Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > USB-Smart > SonyEricsson (USB-Smart)
Old 08-10-2006, 17:05   #1 (permalink)
Member: 136598
k750i CID 36 Flashign error help
hi, had this phone was completly fine thought id put w800i software on it, the main flash went smooth but failed on FS flash and now i can flash FS or read FS
Switch phone ON
Get phone info
Flash CID: 36
Phone KEY: A1_DB2010_36_RED
OTP CID: 36
Phone IMEI: 35655200711678
Flash ID: 200D
Switch phone ON
Send FLASH application
Switch phone ON
ERROR: 300401
i can flash main again
Old 08-10-2006, 17:08   #2 (permalink)
Member: 136598
weird? cleaerd up problem by using versin 8.6 instead of 8.7
Old 08-13-2006, 17:51   #3 (permalink)
Member: 252244
that was exacly my problems 2 for 1 minutes ago. I tried to open the repair tab. then check rebuild sp area and remake crc's.
When its done you can try to flash again. I hope i help you out
// sean (bad gramar :P)
Old 08-14-2006, 10:43   #4 (permalink)
Member: 218192
try erom file..........
Old 08-14-2006, 11:07   #5 (permalink)
fingusio's Avatar
Member: 16927
Sonork: 100.1592866
Use Semc Tool v8.6. V8.7 have bugs.
br,
fingusio
Old 08-15-2006, 18:40   #6 (permalink)
zaccoyne's Avatar
Member: 64381
use v8.6 just had same p;roblm and it workerd
Old 08-18-2006, 06:57   #7 (permalink)
yoya's Avatar
Member: 80255
I have same problem but error 300392, cant do anny anny operation, unlock, repair crc, flash, write gdfs, alwais error 300392, but phone is alive.
Old 08-20-2006, 18:47   #8 (permalink)
popzoran's Avatar
Member: 91406
Switch phone ON
Get phone info
Flash CID: 36
OTP CID: 36
Flash ID: 200D
Switch phone ON
Switch phone ON
ERROR: 300401
And I was having same prob with V8.7 and solved with V8.6
solution is 100%
Old 08-20-2006, 19:05   #9 (permalink)
gprsman's Avatar
Member: 217461
solution is 100%
I have flashad k750 cid 49 con semc tool 86 and 87 100% flashed
I'have problem radio after write gdfs
k750i cid 36 Could not start GDFS service how can i fix pearsonjohnboy Cruiser Suite 3 08-09-2006 05:22
k750I CID 36 Shoja Cruiser Suite 4 07-14-2006 20:30
k750i cid 36 mecca SonyEricsson (USB-Smart) 0 05-25-2006 22:58
any body have gdfs k750i cid 36 BROWN semo HWK 8 02-18-2006 11:23
Page generated in 0.41261 seconds with 11 queries
