04-03-2006, 22:28 | #1 (permalink) |
Freak Poster Join Date: Oct 2005
Member: 191662 Status: Offline Thanks Meter: 2 | Need help with TP- First time at carrying out TP I am wearing rubber soled ***** and i manually handle and use a needle to ground tp but no sucsess???????? Any help will be aprechiated.........its my first attempt at testpoint Last edited by shahzad9; 04-03-2006 at 23:11. |
04-03-2006, 23:09 | #4 (permalink) | |
Member: 191662 Status: Offline Thanks Meter: 2 | Quote:
04-03-2006, 23:15 | #5 (permalink) |
No Life Poster Join Date: Jan 2005 Age: 50
Member: 104911 Status: Offline Thanks Meter: 42 | the easiest way to do all testpoints, motorolas,ericssons etc is to use a power supply to power the phone and connect a probe to the neg and use that for the doing the testpoint. i've done 100's without one single problem. soldering wires is asking for trouble. br |
04-03-2006, 23:24 | #6 (permalink) | |
04-03-2006, 23:36 | #8 (permalink) | |
04-03-2006, 23:43 | #10 (permalink) | |
04-03-2006, 23:56 | #12 (permalink) | |
04-04-2006, 00:05 | #13 (permalink) |
Member: 104911 Status: Offline Thanks Meter: 42 | you do not have to use a power supply but its easier with, and i already had one which i made. the cables are just normal 4mm cables with banana plugs, then get some ic clips from rs/farnell/maplin etc and any test probe. |
1st time with uid need help with 6300 pls | mtb116 | UID - Box | 13 | 09-20-2007 07:52 |
Need help with Motorola K1 , schema for magic TP ? | pali | Motorola P2k | 1 | 05-26-2007 17:57 |
need your help for the first time since the purchase | SALNAI | SAGEM JTAG UNLOCKER | 11 | 08-02-2006 22:37 |
Need help with S65 TP, what diode to use. | cubafreak | S-Gold Based Phones | 5 | 03-02-2006 16:09 |
