05-04-2006, 20:17 | #1 (permalink) |
No Life Poster Join Date: Dec 2000 Location: J.A.U - Just Another Unlocker Age: 43
Member: 2878 Status: Offline Thanks Meter: 9,123 | D750i @ K750i or W800i both white display please help!!! i have a big problem. i have a D750i and flashed with usb-smart 7.9 to W800i. now all ok, but with white display! i can make calls and so on but the screen is only white. here is a log from usb-smart: Switch phone ON Get phone info Flash CID: 36 Phone KEY: A1_DB2010_36_BROWN OTP CID: 36 Phone IMEI: 35657600615140 Flash ID: 200D Switch phone ON Send FLASH application Checking MAIN flash file Send MAIN flash file: "K750_R1N035_ZONE1_STANDARD_IMEI.mbn" MAIN flash sent OK Checking FS flash file Send FS flash file: "K750_R1N035_EU2.fbn" FS flash sent OK Switch phone ON Get phone info Flash CID: 36 Phone KEY: A1_DB2010_36_BROWN OTP CID: 36 Phone IMEI: 35657600615140 Flash ID: 200D Switch phone ON Send FS application App FS: 063035303530332032303031204E5041435843313332373336 345F434F4D504143545F53454D435F43535F4C4F414445525F 5F523345 Start FS services Complete phone Please remove and insert battery before try to power phone! Operation succesfull whats that? i have flashed it with W800i fullflash repair and with old an new normal firmwares. i flashed the same thinks to K750i and the problem is the same, white dipsplay. i flashed eerpom, gdfs, remake crc´s und sp area. i completed the phone. i unlocked the phone but still white display. before i flashed this phone all was ok. what can i make now? please help ( |
05-23-2006, 13:49 | #3 (permalink) | |
Freak Poster Join Date: Dec 2005 Location: UEM
Member: 207453 Status: Offline Thanks Meter: 14 | K750i white Display but fone works fine Quote:
i have the same problem wtih k750i just white display but fone is working fine wil you plz tel me brefily aboiut oldes i didnt get that point, waiting for ur reply thanks BR AbdulRahman | |
05-23-2006, 15:10 | #5 (permalink) | |
Member: 207453 Status: Offline Thanks Meter: 14 | Quote:
i flash the fone and i write GDFS and i unclok that but still same Switch phone ON Get phone info Flash CID: 36 Phone KEY: A1_DB2010_36_RED OTP CID: 36 Phone IMEI: 35785000592986 Flash ID: 200D Switch phone ON Send FLASH application Checking MAIN flash file Send MAIN flash file: "K750_R1AA008_ZONE1_STANDARD.mbn" MAIN flash sent OK Checking FS flash file Send FS flash file: "K750_R1AA008_EMEA6.fbn" FS flash sent OK Switch phone ON Get phone info Flash CID: 36 Phone KEY: A1_DB2010_36_RED OTP CID: 36 Phone IMEI: 35785000592986 Flash ID: 200D Switch phone ON Send FS application Start FS services Complete phone Please remove and insert battery before try to power phone! Operation succesfull Switch phone ON Get phone info Flash CID: 36 Phone KEY: A1_DB2010_36_RED OTP CID: 36 Phone IMEI: 35785000592986 Flash ID: 200D Switch phone ON Send GDFS application Convert to BROWN Switch phone ON Send GDFS application Clear all SP locks Read all codes IMEI: 35785000592986 Unlock NCK: 67030537 Unlock NSCK: 53241867 Unlock SPCK: 60871705 Unlock CCK: 85116926 Unlock PCK: 29511548 Unlock ECK: 77651081 Relock NCK: 69149768 Relock NSCK: 71053087 Relock SPCK: 42041711 Relock CCK: 35706086 Relock PCK: 81826193 Relock ECK: 46733174 User code: 0000 Reset user code Convert back to RED Operation succesfull Switch phone ON Get phone info Flash CID: 36 Phone KEY: A1_DB2010_36_RED OTP CID: 36 Phone IMEI: 35785000592986 Flash ID: 200D Switch phone ON Send GDFS application Convert to BROWN Switch phone ON Send GDFS application Send GDFS file: "k750gdfs.gdf" Rebuild SP area and CRCs Rebuild SP area and CRCs Remake all CRCs Convert back to RED Operation succesfull But still display is white LCD also changed but still same if any1 know this problem then plz.. share with me their exprience Thanks BR Abdulrahman Last edited by abdulrahman; 05-23-2006 at 15:45. | |
05-23-2006, 16:12 | #6 (permalink) |
No Life Poster Join Date: May 2006 Location: ..::INDIA::..
Member: 279604 Status: Offline Sonork: 100.1582858 Thanks Meter: 198 | its nothing but a gdfs problem use the following things----- 1) go in flash arm there select in main the gdfs file 2) then select K750_R1N035_ZONE1_STANDARD.mbn in MAIN K750_R1N035_eu1_fbn in fs 3) then select do job 4) select complete phone after flash and do job 5) then go to repair opption tick to rebuild sp area+ remark crc |
05-23-2006, 23:32 | #7 (permalink) |
Product Supporter Join Date: Dec 2001 Location: in my skin Age: 47
Member: 8086 Status: Offline Thanks Meter: 180 | I have the same problem here, phone looks to be OK except that it shows only white screen. I was working on it 'till hours, tried allmost everything (eeprom area flash, gdfs , repair sp area,crc's etc.) I was thought that tha phone had a newer firmware before flashing and has a new type lcd,what is not supported by R1N035 firmware, but sadly I had not checked original firmware before started to flash. Am I right? I'am keep on working on it... I will report result. |
05-24-2006, 16:26 | #9 (permalink) |
Member: 2878 Status: Offline Thanks Meter: 9,123 | for all with the same problem like mine just flash R1AA008 firmware and the phone works! testet on 5 K750i and D750i and it worked all the time. |
05-25-2006, 16:54 | #10 (permalink) | |
Member: 207453 Status: Offline Thanks Meter: 14 | K750i white display Quote:
BR | |
05-26-2006, 01:42 | #12 (permalink) | |
No Life Poster Join Date: Dec 2002 Age: 46
Member: 19094 Status: Offline Thanks Meter: 3 | Quote:
BR | |
05-31-2006, 18:23 | #14 (permalink) | |
Member: 8086 Status: Offline Thanks Meter: 180 | Quote:
Figured out that this phone had "language lock" locked. It was repaired by pathing language lock area with other sw. Zulea please add this feature to usb-smart semc tool too in the near future. thx | |
06-01-2006, 01:28 | #15 (permalink) | |
BR | |
