08-03-2006, 13:10 | #1 (permalink) |
Registered User Join Date: Sep 2003 Location: Palestine Age: 50
Member: 39208 Status: Offline Thanks Meter: 152 | w550 white screen , pls help .. instruction : 1. - Use Test Point - Checked - Skip TP when flash MAIN, FS - NOT Checked - Complete phone after flash - NOT Checked - Recover Certificate - NOT Checked - Flash W550_EROM_CID49_RED.mbn as MAIN file - Connect/disconnect Test Point on phone when software ask usb-smart log Switch phone ON Send FLASH application Checking MAIN flash file Send MAIN flash file: "W550_EROM_CID49_RED.mbn" MAIN flash sent OK Operation succesfull result : white screen instruction 2 2. - Use Test Point - Checked - Skip TP when flash MAIN, FS - NOT Checked - Complete phone after flash - NOT Checked - Recover Certificate - NOT Checked - Flash (your choice) MAIN file from MAIN_IMEI directory - Connect/disconnect Test Point on phone when software ask usb-smart log: Switch phone ON Send FLASH application Checking MAIN flash file Send MAIN flash file: "W550_R4CB020_ZONE1_STANDARD.mbc" MAIN flash sent OK Operation succesfull result: hangs on white screen instruction 3 3. - Use Test Point - Checked - Skip TP when flash MAIN, FS - Checked - Complete phone after flash - NOT Checked - Recover Certificate - NOT Checked - Flash (your choice) FS file from FS directory - Not need to use Test Point on phone usb-smart log: usb-smart log Switch phone ON Send FLASH application Switch phone ON Send FLASH application Checking FS flash file Send FS flash file: "W550_R4CB020_EMEA6.fbc" ERROR: 30223A "stops at 41% i repeat this 3 times " result: white screen instruction 4: 4. - Use Test Point - Checked - Skip TP when flash MAIN, FS - NOT Checked - Complete phone after flash - NOT Checked - Recover Certificate - NOT Checked - Flash W550_EEPROM_Area_Flash.mbn as MAIN file - Connect/disconnect Test Point on phone when software ask usb-smart log: Switch phone ON Send FLASH application Checking MAIN flash file Send MAIN flash file: "W550_EEPROM_Area_Flash.mbn" MAIN flash sent OK Operation succesfull result: white screen instruction 5: 5. - Use Test Point - Checked - Skip TP when flash MAIN, FS - NOT Checked - Complete phone after flash - Checked - Recover Certificate - NOT Checked - Remove all filenames from MAIN and FS edit boxes - Connect/disconnect Test Point on phone when software ask usb-smart log: Switch phone ON Get phone info Flash CID (TP): 29 Phone KEY (TP): TEST_POINT OTP CID (TP): 29 Send FS application Start FS services ERROR: 303105 result white screen: instruction 6: 6. - Use Test Point - Checked - Skip TP when flash MAIN, FS - NOT Checked - On Repair tab mark Rebuild SP Area and Remake CRC's - Do Selected Jobs - Connect/disconnect Test Point on phone when software ask usb-smart log: Switch phone ON Get phone info Flash CID (TP): 29 Phone KEY (TP): TEST_POINT OTP CID: 49 Phone IMEI: 35744200156010 Flash ID: 200D Switch phone ON Send GDFS application Rebuild SP area and CRCs Operation succesfull result: white screen instruction 7 : 7. - Use Test Point - Checked - Skip TP when flash MAIN, FS - NOT Checked - On Unlock tab mark Clear SP Locks - Do Selected Jobs - Connect/disconnect Test Point on phone when software ask usb-smart log: Switch phone ON Get phone info Flash CID: 29 Phone KEY: TEST_POINT OTP CID: 49 Phone IMEI: 35744200156010 Flash ID: 200D Operation succesfull result : still white screen pls help |
MyPhone T22 Duo white screen, pls help | kolz07 | Infinity-Box | 1 | 12-15-2008 19:40 |
another ways n70 white screen pls help | markrhi | Nokia Hardware & Hardware Repair | 7 | 07-05-2007 15:00 |
NK 7610 white screen pls help | sun-day | Nokia Hardware & Hardware Repair | 2 | 06-07-2007 15:50 |
W550.. White screen.. need help please | bakhshalvi007 | Universalbox | 7 | 12-01-2006 21:57 |
