Unlock Server
Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > USB-Smart > SonyEricsson (USB-Smart)
Old 03-01-2006, 15:58   #1 (permalink)
Member: 127030
Bad NAND block found :: K750i
Here is what I had before doing anything with help of USB smart:
672 GDFS Init Erase erase blk 7
672 FSFLASH: This should not happen. Probably HW error
672 FSFLASH: flash @ 0x45FE0000, 12 bytes
672 FSFLASH: 000: 00 00 00 00 00 00 00 00 00 00 00 00
672 FSFLASH: source @ 0x4C265D30, 12 bytes
672 FSFLASH: 000: 00 00 00 00 0F 00 00 00 00 00 00 00
672 FSFLASH: NOR-flash (0x20) read back failed
672 FSFLASH: NOR-flash (0x20, 0x0F4924279565358B) read back failed @ 0x45FE0000GDFS_LL: FAM error 0x00CC1004 -> GDFS error 29[ICC-LD] ICC_Reader_0_Process Started
673 [ICC-LD] Status Changed: ICC_READER_DEACTIVATED, Reader: 0[SIM] State Changed: SIM_STATE_NULL, Appl: 0, Ref: 0
And this is after I flashed GDFS/Main/FS with USB smart
FSFLASH: Write processes started, pid = 0x1002B.
FSFLASH: Erase processes started, pid = 0x1002C.
FSFLASH: Uncomplete erase found @ 0x5000C000, magic number = 0x1254
FSFLASH: Bad NAND block found @ 0x5000C000
FSFLASH: Uncomplete erase found @ 0x50028000, magic number = 0x1254
FSFLASH: Bad NAND block found @ 0x50028000
FSFLASH: Uncomplete erase found @ 0x50034000, magic number = 0x1254
FSFLASH: Bad NAND block found @ 0x50034000
FSFLASH: Uncomplete erase found @ 0x50038000, magic number = 0x1254
FSFLASH: Bad NAND block found @ 0x50038000
FSFLASH: Uncomplete erase found @ 0x5003C000, magic number = 0x1254
FSFLASH: Bad NAND block found @ 0x5003C000
FSFLASH: Uncomplete erase found @ 0x50040000, magic number = 0x1254
FSFLASH: Bad NAND block found @ 0x50040000
FSFLASH: Uncomplete erase found @ 0x50044000, magic number = 0x1254
FSFLASH: Bad NAND block found @ 0x50044000
FSFLASH: Uncomplete erase found @ 0x50048000, magic number = 0x1254
FSFLASH: Bad NAND block found @ 0x50048000
FSFLASH: Uncomplete erase found @ 0x5004C000, magic number = 0x1254
FSFLASH: Bad NAND block found @ 0x5004C000
FSFLASH: Uncomplete erase found @ 0x50050000, magic number = 0x1254
FSFLASH: Bad NAND block found @ 0x50050000
FSFLASH: Uncomplete erase found @ 0x50054000, magic number = 0x1254
FSFLASH: Bad NAND block found @ 0x50054000
FSFLASH: Uncomplete erase found @ 0x50058000, magic number = 0x1254
FSFLASH: Bad NAND block found @ 0x50058000
FSFLASH: Uncomplete erase found @ 0x5005C000, magic number = 0x1254
FSFLASH: Bad NAND block found @ 0x5005C000
FSFLASH: Uncomplete erase found @ 0x50060000, magic number = 0x1254
FSFLASH: Bad NAND block found @ 0x50060000
FSFLASH: Uncomplete erase found @ 0x50064000, magic number = 0x1254
FSFLASH: Bad NAND block found @ 0x50064000
FSFLASH: Uncomplete erase found @ 0x50068000, magic number = 0x1254
FSFLASH: Bad NAND block found @ 0x50068000
FSFLASH: Uncomplete erase found @ 0x5006C000, magic number = 0x1254
FSFLASH: Bad NAND block found @ 0x5006C000
FSFLASH: Uncomplete erase found @ 0x50070000, magic number = 0x1254
FSFLASH: Bad NAND block found @ 0x50070000
FSFLASH: Uncomplete erase found @ 0x50074000, magic number = 0x1254
FSFLASH: Bad NAND block found @ 0x50074000
FSFLASH: Uncomplete erase found @ 0x50078000, magic number = 0x1254
FSFLASH: Bad NAND block found @ 0x50078000
FSFLASH: Uncomplete erase found @ 0x5007C000, magic number = 0x1254
FSFLASH: Bad NAND block found @ 0x5007C000
FSFLASH: Uncomplete erase found @ 0x50080000, magic number = 0x1254
FSFLASH: Bad NAND block found @ 0x50080000
FSFLASH: Uncomplete erase found @ 0x5008C000, magic number = 0x1254
FSFLASH: Bad NAND block found @ 0x5008C000
FSFLASH: Uncomplete erase found @ 0x50090000, magic number = 0x1254
FSFLASH: Bad NAND block found @ 0x50090000
FSFLASH: Uncomplete erase found @ 0x50094000, magic number = 0x1254
FSFLASH: Bad NAND block found @ 0x50094000
FSFLASH: Uncomplete erase found @ 0x50098000, magic number = 0x1254
FSFLASH: Bad NAND block found @ 0x50098000
FSFLASH: Uncomplete erase found @ 0x5009C000, magic number = 0x1254
FSFLASH: Bad NAND block found @ 0x5009C000
FSFLASH: Uncomplete erase found @ 0x500A0000, magic number = 0x1254
FSFLASH: Bad NAND block found @ 0x500A0000
FSFLASH: Uncomplete erase found @ 0x500A4000, magic number = 0x1254
FSFLASH: Bad NAND block found @ 0x500A4000
FSFLASH: Uncomplete erase found @ 0x500A8000, magic number = 0x1254
FSFLASH: Bad NAND block found @ 0x500A8000
FSFLASH: Uncomplete erase found @ 0x500AC000, magic number = 0x1254
FSFLASH: Bad NAND block found @ 0x500AC000
FSFLASH: Uncomplete erase found @ 0x500B0000, magic number = 0x1254
FSFLASH: Bad NAND block found @ 0x500B0000
FSFLASH: Uncomplete erase found @ 0x500B4000, magic number = 0x1254
FSFLASH: Bad NAND block found @ 0x500B4000
FSFLASH: Uncomplete erase found @ 0x500B8000, magic number = 0x1254
FSFLASH: Bad NAND block found @ 0x500B8000
FSFLASH: Uncomplete erase found @ 0x500BC000, magic number = 0x1254
FSFLASH: Bad NAND block found @ 0x500BC000
FSFLASH: Uncomplete erase found @ 0x500C0000, magic number = 0x1254
FSFLASH: Bad NAND block found @ 0x500C0000
FSFLASH: Uncomplete erase found @ 0x500C4000, magic number = 0x1254
FSFLASH: Bad NAND block found @ 0x500C4000
FSFLASH: Uncomplete erase found @ 0x500C8000, magic number = 0x1254
FSFLASH: Bad NAND block found @ 0x500C8000
FSFLASH: Uncomplete erase found @ 0x500CC000, magic number = 0x1254
FSFLASH: Bad NAND block found @ 0x500CC000
FSFLASH: Uncomplete erase found @ 0x500D0000, magic number = 0x1254
FSFLASH: Bad NAND block found @ 0x500D0000
FSFLASH: Uncomplete erase found @ 0x500D4000, magic number = 0x1254
FSFLASH: Bad NAND block found @ 0x500D4000
FSFLASH: Uncomplete erase found @ 0x500D8000, magic number = 0x1254
FSFLASH: Bad NAND block found @ 0x500D8000
FSFLASH: Uncomplete erase found @ 0x500DC000, magic number = 0x1254
FSFLASH: Bad NAND block found @ 0x500DC000
FSFLASH: Uncomplete erase found @ 0x500E0000, magic number = 0x1254
FSFLASH: Bad NAND block found @ 0x500E0000
FSFLASH: Uncomplete erase found @ 0x500E4000, magic number = 0x1254
FSFLASH: Bad NAND block found @ 0x500E4000
FSFLASH: TOTAL file system blocks: 43988
FSFLASH: AVAILABLE file system blocks: 43013
FSFLASH: COMMITTED file system blocks: 10020
FSFLASH: FREE file system blocks: 32993
FSFLASH: DIRTY file system blocks: 0
FSFLASH: CLEAN file system blocks: 33248 (3315 NOR)
FSFLASH: BAD file system blocks: 720
NAND was certainly working before.
Is there any way usb-smart demaged NAND?
Any ideas?
Old 03-01-2006, 18:16   #2 (permalink)
Proxy's Avatar
Member: 66399
there was seen some ''faulty" flash ic`s sometimes (on t630 tested on me...) which died by programming... my opinion is things like this sometimes hapened, and nothing to do...
But when looking from another side .. WHY?
Old 03-01-2006, 18:20   #3 (permalink)
Member: 127030
Well, actually this is not first phone with bad NAND, so I wouldn't say "sometimes"... And I always tried to repair with usb-smart first, without looking into logs. This time I looked before repairing and there was no NAND problem, although there was NOR issue as I understand.
Old 03-01-2006, 20:39   #4 (permalink)
agent003's Avatar
Member: 19094
This could be a long shot and plain as day also but I gather the battery as plenty of charge in it??
Also why have a k750 when you can have a w800 ... try throwing some of those files at it... worth a try ....from what i seen ...sometimes diferent things work for diferent people on here with usb smart...so why not....nothing to lose
Polarbox 2,bad box,bad support,please read forum users ::S.H.I.T BUT ANSWERED :: DJiCE PolarBox 2 13 09-22-2009 23:27
k750 bad nand flash -can i replece from another k750? zone2 Sony Ericsson 1 01-18-2009 21:25
::-::-::-::-:: @ All Tunisian's Unlockers ::-::-::-::-:: maverick_lp28 Off Topic Zone 72 05-18-2007 18:51
Page generated in 0.88772 seconds with 11 queries
