Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > GSMServer Products > DreamBox
Old 08-04-2008, 17:07   #1 (permalink)
Member: 137181
Thanks Meter: 3
Cool W850 Red Blink Done via TP w/tricks
Just for reference purposes W850 red blink GDFS problem SOLVED via Testpoint and with matching tricks sa STAGE 2 always FAILED
first disassemble the unit carefully
then prepare TP for procedure
launch DBSS select TESPOINT MODE
EXECUTE SEC BYPASS
connect TP where SOFT ask you
AFTER success TP operation
press UNLOCK & REPAIR GDFS
wait till finish then youre DONE
TEST the unit before assembling the unit
LOGS
--- Security Bypass------------------------------------------------------------
User selected phone W850 using Test Point boot mode
Stage 1 started
1) Turn OFF the phone.
2) Connect the phone to DreamBox cable.
Boot Responce = 5A
Processor ID = 99000301FFFFFFFF (DB2020 / DB2030)
NOR Flash ID = 897E
OTP Status = LOCKED
OTP IMEI = 352401-*********
OTP CID = 49
EROM Color = 4 : RED
EROM CID = 52
Hint : Now the probe might be disconnected
Processing ...
Stage 1 completed succesfully
Stage 2 start
Processing...
Entering Security Bypass mode ...
Boot Responce = 5A
Sending Application ...
NOR Flash ID = 897E
OTP Status = LOCKED
OTP CID = 49
EROM CID = 52
Baseband Chip ID = 9900
Phone ID = 218091601580B9E8
Finalizing ...
Stage 2 completed succesfully
Done.
--- Unlock and Repair----------------------------------------------------------
User selected phone W850 using Security Bypass boot mode
Boot Responce = 5A
NOR Flash ID = 897E
OTP Status = LOCKED
OTP IMEI = 352401-**********
OTP CID = 49
EROM CID = 52
Reading GDFS...
Testing security ...
GDFS 0013 Hash Failed
GDFS 0006 Hash Failed
GDFS 000E Hash Failed
GDFS 001C Hash Failed
Unlocking ...
GDFS 0013 Hash OK
GDFS 0006 Hash OK
GDFS 000E Hash OK
GDFS 001C Hash OK
Generating GDFS...
Writing GDFS...
Done.
AFTER that
my secret ????
a switch connected to power button so i can press easily ON/OFF switch while on stage 2 process,works for me everytime
thanks to master shi-fu Alfox for the encouragement
regards
swensonb
DBSS user
Old 04-03-2009, 06:37   #2 (permalink)
Member: 599037
Thanks Meter: 103
it can be done without that button.. never neded that pwr button in drm box.. i hav done a lot
The Following User Says Thank You to peter002 For This Useful Post:
K800 Red Blink Repaired via TP adnanskyland SETool2 17 02-11-2010 18:13
K770 done RED Blink was NON TP IN CREDIT BY SETOOL azad4u SETool2 0 02-02-2010 05:11
k770 red blink done w/out TP textzone Cruiser Suite 0 10-11-2009 05:44
W850 Red Blinking Repair Successfully jatchaminda DreamBox 2 06-13-2008 18:44
Need Help from Experts...W850 red blinking... harim_1981 DreamBox 2 05-10-2008 07:08
Page generated in 1.06007 seconds with 9 queries
