07-18-2006, 20:03 | #1 (permalink) |
Registered User Join Date: Aug 2003 Age: 41
Member: 36653 Status: Offline Thanks Meter: 336 | any solution for w300 death because crc not supported !! I trayed to fash it and it give me Switch phone ON Get phone info Flash CID: 49 Phone KEY: A1_DB2010_49_RED OTP CID: 49 Phone IMEI: 359988002xxxxx Flash ID: 897E Switch phone ON Write Flashloader CID49 Waiting to finish Switch phone ON Start Flashloader CID49 Send FLASH application Switch phone ON Send FLASH application Checking MAIN flash file Send MAIN flash file: "W300_R9A031_ZONE1_STANDARD.mbc" ERROR: 30223B Last edited by the new; 07-18-2006 at 20:58. |
07-18-2006, 22:13 | #4 (permalink) | |
Member: 36653 Status: Offline Thanks Meter: 336 | Quote:
but I see many user have this problem (batterie full charrged )! | |
07-27-2006, 11:37 | #5 (permalink) |
Insane Poster Join Date: Apr 2004 Age: 44
Member: 64149 Status: Offline Thanks Meter: 0 | Guys, if you have cruiser try it: - manually select w300i - unlock RSA - remove&put battery - connect phone - restore firmware - DO NOT DISCONNECT THE PHONE - flash main, fs, complete phone After many times with usbsmart and cruiser this solution working. ERROR: 30223B is NOT battery. |
08-01-2006, 10:40 | #7 (permalink) |
Freak Poster Join Date: Jun 2002 Location: Spain Age: 52
Member: 13239 Status: Offline Thanks Meter: 3 | I'm happy that with cruiser it works, but we have USB-Samrt and we are un USB-Smart section. Send MAIN flash file: "W300_R9A031_ZONE1_STANDARD.mbc" ERROR: 30223B Trying to flash W300 after reading codes and CXC not supported. Please Zulea solve this problem ASAP. Regards |
08-01-2006, 11:44 | #8 (permalink) |
No Life Poster Join Date: Nov 2003
Member: 44904 Status: Offline Thanks Meter: 45 | same problem i try read code and now phone blink blink Switch phone ON Get phone info Flash CID: 49 Phone KEY: A1_DB2010_49_RED OTP CID: 49 Phone IMEI: xxxxxxxxxxxxxx Flash ID: 2019 Switch phone ON Write Flashloader CID49 Waiting to finish Switch phone ON Start Flashloader CID49 Reading flash CXC version Version: R9A036_CXC1123265_ORANGE_JE Send FLASH application Write GDFS Flashloader Switch phone ON Start GDFS Flashloader Recover first flash part ERROR: CXC version not supported for recovery! Please flash MAIN, FS, Complete with any files from Support Area then make Unlock again to solve this error! Mr ZULEA my custumer kill my aaaaaaaaaaaaaaaa!!!!!!!!!!!!!!!!!!!! help i try flash with flash support file and give error log Switch phone ON Get phone info Flash CID: 49 Phone KEY: A1_DB2010_49_RED OTP CID: 49 Phone IMEI: xxxxxxxxxxxxxxxxx Flash ID: 2019 Switch phone ON Write Flashloader CID49 Waiting to finish Switch phone ON Start Flashloader CID49 Send FLASH application Switch phone ON Send FLASH application Checking MAIN flash file Send MAIN flash file: "W300_R9A031_ZONE1_STANDARD.mbc" ERROR: 30223B help help need test point |
08-02-2006, 15:33 | #11 (permalink) |
No Life Poster Join Date: Jul 2006 Location: London
Member: 315127 Status: Offline Thanks Meter: 6 | i had same probs with usb smart. and it seems cruiser sort out all these probs on a better hand. now iam using only cruiser for flashin . but for unlockin usbsmart is the easy to handle tool still.. isint |
08-02-2006, 21:24 | #12 (permalink) | |
No Life Poster Join Date: Jun 2005 Location: Sahara Desert Age: 77
Member: 150570 Status: Offline Thanks Meter: 52 | Quote:
Marty | |
08-03-2006, 18:28 | #15 (permalink) |
Member: 44904 Status: Offline Thanks Meter: 45 | personal i buy asnd cruiser i flash with cruiser phone alive but i cant red code with cruiser i read code with usbsmart and phone dont death because now flash is W300_R9A031 not suport read code from W300_R9A033(4) |
touch screen not work any solution for skip | waqas_as | Chinese Models & Cloned Phones | 4 | 12-27-2008 15:02 |
any real solutions for gd87 Death when are flashing !! | humbedj | Panasonic | 1 | 01-31-2006 12:08 |
***SC_Team where is repair solutions for customers death box after upgrade ? *** | hard | Smart-Clip | 19 | 10-29-2005 19:14 |
any solution for death V300 | dejo | Motorola P2k | 6 | 05-16-2004 10:57 |
