06-13-2008, 03:24 | #1 (permalink) |
No Life Poster Join Date: Nov 2004 Location: Pinas Age: 45
Member: 91411 Status: Offline Sonork: 100.1584444 Thanks Meter: 372 | z610i red blink repaired by dbss Code: - Reading Info--------------------------------------------------------------- User selected phone Z610 using Test Point boot mode 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) Error : Failed. --- Reading Info--------------------------------------------------------------- User selected phone Z610 using Test Point boot mode 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 352836-01-687631-1 OTP CID = 49 EROM Color = 4 : RED EROM CID = 52 Error : Failed. --- Reading Info--------------------------------------------------------------- User selected phone Z610 using Normal boot mode 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 352836-01-687631-1 OTP CID = 49 EROM Color = 4 : RED EROM CID = 52 Starting CS Loader GDFS Service ... GDFS Simlocks : Lock 0 = OFF (00) [5/5] (Network) Lock 1 = OFF (00) [5/5] (Network Subset) Lock 2 = OFF (00) [5/5] (Service Provider) Lock 3 = OFF (00) [5/5] (Corporate) Lock 4 = OFF (00) [5/5] (SIM Card) Lock 5 = OFF (00) [5/5] (Extended) Operator code = 000-00 Done. --- Security Bypass------------------------------------------------------------ User selected phone Z610 using Test Point boot mode Stage 1 started 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 352836-01-687631-1 OTP CID = 49 EROM Color = 4 : RED EROM CID = 52 Warning : Aborted by user. --- Security Bypass------------------------------------------------------------ User selected phone Z610 using Test Point boot mode Stage 1 started 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 352836-01-687631-1 OTP CID = 49 EROM Color = 4 : RED EROM CID = 52 Hint : Now the probe might be disconnected Processing ... Error : Failed. --- Security Bypass------------------------------------------------------------ User selected phone Z610 using Test Point boot mode Stage 1 started 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 352836-01-687631-1 OTP CID = 49 EROM Color = 4 : RED EROM CID = 52 Hint : Now the probe might be disconnected Processing ... Error : Failed. --- Security Bypass------------------------------------------------------------ User selected phone Z610 using Test Point boot mode Stage 1 started 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 352836-01-687631-1 OTP CID = 49 EROM Color = 4 : RED EROM CID = 52 Hint : Now the probe might be disconnected Processing ... Stage 1 completed succesfully Stage 2 start Hint : Now the probe might be disconnected Processing... Entering Security Bypass mode ... 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) Sending Application ... NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 352836-01-687631-1 OTP CID = 49 EROM Color = 4 : RED EROM CID = 52 Baseband Chip ID = 9900 Phone ID = 2180446215F0E0A7 Finalizing ... Stage 2 completed succesfully Done. --- Unlock and Repair---------------------------------------------------------- User selected phone Z610 using Security Bypass boot mode 1) Turn OFF the phone. 2) Connect the phone to DreamBox cable. Boot Responce = 5A Processor ID = 99000301FFFFFFFF (DB2020 / DB2030) Sending Application ... NOR Flash ID = 897E OTP Status = LOCKED OTP IMEI = 352836-01-687631-1 OTP CID = 49 EROM Color = 4 : RED EROM CID = 52 Baseband Chip ID = 9900 Phone ID = 2180446215F0E0A7 Reading GDFS... Testing security ... GDFS 0013 Hash Failed GDFS 0006 Hash Failed GDFS 000E Hash Failed GDFS 001C Hash Failed Unlocking ... Testing security ... GDFS 0013 Hash OK GDFS 0006 Hash OK GDFS 000E Hash OK GDFS 001C Hash OK Generating GDFS... Writing GDFS... Done. |
06-14-2008, 02:20 | #3 (permalink) |
Member: 91411 Status: Offline Sonork: 100.1584444 Thanks Meter: 372 | actually its not lots of tries.those many tries were intended without the tp just to test if the phone could goto by pass mode without error and after all tests then opened the unit ready for TP |
Sony Ericsson K550i RED Blink Repair Done By Setool3 | Sahil2007 | SETool2 | 10 | 04-06-2009 23:12 |
>> Post here your Successfull Red Blink Repair by Useing SE Testpoint Full Unlocker > | Faisal_Computer | Cruiser Suite | 25 | 10-14-2008 11:47 |
k800i red blinking repaired with dbss v3.41 | alfox | DreamBox | 0 | 04-28-2008 05:03 |
k800i red blinking repaired with dbss v3.4 | alfox | DreamBox | 0 | 04-22-2008 09:05 |
