03-15-2006, 01:11 | #1 (permalink) |
No Life Poster Join Date: Oct 2002 Location: Shenzhen China Age: 68
Member: 16350 Status: Offline Sonork: 110823 Thanks Meter: 42 | v600i flash problem Switch phone ON Get phone info Flash CID: 36 Phone KEY: A1_DB2000_36_RED OTP CID: 36 Phone IMEI: 35683000081802 Flash ID: 200D Switch phone ON Send FLASH application Read MAIN to file: "v600i vodafone cid 36 red.mbn" ERROR: 302416 On the already flashed one i have write K600_EROM_CID36.mbn flashed 100%, K608_EEPROM_FlashArea.mbn flashed 100%, K608_EROM_CID37_BROWN.mbn flashed 100%. Also i have done certificat recovery ok and repair function all ok. but i canot flash it.. and here is what soft say after 80% flash Switch phone ON Get phone info Flash CID: 36 Phone KEY: A1_DB2000_36_RED OTP CID: 36 Phone IMEI: 35683000081700 Flash ID: 200D Switch phone ON Send FLASH application Send MAIN flash file: "K600_ZONE1_STANDARD_R2J005_IMEI.mbn" ERROR: 30223B I use 4in1 cable and Dss-25 interface..same problem. tryed on 2computers one AMd and one Celeron direct on usb and also using alimented USB Hub, with 2 bateries full charged and also using external 4.5 v laboratory stabilised power suply.. So what should i do??? BR Last edited by opo; 03-15-2006 at 01:45. |
03-15-2006, 02:00 | #2 (permalink) |
Member: 16350 Status: Offline Sonork: 110823 Thanks Meter: 42 | And one more thing..the speed for flashing... very bad. I chose 920 000 and it flash same speed as chosing 115200...Why?? Already it makes mistake for flashing ...but wayt 80% is like one hour..so i canot test to many posibilities in one day..where can i choose real speed as chosing in Bauderate buton is just formal.. |
03-15-2006, 10:13 | #3 (permalink) |
Freak Poster Join Date: Aug 2005 Age: 59
Member: 166618 Status: Offline Thanks Meter: 2 | which version of USB-Smart do you use, seem that it isn't latest one, getting same problem with k608 and after updating program it worked fine, be sure that battery is charged, cable is ok, and set baudrate to 400000 not highest one, because new versions doesn't work with it, try also testpoint for the phone, shouldn't be one, because only CID49 is testpoint, but the v600 is a little suspect for me, i have got also one CID36 doesn't flash but while using testpoint work fine br |
03-15-2006, 12:08 | #4 (permalink) |
Member: 16350 Status: Offline Sonork: 110823 Thanks Meter: 42 | I have used last 6.6 version all the time I am very sory to say this ...but who does not have Cruiser..should buy one... cozz where usb-smart fail...cruiser helped me.. Phone is back alive |
03-15-2006, 13:53 | #5 (permalink) |
Member: 16350 Status: Offline Sonork: 110823 Thanks Meter: 42 | You canot say i am not objective.... I also tryed on second one...USB-smart kill this time 72% same error verry bad speed(have tryed all posibilities i think some bug here), Cruiser alive and flash at 420000 bauderate very quick.... Zulea since u r the programer..can u do some error table with what each error means??? BR |
03-16-2006, 00:51 | #7 (permalink) | ||
Member: 16350 Status: Offline Sonork: 110823 Thanks Meter: 42 | Quote:
E52 RM-469 Flashing problem.Flash ID not supported for this loader (RAPUv11_algo_xsr1 | rafik2533 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 04-04-2010 20:38 |
v600i flash problem!!! | samirr | Sony Ericsson | 4 | 12-28-2009 12:49 |
V600i FLASH PROBLEM!!! | denard | Cruiser Suite | 5 | 11-29-2008 16:39 |
v600i flash problems | khalid2001 | Cruiser Suite | 2 | 05-29-2006 09:38 |
V600i Flashing Problem | bono32 | Cruiser Suite | 0 | 02-23-2006 12:22 |
