Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Feb 2006 Location: Hong Kong Age: 34
Member: 229358 Status: Offline Thanks: 77
| what't happen about w810 unlock ? now my w810 can't power on !! when i unlock w810i , show error below : Switch phone ON Get phone info Flash CID: 49 Phone KEY: A1_DB2010_49_RED OTP CID: 49 Phone IMEI: 35906xxxxxxxxx Flash ID: 2019 Switch phone ON Write Flashloader CID49 Waiting to finish Switch phone ON Start Flashloader CID49 Send FLASH application Write GDFS Flashloader Switch phone ON Start GDFS Flashloader ERROR: 305328 |
| | #7 (permalink) |
| Crazy Poster ![]() ![]() ![]() Join Date: Aug 2005 Age: 53
Member: 170987 Status: Offline Thanks: 0
| problem with w810 make sure battery is fully charged and you use latest version today is v85 then select correct com if using cruiser select cruiser cable and check what com is being used by it then connect phone and 9 volt battery which should be fully charged or new to cable then plug to phone and without battery click on do jos what ever it is you wanna do then insert battery if still not see phone clean or replace charging block as some get contaminated and need changing.i did 2 today . |
| | #8 (permalink) | |
| Cheater -Don't Deal with him- ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2002 Age: 37
Member: 8879 Status: Offline Sonork: 100.84016 Thanks: 22
| Quote:
works fine mate, done lots of these already! | |
| | #9 (permalink) | |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Feb 2006 Location: Inside Your Mind
Member: 229854 Status: Offline Thanks: 0
| Quote:
Regards BladeGsm | |
| | #10 (permalink) | |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2005 Location: GSM world Age: 38
Member: 111249 Status: Offline Thanks: 12
| Quote:
BR | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| 3110c with power supply, power on is ok. but with battery can't power on. | unnang | Nokia Hardware & Hardware-Repair Area | 16 | 02-10-2013 12:28 |
| 1200/1208 power on in fbus cable but can't power on in battery solution here | joauz | Nokia Hardware & Hardware-Repair Area | 6 | 12-17-2008 05:29 |
| HELP, My LG KE850(*****) can't power on! | eminem198123 | LG | 1 | 12-08-2008 10:08 |
| N-GAGE QD Can't power on whit batt,With UFS power on oke... | Mr.XXX | Nokia Hardware & Hardware-Repair Area | 2 | 07-18-2006 16:38 |
| A35 after unlock can't power on | acyl2000 | x1x to x45/x50 | 6 | 01-07-2002 14:09 |
