Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > USB-Smart > SonyEricsson (USB-Smart)
Old 02-20-2006, 17:03   #1 (permalink)
Member: 234049
V808 to Z800 problem.Help!!!
Hi everyone!
I tried to flash a V802 to Z800 and it worked after i convert cid to cid36(erom cid 36)
After that i flashed phone with R1AB014 and it was completed fine but when i tried to start the phone it just says "please wait".
Tried everything but doesnt work,my phone worked fine before,so its not a hardware problem. What shoul i do???
Old 02-20-2006, 18:11   #2 (permalink)
EIGY's Avatar
Member: 68075
Flash Again and Writh GDFS!
Then Unlock!
If, You buckup flash file.
Flash before firmware!
B.R.
EIGY.
PS:日本人なのに安いソフト使うから!
エスイツール使えば問題解決!
Old 02-20-2006, 19:26   #3 (permalink)
Member: 234049
It doesnt work
PS:日本人じゃない。。。エスイツールって???
Old 02-20-2006, 23:09   #4 (permalink)
Member: 234049
Solved by this method:
1. Flash Z800_R1AB013_CID36_FullRepairFlash.mbn with Recovery and Complete checked
2. Repair -> Rebuild SP Area
But my phone cant find any network.......
Old 02-21-2006, 08:09   #5 (permalink)
Member: 150697
Originally Posted by niftymanjp
It doesnt work
このフォーラムは英語でしか話さないようにしましょう。  多分「エスイ」と言うのは「安い」と打ちたかっ ただろう。
edit: 間違った。。。エスイツールって。。。SETOOLと言うことだ!しかし、SETOOLでも、USBSMA RTでもV800/Z800ではなにも違うじゃない。ツールは結構同じだからさ。。。
Remember after flashing main to go to settings and select GSM for network.
Also, try flashing original Z800 GDFS now that the phone is a CID36 Z800.
I read somewhere that sometimes when going from V800/802 to Z800, that the RF calibration settings can become messed up.
Old 02-21-2006, 09:06   #6 (permalink)
shohag's Avatar
Member: 147116
Sonork: 100.1578260
do comptete phone after flash............
work 100%..............
Old 03-01-2006, 20:46   #7 (permalink)
Member: 234049
Thanks,i will try this.
Old 03-01-2006, 22:25   #8 (permalink)
garch's Avatar
Member: 138305
... and don't forget to "complete" (finalize) phone.
Old 03-02-2006, 03:44   #9 (permalink)
Member: 144445
i got the same problem with one of the V800/Z800, revived by Cruiser so if you have you may give it a try.
Old 03-03-2006, 12:35   #10 (permalink)
Member: 234049
I flashed original Z800 GDFS and completed the phone,but now when i put my SIM i have a message Insert correct Sim card....
Old 03-03-2006, 13:02   #11 (permalink)
Member: 234049
I have also noticed this:
Switch phone ON
Get phone info
Flash CID: 36
Phone KEY: A1_DB2000_36_RED
OTP CID: 29
Flash CID and OTP CID are diffrent, maybe this is the problem?
Old 03-03-2006, 17:16   #12 (permalink)
Member: 144445
press unlock may help?
Old 03-07-2006, 10:43   #13 (permalink)
Member: 234049
No it didnt,still Insert Correct SIM card,please help!
The Following User Says Thank You to niftymanjp For This Useful Post:
Old 03-07-2006, 17:04   #14 (permalink)
Member: 231995
USE SEMC Tool v3.3 then rebuild SP Area
That'S it!
Old 03-08-2006, 10:27   #15 (permalink)
Member: 234049
That'S it!
Hello,where can i get it,i found only Cracked ver.Thanks!
acount id problem.help uregent plz [SOLVED] dani2080 PolarBox 2 2 03-29-2010 12:46
Problems converting V800 to Z800 phone_abuser SonyEricsson (USB-Smart) 6 11-11-2005 18:04
Murphy problem with V800 to Z800, Server kills phones forhike TOTAL MultiServer 4 07-23-2005 05:00
V802 to Z800, Network Problem ... gwaai Cruiser Suite 10 06-14-2005 15:51
Help on V800 to Z800 franklee628 TOTAL MultiServer 9 04-20-2005 16:11
Page generated in 1.32815 seconds with 11 queries
