Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > USB-Smart > SonyEricsson (USB-Smart)
Old 08-21-2006, 15:48   #1 (permalink)
Member: 163019
PLEASE HELP,VERY STRANGE PROBLEM ON TWO K750is
I have two K750s,they are both showing wjite screens.
I have flashed both with these flashes below,they flash properly but do not complete properly.
They do not do FS.
They are both cid36.
MAIN: K750_R1N035_CID36_FullRepairFlash.mbn
FS:K750_R1N035_EMEA6.fbn.
After flashing,they give error.Check log below:
Recover certificate
Switch phone ON
Switch phone ON
Get phone info
Flash CID: 36
Phone KEY: A1_DB2010_36_RED
OTP CID: 36
Phone IMEI: 35655100209017
Flash ID: 200D
Switch phone ON
Send FLASH application
Checking MAIN flash file
Send MAIN flash file: "K750_R1N035_CID36_FullRepairFlash.mbn"
MAIN flash sent OK
Checking FS flash file
Send FS flash file: "K750_R1N035_EMEA6.fbn"
FS flash sent OK
Switch phone ON
Get phone info
Flash CID: 36
OTP CID: 36
Flash ID: 200D
Switch phone ON
Send FS application
Start FS services
ERROR: 303105
Kindly assist as i need to have these phones working.
Old 08-21-2006, 16:00   #2 (permalink)
MadMax71's Avatar
Member: 194949
Here is guide how to full repair K750
Usualy with this procedure can be solved ANY software problems
(dead, Please Wait, ...)
1. - Use Test Point - NOT Checked
- Skip TP when flash MAIN, FS - NOT Checked
- Complete phone after flash - Checked
- Recover Certificate - Checked
- Flash K750_R1N035_CID36_FullRepairFlash.mbn as MAIN file
2. - Use Test Point - NOT Checked
- On Repair tab mark Rebuild SP Area and Remake CRC's
- Do Selected Jobs
- Connect/disconnect Test Point on phone when software ask
3. - Use Test Point - NOT Checked
- On Unlock tab mark Clear SP Locks
- Do Selected Jobs
If you want to use fullrepairflash then there is no need to flash fs, or just choose the correct main file!
Old 08-21-2006, 21:07   #3 (permalink)
irfanamin2's Avatar
Member: 82423
Try to Flash "MAIN" File (K750_R1N035_CID36_FullRepairFlash.mbn) + Complete phone.
Br.
Old 08-21-2006, 23:19   #4 (permalink)
Moderator
Chris02's Avatar
Member: 41076
Just Flash EROM brown and try to complete your phone again!
Old 08-22-2006, 07:55   #5 (permalink)
The SAINT®'s Avatar
Member: 111249
It should b EROM_CID36_RED, if I m not wrong. Just flash this file n after that complete phone.
Old 08-22-2006, 08:35   #6 (permalink)
manni_124's Avatar
Member: 203028
u do flash write mcu + fs and complete phone
Old 08-22-2006, 12:03   #7 (permalink)
Member: 7575
Flash latest software, you have new LCD type. It'll work with R1BC002 and higher.
Please help with strange problem mikerooney Genie Universal 4 01-24-2009 04:20
UB Team please help with strange problem mikerooney Universalbox 0 01-16-2009 00:20
PLEASE HELP,VERY STRANGE PROBLEM ON TWO K750is AbdulKadir SonyEricsson (USB-Smart) 2 08-21-2006 21:06
Very Very Strange Problem On Be4 Pandemonio100 Alcatel & TCL Old Models 1 06-25-2002 20:00
Please help me. Strange problem Siemens man Alcatel & TCL Old Models 0 11-26-2001 20:26
Page generated in 0.28277 seconds with 11 queries
