04-28-2008, 12:02 | #1 (permalink) |
No Life Poster Join Date: Dec 2003 Location: poland Age: 44
Member: 46621 Status: Offline Thanks Meter: 34 | w200 unlock problem- phone death User selected phone W200 using Test Point boot mode Stage 1 started 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 8040030101010101 (DB2012 R3A) EROM Color = 4 : RED EROM CID = 52 NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 357355*********xx OTP CID = 51 EROM Color = 4 : RED EROM CID = 52 Hint : Now the probe might be disconnected Processing ... | Error : Loader failed to dump GDFS. Hint : Power on the phone and change settings/contacts/theme e.t.c. Hint : This will reorganize GDFS structure and possibly fix the error. Error : Failed. now i cant flash and cant unlock --- Security Bypass------------------------------------------------------------ User selected phone W200 using Test Point boot mode Stage 1 started 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 8040030101010101 (DB2012 R3A) and soft freez |
04-28-2008, 13:14 | #2 (permalink) |
Member: 46621 Status: Offline Thanks Meter: 34 | dont work v0.914023/UNI CARD SERIAL: ******xx Loaded 51 flash descriptors Abort all operations. phone pre-boot failed,possible RECOVERY needed. Elapsed:57 secs. llbug: port 6 open error: "Nie mozna odnalezc okreslonego pliku" phone pre-boot failed,possible RECOVERY needed. Elapsed:0 secs. Open COM port OK ChipID:8040,EMP protocol:0301 NEW SECURITY MODEL DETECTED PHONE IS BLACK (00000000) NO VALID FLASH CID DETECTED (103) skipping empty loader... phone pre-boot failed,possible RECOVERY needed. Elapsed:19 secs. whit usb and serial |
04-29-2008, 11:45 | #6 (permalink) | ||
No Life Poster Join Date: Dec 2005
Member: 214480 Status: Offline Thanks Meter: 2,087 | Our decision depends on the configuration GDFS. If it is wrong - that does not work. In this case, when our program try to GDFS data from the phone, it can't do that. Quote: Quote:
So, this shows the hardware problem. Maybe your problem is similar to this: Quote:
w200 unlock problem | EFOKORKU | MT-BOX | 4 | 10-16-2007 04:02 |
w200 unlock problem i think exe problem please lead look here | saily | Cruiser Suite | 22 | 08-15-2007 14:31 |
w200 unlock problem | saily | Cruiser Suite | 1 | 06-28-2007 16:14 |
Sonyericsson W200 unlock problem | mulenga | MT-BOX | 4 | 06-26-2007 19:55 |
