ... NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 352826-01-958492-1 OTP CID = 51 EROM Color = 4 : RED EROM CID = 52 Baseband Chip ID = 9900 Phone ID = 23803A6215C001EA Reading GDFS... Testing security ... Error : Failed. |
08-07-2008, 08:48 | #7 (permalink) | |
No Life Poster Join Date: Apr 2008 Location: TO SERVE AND PROTECT
Member: 739429 Status: Offline Sonork: FIND TO GOOGLES Thanks Meter: 85 | Quote:
08-07-2008, 08:52 | #8 (permalink) |
Freak Poster Join Date: Oct 2007 Location: Phillipines
Member: 614098 Status: Offline Thanks Meter: 192 | click........ EXCUTE SECURITY BYPASS OPERATION.........using TESTPOINT MODE....... then CLICK UNLOCK AND REPAIR GDFS SECURITY BLOCKS using SECURITY BYPASS mode....... |
08-07-2008, 09:34 | #9 (permalink) | |
Freak Poster Join Date: Mar 2006 Location: HP Mnla,Philippines Age: 38
Member: 247410 Status: Offline Thanks Meter: 161 | Quote:
What cable did you use?? Do not use Dcu60.... After repair gdfs In dream Box Flash with Setool.. Use Cable k750 Came from Setool box.. Check only Use Server and Complete phone after flash... | |
k800i gdfs wright but still whit light | saajith | DreamBox | 1 | 02-27-2010 15:06 |
HELP E63 after repair SD,Simlock but still power off when listenning music[SOLVED] | quanpham | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 20 | 02-09-2010 06:16 |
Successfully Repair GDFS DB2020 whit my modified cable | megdy | SETool2 | 8 | 09-23-2008 02:22 |
Another 2 pies successfully repaired gdfs | hackerbd | DreamBox | 2 | 05-06-2008 12:42 |
