Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > USB-Smart > SonyEricsson (USB-Smart)
Old 10-29-2005, 20:39   #1 (permalink)
Member: 116970
ERROR: 303301 thise error in allllllllllllll k700 why
Old 01-04-2006, 07:11   #2 (permalink)
struggler's Avatar
Member: 208691
well i get that error to.. I dint flash the phone more. Just check Complete phone and do job and it works
Old 01-04-2006, 08:04   #3 (permalink)
senkron24's Avatar
Member: 15880
Sonork: 100.1612155
je mann what is thad pls saersch mann and not spamm in the suport forum from zuleah
here is eror masaje from
ERROR: 303106: You have different flash files versions…Correct this little mistake and try again
ERROR: 30353B: You have tried to flash the three flash files (Main, Fs, Sfa). Flash only= TWO flash files and later if you want you can flash Sfa file in the phone only.
ERROR: 300314: This Error is appears when you have a V600(maybe any phone) with CID’s mismatch. Flash Erom with CID36 from support area for that phone. Also as a suggestion flash with main and fs file after Erom for better result.
ERROR: 003608, ERROR: 00360C & ERROR: 00360C: This errors where showed when the phone had the RSA killed by Twister or Terminator
ERROR: 304314: This error appears when you are using flash files with CID lower than in OTP. You must use equal or higher.
ERROR: 0001A1: Possibly problem due to cable with bad connection. Check the cable or buy a new one
ERROR: 00A405: This problem happens when you have communication/timers problem check that the cable is working and post a thread telling the exactly error if still happening. Problem related to T100. It’s impossible to clear SP locks in this phone.
ERROR: 300301: Bug found in v1.1 in Sony Ericsson z1010, support with CID16. Problem already solved
ERROR: 304107 & ERROR: 304106: Recover Certificate Problems
ERROR: 303002: This problem appeared when you are trying to Complete the phone alter flash. This error should be already solved. Occurred in v1.7
ERROR: 304100: This error appears when we are trying to flash a phone that’s empty. This will be solved in a short period of time. In Z1010 phones with CID16 we had this bug corrected already in v1.9
ERROR: 302403: This was a bug corrected in v3.1 so if you have seen this error download last exe. Also this error appeared in v2.0 reading flash files bug was fixed
ERROR: 300314: Problem when trying to unlock V600 in v1.7/1.9 fixed on newer versions.
ERROR: 003612: Use another cable T28 com cable doesn’t work in AVR phones
ERROR NETWORK CONTACT: You have to Complete phone
and not write with creked soft here all good work here by new version from usm smart and zuleah work for godd upd for orginal user not for carker hehe
an all pls dont write first serch first then you write pls dont write with craked soft this craked dont work 100%
best regarts senkron24
Old 01-04-2006, 13:32   #4 (permalink)
jab
Member: 12386
hi all,
this the error message i get when i try to flash and the phone comes on:
ERROR: 300314:
to rectify this is what zulea says
can someone please kindly explain how i flash the eprom.
thanks
jab
Old 01-05-2006, 04:05   #5 (permalink)
arunamobile's Avatar
Member: 129258
i have one j300i when we try to recovery flash certificate error 304106. now hown can we flash please guide us thanking you
Old 01-05-2006, 19:52   #6 (permalink)
jab
Member: 12386
Question still cant flash (need a hammer)
hi Zulea,
i want your expertise on this problem tried to flash the fone now million times still get the same error message.
the phone turns on by itself and i get the error message.
i know there are 2 different files in the fone but how can i rectify the problem the crap fone always turns on and how do i write the eprom and with which file as mentioned earlier.
thanks
jab
Old 01-05-2006, 20:59   #7 (permalink)
Member: 199327
Which version of SEMC Tool are you using? just use an older version and it will work like a charm! I got this same error with W800i and K700i when I used SEMC Tool v5.5 but when I used the older version of SEMC Tool v5.1, it was perfect and without any problems!
Old 01-05-2006, 21:41   #8 (permalink)
Member: 99581
THERE SHOULD BE EASY WAY FOR UNDERSTANDING ERROR ON" USB SMART" FOR NOVICE OR AVRAGE USER .
ERROR 304100 :- WHAT WILL AVERAGE USER CAN UNDERSTAND ???
IF SHOWS ERROR ALONG WITH DESCRIPTION EASYER FOR USER .
1. ERROR 304100 :- CID mismatch.
2. ERROR: 304107 & ERROR: 304106 :- Recover Certificate Problems
3. ERROR: 00A405 :- communication/timers problem check that the cable is working
IS THESE DESCRIPTION TOO HARD TO IMPLIMENT ON USE-SMART ??
Old 01-08-2006, 15:24   #9 (permalink)
jab
Member: 12386
hi all,
thanks everyone problem solved. at last....
thanks
jab
Old 01-14-2006, 16:10   #10 (permalink)
Member: 10228
Originally Posted by jab
hi all,
thanks
jab
How did you do?
/returburk
Old 01-16-2006, 18:58   #11 (permalink)
jab
Member: 12386
Wink
hi there,
first of all i recoverd certificate by put in a tick in the box.
then i flashed the whole phone by putting all 3 flashes and complete phone.
hope that helps if not flas the phone with k700 eprom fix file.
if you dont have ask man gladly help anyone if we can.
everyone keep this support going.
teaching and learning a great thing
thanks
jab
why usb smart very bad in flashing k700 gsm4libya SonyEricsson (USB-Smart) 33 02-28-2006 09:46
i have thise error mr TsT please help gsm4libya TST Dongle 4 10-14-2005 13:14
k700 error in flashing jln310 SonyEricsson (USB-Smart) 0 10-07-2005 05:23
why...why....why....always error in update. j2000 Phoenix Black Box 2 06-18-2005 21:52
i need help for thise error gsm4libya Nokia Hardware & Hardware-Repair Area 5 04-09-2005 08:38
Page generated in 0.81511 seconds with 11 queries
