06-29-2006, 13:02 | #1 (permalink) |
No Life Poster Join Date: Sep 2003 Age: 43
Member: 39948 Status: Offline Thanks Meter: 68 | K750 R1CA021 cannot complete phone after downgrade to R1BC002. Switch phone ON Get phone info Flash CID: 49 Phone KEY: A1_DB2010_49_RED OTP CID: 49 Phone IMEI: 359672002xxxxx Flash ID: 200D Switch phone ON Write Flashloader CID49 Waiting to finish Switch phone ON Start Flashloader CID49 Reading flash CXC version Version: R1BC002_CXC125954_CHINA_CL Send FLASH application Recover first flash part Send FS application ERROR: 303041 I try many time to complete phone always show error 303041. I'm using semc v8.6 try semc 8.5 and 8.2 same result. please help me. thanks. |
06-29-2006, 13:32 | #3 (permalink) |
Member: 39948 Status: Offline Thanks Meter: 68 | im did flash it with correct main + fs. my phone brand new. just want to change language. the phone is still alive. but had configuration error. Just need complete phone only. |
06-30-2006, 19:44 | #6 (permalink) |
Insane Poster Join Date: Dec 2002 Age: 57
Member: 19110 Status: Offline Thanks Meter: 0 | I have same problem. Sound dissapered after unlock K750 CID 49 R1C. Tried to flash with R1B and gave error 303041. Now display show Configuration error. Get phone info Flash CID: 49 Phone KEY: A1_DB2010_49_RED OTP CID: 49 Phone IMEI: 359672002xxxxx Flash ID: 200D Switch phone ON Write Flashloader CID49 Waiting to finish Switch phone ON Start Flashloader CID49 Send FLASH application Checking MAIN flash file Send MAIN flash file: "K750_R1BC002_ZONE1_STANDARD.mbc" MAIN flash sent OK Switch phone ON Send FLASH application Checking FS flash file Send FS flash file: "K750_R1BC002_EU1.fbc" FS flash sent OK Switch phone ON Get phone info Flash CID: 49 Phone KEY: A1_DB2010_49_RED OTP CID: 49 Phone IMEI: 359672002xxxxx Flash ID: 200D Switch phone ON Write Flashloader CID49 Waiting to finish Switch phone ON Start Flashloader CID49 Reading flash CXC version Version: R1BC002_CXC125952_EU_1_CL Send FLASH application Recover first flash part Send FS application ERROR: 303041 |
07-01-2006, 15:09 | #7 (permalink) |
Member: 39948 Status: Offline Thanks Meter: 68 | my problem solve with MTBOX SE Trial. To ZULEA. Right now already two people gor this problem. please upload R1CA021 firmware. my friend want buy this USB_SMART 3 Pcs. If this problem didnt solve with USB Smart. I will tell my friend to not buy this product. n I will Upgrade my MTBOX SE To Full. |
07-02-2006, 17:52 | #10 (permalink) | |
No Life Poster Join Date: Sep 2000 Location: UK York Age: 56
Member: 2008 Status: Offline Thanks Meter: 4 | Quote:
No Problems here Just Downflashed 10 x K750i R1C021 Branded Virgin TO R1BC002 with no problems at all Try "to Complete phone" with no other options ticked. Regards Charlie | |
07-03-2006, 10:27 | #13 (permalink) | |
Junior Member Join Date: Oct 2003
Member: 41808 Status: Offline Thanks Meter: 0 | Quote:
07-03-2006, 15:13 | #14 (permalink) |
No Life Poster Join Date: Jan 2005 Location: GSM world Age: 49
Member: 111249 Status: Offline Thanks Meter: 531 | @Shmel1972, ok if u have a problem dowgrading it just flash the phone with the same files... If u cant get the files check on www.topsony.com BR |
08-09-2006, 10:51 | #15 (permalink) | |
Junior Member Join Date: Aug 2003 Age: 45
Member: 37991 Status: Offline Thanks Meter: 0 | Quote:
It exists some thing that it is necessary to know: 1 - you have to have installed the Drives USBFlash to use the cable DCU60. Select and Download the firmware for the K750i from "Flash Files" tab in davinci. Mark Download MAIN and FS option there and click on Get files. 2 - to open Davinci 16.4, introduce the files MAIN and FS, and press "Flash." DON'T MARK THE OPTION FINALIZATION. When finishes writing the files MAIN and FS, closing the program Davinci. Decompress the file custom.rar(download it from www.topsony.com) and save inside the same directory of the program FarManage. And must edit your CID number and version in customize.xml file. Open Far Manage: 1 - Execute the command (Alt + the key F1 / Alt + the key F2) - a new window will Appear, "SEFP" press. 2- Select the cable, speed, and I model of telephone, "Enter press The Matrix" 3- Press the button "C" and connect the cable to the telephone. 4- Press FS 5- Select the directory / tpa/preset/system/custom/ 6- Select the directory "custom" in C:\Files Programs\Far\custom. 7- Select all the files with the right button of the mouse, click file for file (the selected files will be in yellow) or use the command Ctrl+, later press in "Copy" 8- Confirm the operation, press in "Copy" 9- Once ended the process of copy of the files, is necessary to finish the operation loading CSFS (SHUTDOWN CSFS loader). The square of I dialogue "Shoutown" will appear when you ascend for folder root FS: for this it is necessary to go pressed in the two "points" that appear up of everything in the left field. When the message appears: "Do you wish to SHUTDOWN CSFS loader?" "Yes" press. Now restart your phone and enjoy. | |
K750 CID49 Cannot Complete!? | ecsike | SonyEricsson (USB-Smart) | 8 | 07-17-2006 15:07 |
K750i CID49 cannot complete phone | Felix_Ponsel | SonyEricsson (USB-Smart) | 17 | 05-14-2006 06:10 |
W550 cannot complete phone aftre flash | VIZER | SonyEricsson (USB-Smart) | 13 | 03-30-2006 15:47 |
After using flux to reheat pcb, must i clean the pcb??i cannot flash phone after that | smartfone | Nokia Hardware & Hardware Repair | 9 | 08-13-2005 14:17 |
