Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | .: Nokia Unlock :. | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| Banned ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jun 2006 Location: Z-LanD
Member: 294953 Status: Offline Sonork: 100.1576570 Thanks: 1
| Usb Smart and Error book hey zulea u must post here all error and what does them mean always i get errors and i don't know what is it then post all Error 30XXXX = ?????????? error 4100XX = ?????????? error XXXXX = ??????????? error XXXXX = ??????????? error XXXXX = ??????????? error XXXXX = ??????????? ........ whare the support man????!!!!!! |
| | #2 (permalink) | |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Aug 2006 Location: Phils
Member: 331390 Status: Offline Thanks: 1,613
| Quote:
ERROR: 303106: You have different flash files versions…Correct this little mistake and try again --------------- ERROR: 30353B: You have tried to flash the three flash files (Main, Fs, Sfa). Flash only= TWO flash files and later if you want you can flash Sfa file in the phone only. --------------- ERROR: 300314: This Error is appears when you have a V600(maybe any phone) with CID’s mismatch. Flash Erom with CID36 from support area for that phone. Also as a suggestion flash with main and fs file after Erom for better result. --------------- ERROR: 003608, ERROR: 00360C & ERROR: 00360C: This errors where showed when the phone had the RSA killed by Twister or Terminator --------------- ERROR: 304314: This error appears when you are using flash files with CID lower than in OTP. You must use equal or higher. --------------- ERROR: 0001A1: Possibly problem due to cable with bad connection. Check the cable or buy a new one --------------- ERROR: 00A405: This problem happens when you have communication/timers problem check that the cable is working and post a thread telling the exactly error if still happening. Problem related to T100. It’s impossible to clear SP locks in this phone. --------------- ERROR: 300301: Bug found in v1.1 in Sony Ericsson z1010, support with CID16. Problem already solved --------------- ERROR: 304107 & ERROR: 304106: Recover Certificate Problems --------------- ERROR: 303002: This problem appeared when you are trying to Complete the phone alter flash. This error should be already solved. Occurred in v1.7 --------------- ERROR: 304100: This error appears when we are trying to flash a phone that’s empty. This will be solved in a short period of time. In Z1010 phones with CID16 we had this bug corrected already in v1.9 --------------- ERROR: 302403: This was a bug corrected in v3.1 so if you have seen this error download last exe. Also this error appeared in v2.0 reading flash files bug was fixed --------------- ERROR: 300314: Problem when trying to unlock V600 in v1.7/1.9 fixed on newer versions. --------------- ERROR: 003612: Use another cable T28 com cable doesn’t work in AVR phones --------------- ERROR NETWORK CONTACT: You have to Complete phone --------------- ERROR 304100 :- WHAT WILL AVERAGE USER CAN UNDERSTAND ??? IF SHOWS ERROR ALONG WITH DESCRIPTION EASYER FOR USER . 1. ERROR 304100 :- CID mismatch. 2. ERROR: 304107 & ERROR: 304106 :- Recover Certificate Problems 3. ERROR: 00A405 :- communication/timers problem check that the cable is working IS THESE DESCRIPTION TOO HARD TO IMPLIMENT ON USE-SMART P.S. next time use the seach button before you blame someone. BR, | |
| | #7 (permalink) | |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Feb 2005 Location: HOME OF PEACE Age: 39
Member: 113732 Status: Offline Thanks: 39
| Quote:
A also request the USB-smart Team to put this thread on top & rename it as ALL ERROR QUESTIONS SHOULD BE POSTED HERE. Let start with ERROR 305016 WORKING ON DEAD k700I ERROR 302238 WORKING ON DEAD K700I ALSO For More Infor refer to error on every set Also on ERROR: 303106, which means having different flash files. What happens when it appears in a situation where the flashfiles are not different? | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Panasolar, JAF, JAFWM, Smart Clip, Usb Smart and more | gsm-traders | Main Sales Section | 0 | 04-29-2006 01:35 |
| usb smart and errors | google_uk | SonyEricsson (USB-Smart) | 3 | 04-17-2006 04:02 |
| Usb-Smart cid49 for 49 eur , updates on usb-smart and others !!! | OvidelGSM | Main Sales Section | 0 | 04-15-2006 11:49 |
| Solve some USB-Smart dongle error problems | zulea | Dongle Problems (USB-Smart) | 0 | 04-02-2006 23:49 |
| Usb smart install error, Help pls "zulea" | mobitek | SonyEricsson (USB-Smart) | 3 | 10-26-2005 11:45 |
