05-25-2008, 05:41 | #1 (permalink) |
Freak Poster Join Date: Sep 2007 Location: Lima - Perú
Member: 598854 Status: Offline Thanks Meter: 141 | w850 totally dead , now red blink User selected phone W850 using Test Point boot mode Turn OFF the phone. Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) NOR Flash ID = 2019 OTP Status = LOCKED OTP IMEI = 352826-01-347179-4 OTP CID = 49 EROM Color = 4 : RED EROM CID = 52 Hint : Now the probe might be disconnected Processing ... Flash Chip : ST M58PR512J Flash Chip ID : 88190020 Generating GDFS... Writing GDFS... Done. Then i flash phone with corresponding firmware: User selected phone W850 using Normal boot mode 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) NOR Flash ID = 2019 OTP Status = LOCKED OTP IMEI = 352826-01-347179-4 OTP CID = 49 EROM Color = 4 : RED EROM CID = 52 Sending Main Firmware Certificate ... OK. Writing Main Firmware Blocks Finished. Sending File System Certificate ... OK. Writing File System Blocks Finished. Done. Now phone red blink, but dont power on at all, what is the correct procedure to repair gdfs?, im already know how to do the tp, but im confused with procedure on software, im new user of dreambox. thanks in advance, its a great great great tool, good luck dbteam and i hope you can help me with this . Best regards |
05-25-2008, 08:44 | #2 (permalink) |
Freak Poster Join Date: Aug 2005 Age: 47
Member: 170455 Status: Offline Thanks Meter: 23 | User selected phone W850 using Test Point boot mode Turn OFF the phone. Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) NOR Flash ID = 2019 OTP Status = LOCKED OTP IMEI = 352826-01-347179-4 OTP CID = 49 EROM Color = 4 : RED EROM CID = 52 Hint : Now the probe might be disconnected Processing ... Flash Chip : ST M58PR512J Flash Chip ID : 88190020 Generating GDFS... WHAT GDFS U WRITE? Writing GDFS...Done. WHERE IS STAGE 2 PROCEDURE?? YR PROCEDURE MUST BE LIKE THIS. EX: - Security Bypass------------------------------------------------------------ User selected phone K800 using Test Point boot mode Stage 1 started 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 351708-01-NOT SHOW-5 OTP CID = 49 EROM Color = 4 : RED EROM CID = 52 Hint : Now the probe might be disconnected Processing ... Stage 1 completed succesfully Stage 2 start Hint : Now the probe might be disconnected Processing... Entering Security Bypass mode ... 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) Sending Application ... NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 351708-01-NOT SHOW-5 OTP CID = 49 EROM Color = 4 : RED EROM CID = 52 Baseband Chip ID = 9900 Phone ID = 2180DC5D15D09986 Finalizing ... Stage 2 completed succesfully Done. --- Loading GDFS file---------------------------------------------------------- Loading "C:\DVD_COLLECTION\Dream Box\GDFS\K800_gdfs.dmap"... Done. --- Write GDFS----------------------------------------------------------------- User selected phone K800 using Security Bypass boot mode 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) Sending Application ... NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 351708-01-NOT SHOW-5 OTP CID = 49 EROM Color = 4 : RED EROM CID = 52 Baseband Chip ID = 9900 Phone ID = 2180DC5D15D09986 Flash Chip : Intel 48F50xxM0Y0 Flash Chip ID : 887E0089 Generating GDFS... Writing GDFS... Done. --- Unlock and Repair---------------------------------------------------------- User selected phone K800 using BypassSecurity boot mode 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) Sending Application ... NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 351708-01-NOT SHOW-5 OTP CID = 49 EROM Color = 4 : RED EROM CID = 52 Baseband Chip ID = 9900 Phone ID = 2180DC5D15D09986 Reading GDFS... Testing security ... GDFS 0013 Hash Failed GDFS 0006 Hash Failed GDFS 000E Hash Failed GDFS 001C Hash Failed Unlocking ... Testing security ... GDFS 0013 Hash OK GDFS 0006 Hash OK GDFS 000E Hash OK GDFS 001C Hash OK Generating GDFS... Writing GDFS... Done. IF STILL RED BLINK U MAY CHECK FLEX , UI BOARD AND MAIN BOARD CONNECTOR. BR, |
05-30-2008, 23:47 | #5 (permalink) |
Member: 598854 Status: Offline Thanks Meter: 141 | i achieve to pass the 1st stage with easy tp and normal variant 1 , but second stage always failed i try all variants, im confused with image from support, its not same side on 2nd stage, please please somebody could send me and image of correct place for tp 2nd stage. here the image the yellow circles where i achieve the 1st stage , and pink circles where i found 2nd stage variants but all of them failed time out detected: this are my flash chip 2 nd stage variant 1: 2 nd stage variant 2: it say that 2 variants are on side 3. but i see a lot of differences between the 2. B.R Last edited by renzox; 05-30-2008 at 23:53. |
05-31-2008, 02:46 | #7 (permalink) |
Member: 598854 Status: Offline Thanks Meter: 141 | hi kevin, nice to see you here hehehe, i try the 2 variants accoding to picture and always give that timeout error, please somebody know where is easy tp for 2nd stage or the most effective tp and give me the exact position ????. B.R |
bb 7290 totally dead no red light | unlock & flash | BlackBerry (RIM) | 0 | 10-14-2009 13:13 |
How To Repair W850 if detech k700- RED blink | zakiyyboss | Sony Ericsson | 26 | 03-28-2009 06:30 |
How To Repair W850 if detech k700- RED blink | zakiyyboss | SETool2 | 4 | 12-26-2008 12:31 |
k300i dead, only red blinking but only without baterry | NEON-GSM | Sony Ericsson Hardware Repair | 3 | 09-05-2005 14:12 |
t28 unlock and total dead now... | snoopy | Old Ericsson Phones & Sony Phones | 5 | 06-19-2002 22:17 |
