05-01-2010, 09:42 | #1 (permalink) |
No Life Poster Join Date: Aug 2002 Location: Island Garden City Of Samal,Ph
Member: 14852 Status: Offline Sonork: 100.1608716 Thanks Meter: 503 | W705a DEAD During Unlocking LOGS inside [HELP] User selected phone W705 using DCU60 boot mode 1) Turn OFF the phone. 2) Hold <2>+<5> buttons and connect the phone to DCU60 cable. Boot Responce = 7A Processor ID = E8000401FFFFFFFF (DB3210) Booting via ROM ... OTP IMEI = 351807-03-141520-4 EROM Color (BOOT) = 1 : BLUE EROM CID (BOOT) = 53 Starting File System & GDFS services ... Creating backup... Reading TA1 ... Reading TA2 ... Creating GDFS & TA backup W705_settings_backup_20100501-163610.dmap ... Booting via ROM ... OTP IMEI = 351807-03-141520-4 EROM Color (BOOT) = 1 : BLUE EROM CID (BOOT) = 53 NAND Flash ID: 00EC 00AA RND : 69B48A0635803F5E35008D22 Processing P96 authentication ... Device Key : FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF Restarting the phone... Booting via ROM ... OTP IMEI = 351807-03-141520-4 EROM Color (BOOT) = 1 : BLUE EROM CID (BOOT) = 53 RND : 190DB40E35803F5E35008D22 Processing P96 authentication ... Restarting the phone... Booting via ROM ... OTP IMEI = 351807-03-141520-4 EROM Color (BOOT) = 1 : BLUE EROM CID (BOOT) = 53 Writing SEMCBOOT... STOP @ 50% now the phone DEAD. HELP me team... |
05-01-2010, 11:16 | #2 (permalink) |
Junior Member Join Date: Jul 2009
Member: 1071819 Status: Offline Thanks Meter: 6 | Flashing can stop if battery is empty. I don't see problems with dreambox. You had to check battery and try again. BTW, from your log I see that phone was BLUE and had "destroyed device key" even before you connected it to dreambox. |
The Following User Says Thank You to [ASD] For This Useful Post: |
05-01-2010, 12:34 | #3 (permalink) |
Member: 14852 Status: Offline Sonork: 100.1608716 Thanks Meter: 503 | THE fully CHARGE ... i try other model no problem but this model i got a problem... destroyed device key FFFFFFFFFFFFFFFF due stop writing EROM by DREAMbox STOP @ 50%... THAT it... hope dreambox this problem.. |
05-01-2010, 22:39 | #5 (permalink) |
Member: 14852 Status: Offline Sonork: 100.1608716 Thanks Meter: 503 | yup i wait 1hr & 15mins so i decide to disconnect the phone STOP @ 50% no respone and HANG nothing happen... no error code show. i try some other phone during Writing SEMCBOOT take only i try the operation twice but no success.. HOPE you can fix this team... thanks for the reply. |
05-05-2010, 03:26 | #9 (permalink) |
Member: 14852 Status: Offline Sonork: 100.1608716 Thanks Meter: 503 | it's not discharged team ... the battery is FUllY charge maybe software fault i try a lot of phone unlocked on DREAMBOX UNLOCKING NO SWEAT very fast easy... only problem on this phone W705a... |
05-05-2010, 15:29 | #10 (permalink) |
No Life Poster Join Date: Dec 2005
Member: 214480 Status: Offline Thanks Meter: 2,087 | Dbss should log errors when you disconnect phone that was connected via DCU60 during the job. Please, run job. Wait when it freeze on 50%. Then disconnect phone, and send dbss log to me. |
05-06-2010, 03:21 | #12 (permalink) | ||
Member: 14852 Status: Offline Sonork: 100.1608716 Thanks Meter: 503 | Quote:
Code: [01/05/2010 15:34:04] DBSS Start 3.25 [01/05/2010 15:34:19] --- Unlock and Repair---------------------------------------------------------- [01/05/2010 15:34:22] User selected phone W705 using DCU60 boot mode [01/05/2010 15:34:22] 1) Turn OFF the phone. [01/05/2010 15:34:22] 2) Hold <2>+<5> buttons and connect the phone to DCU60 cable. [01/05/2010 15:35:04] Boot Responce = 7A [01/05/2010 15:35:04] Processor ID = E8000401FFFFFFFF (DB3210) [01/05/2010 15:35:04] Booting via SEMCBOOT ... [01/05/2010 15:35:04] OTP IMEI = 351807-03-141520-4 [01/05/2010 15:35:04] EROM Color (BOOT) = 4 : RED [01/05/2010 15:35:04] EROM CID (BOOT) = 53 [01/05/2010 15:35:04] Error : Invalid boot method. Plese boot holding <2>+<5> [01/05/2010 15:35:04] Error : #3190:003C0432 [01/05/2010 15:35:04] Error : Failed. [01/05/2010 15:35:04] [01/05/2010 15:35:10] --- Unlock and Repair---------------------------------------------------------- [01/05/2010 15:35:10] User selected phone W705 using DCU60 boot mode [01/05/2010 15:35:10] 1) Turn OFF the phone. [01/05/2010 15:35:10] 2) Hold <2>+<5> buttons and connect the phone to DCU60 cable. [01/05/2010 15:35:20] Boot Responce = 7A [01/05/2010 15:35:21] Processor ID = E8000401FFFFFFFF (DB3210) [01/05/2010 15:35:21] Booting via ROM ... [01/05/2010 15:35:21] OTP IMEI = 351807-03-141520-4 [01/05/2010 15:35:21] EROM Color (BOOT) = 4 : RED [01/05/2010 15:35:21] EROM CID (BOOT) = 53 [01/05/2010 15:35:28] Starting File System & GDFS services ... [01/05/2010 15:35:28] Creating backup... [01/05/2010 15:35:44] Reading TA1 ... [01/05/2010 15:35:44] Reading TA2 ... [01/05/2010 15:35:45] Creating GDFS & TA backup W705_settings_backup_20100501-153545.dmap ... [01/05/2010 15:35:49] Booting via ROM ... [01/05/2010 15:35:49] OTP IMEI = 351807-03-141520-4 [01/05/2010 15:35:50] EROM Color (BOOT) = 4 : RED [01/05/2010 15:35:50] EROM CID (BOOT) = 53 [01/05/2010 15:35:52] NAND Flash ID: 00EC 00AA [01/05/2010 15:35:54] RND : A32856D535803F5E35008D22 [01/05/2010 15:35:54] Processing P96 authentication ... [01/05/2010 15:36:06] Device Key : 68DDD933029C4FCF35454D22DE9E11E7 [01/05/2010 15:36:06] Restarting the phone... [01/05/2010 15:36:08] Booting via ROM ... [01/05/2010 15:36:09] OTP IMEI = 351807-03-141520-4 [01/05/2010 15:36:09] EROM Color (BOOT) = 4 : RED [01/05/2010 15:36:09] EROM CID (BOOT) = 53 [01/05/2010 15:36:13] RND : AB651D8335803F5E35008D22 [01/05/2010 15:36:13] Processing P96 authentication ... [01/05/2010 15:36:26] Restarting the phone... [01/05/2010 15:36:28] Booting via ROM ... [01/05/2010 15:36:29] OTP IMEI = 351807-03-141520-4 [01/05/2010 15:36:29] EROM Color (BOOT) = 1 : BLUE [01/05/2010 15:36:29] EROM CID (BOOT) = 53 [01/05/2010 15:36:32] Writing SEMCBOOT... [01/05/2010 15:38:19] Error : #3190:000402A8 [01/05/2010 15:38:19] Error : #3190:00380401 [01/05/2010 15:38:19] Error : #3190:00380385 [01/05/2010 15:38:19] Error : #3190:003A02C3 [01/05/2010 15:38:19] Error : #3190:003A05C4 [01/05/2010 15:38:19] Error : #3190:003C05EE [01/05/2010 15:38:19] Error : #3190:003C045F [01/05/2010 15:38:19] Error : Failed. [01/05/2010 15:38:19] [01/05/2010 15:38:38] --- Unlock and Repair---------------------------------------------------------- [01/05/2010 15:38:38] User selected phone W705 using DCU60 boot mode [01/05/2010 15:38:39] 1) Turn OFF the phone. [01/05/2010 15:38:39] 2) Hold <2>+<5> buttons and connect the phone to DCU60 cable. [01/05/2010 15:38:45] Boot Responce = 7A [01/05/2010 15:38:45] Processor ID = E8000401FFFFFFFF (DB3210) [01/05/2010 15:38:45] Booting via ROM ... [01/05/2010 15:38:45] OTP IMEI = 351807-03-141520-4 [01/05/2010 15:38:45] EROM Color (BOOT) = 1 : BLUE [01/05/2010 15:38:45] EROM CID (BOOT) = 53 [01/05/2010 15:38:56] Starting File System & GDFS services ... [01/05/2010 15:38:56] Creating backup... [01/05/2010 15:39:10] Reading TA1 ... [01/05/2010 15:39:11] Reading TA2 ... [01/05/2010 15:39:11] Creating GDFS & TA backup W705_settings_backup_20100501-153911.dmap ... [01/05/2010 15:39:16] Booting via ROM ... [01/05/2010 15:39:17] OTP IMEI = 351807-03-141520-4 [01/05/2010 15:39:17] EROM Color (BOOT) = 1 : BLUE [01/05/2010 15:39:17] EROM CID (BOOT) = 53 [01/05/2010 15:39:19] NAND Flash ID: 00EC 00AA [01/05/2010 15:39:20] RND : 268D4F0335803F5E35008D22 [01/05/2010 15:39:20] Processing P96 authentication ... [01/05/2010 15:39:32] Device Key : FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF [01/05/2010 15:39:32] Restarting the phone... [01/05/2010 15:39:35] Booting via ROM ... [01/05/2010 15:39:36] OTP IMEI = 351807-03-141520-4 [01/05/2010 15:39:36] EROM Color (BOOT) = 1 : BLUE [01/05/2010 15:39:36] EROM CID (BOOT) = 53 [01/05/2010 15:39:39] RND : FB10488535803F5E35008D22 [01/05/2010 15:39:39] Processing P96 authentication ... [01/05/2010 15:39:52] Restarting the phone... [01/05/2010 15:39:56] Booting via ROM ... [01/05/2010 15:39:57] OTP IMEI = 351807-03-141520-4 [01/05/2010 15:39:57] EROM Color (BOOT) = 1 : BLUE [01/05/2010 15:39:57] EROM CID (BOOT) = 53 [01/05/2010 15:40:00] Writing SEMCBOOT... [01/05/2010 15:40:42] Error : #3190:000402A0 [01/05/2010 15:45:15] [01/05/2010 15:45:15] DBSS Start 3.25 [01/05/2010 15:45:29] --- Unlock and Repair---------------------------------------------------------- [01/05/2010 15:45:31] User selected phone W705 using DCU60 boot mode [01/05/2010 15:45:32] 1) Turn OFF the phone. [01/05/2010 15:45:32] 2) Hold <2>+<5> buttons and connect the phone to DCU60 cable. [01/05/2010 15:45:35] Boot Responce = 7A [01/05/2010 15:45:35] Processor ID = E8000401FFFFFFFF (DB3210) [01/05/2010 15:45:35] Booting via ROM ... [01/05/2010 15:45:35] OTP IMEI = 351807-03-141520-4 [01/05/2010 15:45:35] EROM Color (BOOT) = 1 : BLUE [01/05/2010 15:45:35] EROM CID (BOOT) = 53 [01/05/2010 15:45:45] Starting File System & GDFS services ... [01/05/2010 15:45:45] Creating backup... [01/05/2010 15:46:00] Reading TA1 ... [01/05/2010 15:46:01] Reading TA2 ... [01/05/2010 15:46:01] Creating GDFS & TA backup W705_settings_backup_20100501-154601.dmap ... [01/05/2010 15:46:06] Error : #3190:000402A8 [01/05/2010 15:46:06] Error : #3190:00380196 [01/05/2010 15:46:06] Error : #3190:003800FA [01/05/2010 15:46:06] Error : #3190:003C0C2F [01/05/2010 15:46:06] Error : #3190:003C0454 [01/05/2010 15:46:06] Error : Failed. [01/05/2010 15:46:06] [01/05/2010 15:46:20] --- Unlock and Repair---------------------------------------------------------- [01/05/2010 15:46:20] User selected phone W705 using DCU60 boot mode [01/05/2010 15:46:21] 1) Turn OFF the phone. [01/05/2010 15:46:21] 2) Hold <2>+<5> buttons and connect the phone to DCU60 cable. [01/05/2010 15:48:17] Boot Responce = 7A [01/05/2010 15:48:18] Processor ID = E8000401FFFFFFFF (DB3210) [01/05/2010 15:48:19] Booting via ROM ... [01/05/2010 15:48:19] OTP IMEI = 351807-03-141520-4 [01/05/2010 15:48:24] [01/05/2010 15:48:24] DBSS Start 3.25 [01/05/2010 15:48:46] --- Unlock and Repair---------------------------------------------------------- [01/05/2010 15:48:46] User selected phone W705 using DCU60 boot mode [01/05/2010 15:48:47] 1) Turn OFF the phone. [01/05/2010 15:48:47] 2) Hold <2>+<5> buttons and connect the phone to DCU60 cable. [01/05/2010 15:49:04] Boot Responce = 7A [01/05/2010 15:49:05] Processor ID = E8000401FFFFFFFF (DB3210) [01/05/2010 15:49:05] Booting via ROM ... [01/05/2010 15:49:05] OTP IMEI = 351807-03-141520-4 [01/05/2010 15:49:05] EROM Color (BOOT) = 1 : BLUE [01/05/2010 15:49:05] EROM CID (BOOT) = 53 [01/05/2010 15:49:15] Starting File System & GDFS services ... [01/05/2010 15:49:15] Creating backup... [01/05/2010 15:49:30] Reading TA1 ... [01/05/2010 15:49:31] Reading TA2 ... [01/05/2010 15:49:31] Creating GDFS & TA backup W705_settings_backup_20100501-154931.dmap ... [01/05/2010 15:49:38] Booting via ROM ... [01/05/2010 15:49:39] OTP IMEI = 351807-03-141520-4 [01/05/2010 15:49:39] EROM Color (BOOT) = 1 : BLUE [01/05/2010 15:49:39] EROM CID (BOOT) = 53 [01/05/2010 15:49:42] NAND Flash ID: 00EC 00AA [01/05/2010 15:49:44] RND : 67B7C96535803F5E35008D22 [01/05/2010 15:49:44] Processing P96 authentication ... [01/05/2010 15:49:58] Device Key : FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF [01/05/2010 15:49:58] Restarting the phone... [01/05/2010 15:50:01] Booting via ROM ... [01/05/2010 15:50:01] OTP IMEI = 351807-03-141520-4 [01/05/2010 15:50:01] EROM Color (BOOT) = 1 : BLUE [01/05/2010 15:50:01] EROM CID (BOOT) = 53 [01/05/2010 15:50:05] RND : 7FBFCFAA35803F5E35008D22 [01/05/2010 15:50:05] Processing P96 authentication ... [01/05/2010 15:50:20] Restarting the phone... [01/05/2010 15:50:23] Booting via ROM ... [01/05/2010 15:50:24] OTP IMEI = 351807-03-141520-4 [01/05/2010 15:50:24] EROM Color (BOOT) = 1 : BLUE [01/05/2010 15:50:24] EROM CID (BOOT) = 53 [01/05/2010 15:50:28] Writing SEMCBOOT... [01/05/2010 15:52:49] Error : #3190:000402A0 [01/05/2010 15:52:49] Error : #3190:00380401 [01/05/2010 15:52:50] Error : #3190:00380385 [01/05/2010 15:52:50] Error : #3190:003A02C3 [01/05/2010 15:52:50] Error : #3190:003A05C4 [01/05/2010 15:52:50] Error : #3190:003C05EE [01/05/2010 15:52:50] Error : #3190:003C045F [01/05/2010 15:52:50] Warning : Aborted by user. [01/05/2010 15:52:50] [01/05/2010 15:52:57] --- Loading Phone Settings file------------------------------------------------ [01/05/2010 15:53:05] Loading "C:\Program Files\DreamBox\User Data\W705_settings_backup_20100501-153545.dmap"... [01/05/2010 15:53:05] Done. [01/05/2010 15:53:05] [01/05/2010 15:53:09] --- Write Phone Settings------------------------------------------------------- [01/05/2010 15:53:09] User selected phone W705 using DCU60 boot mode [01/05/2010 15:53:09] 1) Turn OFF the phone. [01/05/2010 15:53:09] 2) Hold <2>+<5> buttons and connect the phone to DCU60 cable. [01/05/2010 15:53:18] Boot Responce = 7A [01/05/2010 15:53:18] Processor ID = E8000401FFFFFFFF (DB3210) [01/05/2010 15:53:18] Booting via ROM ... [01/05/2010 15:53:18] OTP IMEI = 351807-03-141520-4 [01/05/2010 15:53:18] EROM Color (BOOT) = 1 : BLUE [01/05/2010 15:53:18] EROM CID (BOOT) = 53 [01/05/2010 15:53:28] Creating backup... [01/05/2010 15:53:43] Reading TA1 ... [01/05/2010 15:53:44] Reading TA2 ... [01/05/2010 15:53:44] Creating GDFS & TA backup W705_settings_backup_20100501-155344.dmap ... [01/05/2010 15:55:22] Writing GDFS ... [01/05/2010 15:55:22] Writing TA ... [01/05/2010 15:55:45] Writing TA1 ... [01/05/2010 15:55:49] Writing TA2 ... [01/05/2010 15:55:49] Done. [01/05/2010 15:55:49] [01/05/2010 15:56:23] --- Unlock and Repair---------------------------------------------------------- [01/05/2010 15:56:23] User selected phone W705 using DCU60 boot mode [01/05/2010 15:56:23] 1) Turn OFF the phone. [01/05/2010 15:56:23] 2) Hold <2>+<5> buttons and connect the phone to DCU60 cable. [01/05/2010 15:56:31] Boot Responce = 7A [01/05/2010 15:56:31] Processor ID = E8000401FFFFFFFF (DB3210) [01/05/2010 15:56:31] Booting via ROM ... [01/05/2010 15:56:31] OTP IMEI = 351807-03-141520-4 [01/05/2010 15:56:31] EROM Color (BOOT) = 1 : BLUE [01/05/2010 15:56:31] EROM CID (BOOT) = 53 [01/05/2010 15:56:42] Starting File System & GDFS services ... [01/05/2010 15:56:42] Creating backup... [01/05/2010 15:56:59] Reading TA1 ... [01/05/2010 15:56:59] Reading TA2 ... [01/05/2010 15:57:00] Creating GDFS & TA backup W705_settings_backup_20100501-155700.dmap ... [01/05/2010 15:57:05] Booting via ROM ... [01/05/2010 15:57:06] OTP IMEI = 351807-03-141520-4 [01/05/2010 15:57:06] EROM Color (BOOT) = 1 : BLUE [01/05/2010 15:57:06] EROM CID (BOOT) = 53 [01/05/2010 15:57:10] NAND Flash ID: 00EC 00AA [01/05/2010 15:57:13] RND : 67E772ED35803F5E35008D22 [01/05/2010 15:57:13] Processing P96 authentication ... [01/05/2010 15:57:27] Error : status == 0x03EA [01/05/2010 15:57:27] Error : #3190:00380363 [01/05/2010 15:57:27] Error : #3190:003A0467 [01/05/2010 15:57:27] Error : #3190:003C0CBE 35180703141520KIDP96_EMP_DUMP_R1A [01/05/2010 15:57:27] Error : #3190:003C0568 [01/05/2010 15:57:27] Error : #3190:003C045F [01/05/2010 15:57:27] Error : Failed. [01/05/2010 15:57:27] [01/05/2010 15:57:35] --- Unlock and Repair---------------------------------------------------------- [01/05/2010 15:57:35] User selected phone W705 using DCU60 boot mode [01/05/2010 15:57:36] 1) Turn OFF the phone. [01/05/2010 15:57:36] 2) Hold <2>+<5> buttons and connect the phone to DCU60 cable. [01/05/2010 15:57:42] Boot Responce = 7A [01/05/2010 15:57:44] Processor ID = E8000401FFFFFFFF (DB3210) [01/05/2010 15:57:44] Booting via ROM ... [01/05/2010 15:57:44] OTP IMEI = 351807-03-141520-4 [01/05/2010 15:57:45] EROM Color (BOOT) = 1 : BLUE [01/05/2010 15:57:45] EROM CID (BOOT) = 53 [01/05/2010 15:57:45] Error : #3190:000402A0 [01/05/2010 15:57:45] Error : #3190:003800BB [01/05/2010 15:57:45] Error : #3190:00380249 [01/05/2010 15:57:45] Error : #3190:003C02DC [01/05/2010 15:57:45] Error : #3190:003C0435 [01/05/2010 15:57:45] Warning : Aborted by user. [01/05/2010 15:57:45] [01/05/2010 15:57:49] --- Unlock and Repair---------------------------------------------------------- [01/05/2010 15:57:49] User selected phone W705 using DCU60 boot mode [01/05/2010 15:57:50] 1) Turn OFF the phone. [01/05/2010 15:57:50] 2) Hold <2>+<5> buttons and connect the phone to DCU60 cable. [01/05/2010 15:58:13] Boot Responce = 7A [01/05/2010 15:58:13] Processor ID = E8000401FFFFFFFF (DB3210) [01/05/2010 15:58:14] Booting via ROM ... [01/05/2010 15:58:14] OTP IMEI = 351807-03-141520-4 [01/05/2010 15:58:14] EROM Color (BOOT) = 1 : BLUE [01/05/2010 15:58:14] EROM CID (BOOT) = 53 [01/05/2010 15:58:26] Starting File System & GDFS services ... [01/05/2010 15:58:26] Creating backup... [01/05/2010 15:58:42] Reading TA1 ... [01/05/2010 15:58:42] Reading TA2 ... [01/05/2010 15:58:43] Creating GDFS & TA backup W705_settings_backup_20100501-155843.dmap ... [01/05/2010 15:58:51] Booting via ROM ... [01/05/2010 15:58:52] OTP IMEI = 351807-03-141520-4 [01/05/2010 15:58:52] EROM Color (BOOT) = 1 : BLUE [01/05/2010 15:58:52] EROM CID (BOOT) = 53 [01/05/2010 15:58:55] NAND Flash ID: 00EC 00AA [01/05/2010 15:58:57] RND : A2FFA11E35803F5E35008D22 [01/05/2010 15:58:57] Processing P96 authentication ... [01/05/2010 15:59:11] Device Key : FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF [01/05/2010 15:59:11] Restarting the phone... [01/05/2010 15:59:14] Booting via ROM ... [01/05/2010 15:59:14] OTP IMEI = 351807-03-141520-4 [01/05/2010 15:59:15] EROM Color (BOOT) = 1 : BLUE [01/05/2010 15:59:15] EROM CID (BOOT) = 53 [01/05/2010 15:59:19] RND : D4901D6F35803F5E35008D22 [01/05/2010 15:59:19] Processing P96 authentication ... [01/05/2010 15:59:32] Restarting the phone... [01/05/2010 15:59:36] Booting via ROM ... [01/05/2010 15:59:36] OTP IMEI = 351807-03-141520-4 [01/05/2010 15:59:36] EROM Color (BOOT) = 1 : BLUE [01/05/2010 15:59:36] EROM CID (BOOT) = 53 [01/05/2010 15:59:39] Writing SEMCBOOT... [01/05/2010 16:05:23] Error : #3190:000402A0 [01/05/2010 16:05:23] Error : #3190:00380401 [01/05/2010 16:05:23] Error : #3190:00380385 [01/05/2010 16:05:23] Error : #3190:003A02C3 [01/05/2010 16:05:23] Error : #3190:003A05C4 [01/05/2010 16:05:23] Error : #3190:003C05EE [01/05/2010 16:05:23] Error : #3190:003C045F [01/05/2010 16:05:23] Warning : Aborted by user. [01/05/2010 16:05:23] [01/05/2010 16:32:03] [01/05/2010 16:32:03] DBSS Start 3.25 [01/05/2010 16:32:23] --- Reading Info--------------------------------------------------------------- [01/05/2010 16:32:26] User selected phone W705 using DCU60 boot mode [01/05/2010 16:32:27] 1) Turn OFF the phone. [01/05/2010 16:32:27] 2) Hold <2>+<5> buttons and connect the phone to DCU60 cable. [01/05/2010 16:33:11] Error : #3190:0004019C [01/05/2010 16:33:11] Error : #3190:00380185 [01/05/2010 16:33:11] Error : #3190:003800FA [01/05/2010 16:33:11] Error : #3190:003C0092 [01/05/2010 16:33:11] Warning : Aborted by user. | ||
