03-03-2006, 22:12 | #1 (permalink) |
No Life Poster Join Date: Feb 2006 Location: pakistan Age: 41
Member: 227726 Status: Offline Thanks Meter: 297 | w550 after unlock semc v6.5 dead Switch phone ON Get phone info Flash CID: 49 Phone KEY: A1_DB2010_49_RED OTP CID: 49 Phone IMEI: 35744200540491 Flash ID: 890D Switch phone ON Send FLASH application Send MAIN flash file: "W550_R4AB048_HONG_KONG.mbc" and measeag out of memory while expanding memory stream i try this way 1. - Use Test Point - Checked - Skip TP when flash MAIN, FS - NOT Checked - Complete phone after flash - NOT Checked - Recover Certificate - NOT Checked - Flash W550_EROM_CID49_RED.mbn as MAIN file - Connect/disconnect Test Point on phone when software ask 2. - Use Test Point - Checked - Skip TP when flash MAIN, FS - NOT Checked - Complete phone after flash - NOT Checked - Recover Certificate - NOT Checked - Flash (your choice) MAIN file from MAIN_IMEI directory - Connect/disconnect Test Point on phone when software ask 3. - Use Test Point - Checked - Skip TP when flash MAIN, FS - Checked - Complete phone after flash - NOT Checked - Recover Certificate - NOT Checked - Flash (your choice) FS file from FS directory - Not need to use Test Point on phone 4. - Use Test Point - Checked - Skip TP when flash MAIN, FS - NOT Checked - Complete phone after flash - NOT Checked - Recover Certificate - NOT Checked - Flash W550_EEPROM_Area_Flash.mbn as MAIN file - Connect/disconnect Test Point on phone when software ask 5. - Use Test Point - Checked - Skip TP when flash MAIN, FS - NOT Checked - Complete phone after flash - Checked - Recover Certificate - NOT Checked - Remove all filenames from MAIN and FS edit boxes - Connect/disconnect Test Point on phone when software ask 6. - Use Test Point - Checked - Skip TP when flash MAIN, FS - NOT Checked - On Repair tab mark Rebuild SP Area and Remake CRC's - Do Selected Jobs - Connect/disconnect Test Point on phone when software ask 7. - Use Test Point - Checked - Skip TP when flash MAIN, FS - NOT Checked - On Unlock tab mark Clear SP Locks - Do Selected Jobs - Connect/disconnect Test Point on phone when software ask but the same massage out of memory while expanding memory stream. plz help me what i do thanks in adv |
03-13-2006, 09:53 | #5 (permalink) |
Crazy Poster Join Date: Mar 2006
Member: 239849 Status: Offline Thanks Meter: 2 | now every time when i unlock phone i remine me to do read phone code or info first,because it will not to touch the flash chips,and it safety to do unlock...but some of the phone cannot read info or code so after that read is not success,you can do read code fisrt is better than you directly press unlock funtion key...sorry my english....hope help.. ps:when you have sucess read the phone code,you can press your phone left * * left,and release the lock by this press and lock code while you read from software. |
w550 after unlock semc v6.5 dead | masterspargo | Sony Ericsson | 0 | 03-03-2006 22:17 |
w550 after unlock semc v6.5 dead | masterspargo | SonyEricsson (USB-Smart) | 0 | 03-03-2006 22:11 |
NEC e338 is halfdead after unlock with crassy 5 | Irfangk786 | NEC | 3 | 05-30-2005 23:44 |
nec 338 hang after unlock with crassy 5.0 | fancyvpp | NEC | 5 | 05-25-2005 00:45 |
C65 dead after unlocking with sst 5.31 | rachelyna | S-Gold Based Phones | 9 | 05-05-2005 17:08 |
