11-22-2005, 11:46 | #1 (permalink) |
Junior Member Join Date: Nov 2005
Member: 201810 Status: Offline Thanks Meter: 0 | @Zulea help for com port I received USB Smart with 4in1 cable. I install correctly drivers for both but when i open SEMC and select 4in1 cable with its com port software tells me that cannot open com port!!! At home i have amd 64 with Windows XP SP2 I try in office with another pc with Athlon xp and Windows XP Sp2 and same kind of errors... Then i try other pc with AMD Sempron and Windows me and everything seems to be ok...(now i must try to unlock) I would like to use it with my pc (AMD 64 one) is it a problem of compatibility or i do something wrong?? Thanks a lot |
11-22-2005, 11:53 | #2 (permalink) | |
Freak Poster Join Date: Jul 2005 Age: 51
Member: 161012 Status: Offline Thanks Meter: 1 | Comm Port Quote:
11-22-2005, 12:56 | #4 (permalink) |
No Life Poster Join Date: Apr 2005 Location: not fixed yet
Member: 138305 Status: Offline Thanks Meter: 2 | @Andreino real problem is that Your system can manage more VIRTUAL port then com 1 to 4 . Go in System Resources and check "Comm Port" setting . From there You can see which is exactly number assigned . This number can be between 40 and 60 too. |
11-22-2005, 13:16 | #5 (permalink) |
Member: 201810 Status: Offline Thanks Meter: 0 | Thanks So you mean to see which number of com port is assigned to cruiser cable??If yes i did it. If no what else can i do?? I try to unlock a K608 on pc with Windows ME and everything ok...so the cable and USB Smart are ok...but unfortunately my pc has....problem |
