Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > USB-Smart > SonyEricsson (USB-Smart)
Old 04-26-2006, 16:29   #1 (permalink)
Crazy Poster
Member: 170471
where can I find k608 flash files for usbsmart
k600 flash files will not do unless someones knows how to rewrite the phone model to k608i instead of k600i
Old 04-26-2006, 18:52   #2 (permalink)
Member: 231052
Thanks Meter: 17
use the files from k600, it is the same phone!
Old 04-26-2006, 20:18   #3 (permalink)
Crazy Poster
Member: 170471
I'll repeat, where can I find k608 flash files, unless someone knows how to change the phone model from k600i to k608i
Old 04-26-2006, 22:14   #4 (permalink)
phone_abuser's Avatar
Member: 58817
In usb-smart support site...download Usbsmart_Maintenance_v40 from homepage www.usb-smart.com and use with your dongle.
Use K600 main flash and FS-flash for your cid. Complete phone after flash. Fixed!
If you dont have one, dont bother because you cant use cracked version for your phone(cid49)
Old 04-27-2006, 21:30   #5 (permalink)
Crazy Poster
Member: 170471
where can i find k608 flash files, they are not on the support site ftp, i have checked, it just has a text saying use k600 files.
flashing k600i files does not allow me to repair the phone model name to k608i.
How can I change the phone model name back to k608i
15-Dec-2005:
K608 Full Repair files
K608_CID37_R2F015_FullRepairFlash.zip
K608_CID49_R2F015_FullRepairFlash.zip
the above files are not there.
I need to turn this phone back into a k608, the operator it is used on does not support the k600, only the k608
Old 04-28-2006, 00:53   #6 (permalink)
agent003's Avatar
Member: 19094
Thanks Meter: 3
ummm....I cant see a reason for it.....these are exactly the same phones...
Anyway.... I still have r2j005 files if its that important to you....but ill only be able to upload over the week end if you dont get them by then..
Old 05-01-2006, 10:42   #7 (permalink)
Crazy Poster
Member: 170471
for warranty purposes I would like k608i as the phone model name, all i need is a way of changing the phone identifier from k600i to k608i
Old 05-01-2006, 10:47   #8 (permalink)
Member: 91799
Thanks Meter: 3
For warranty purposes you do need a lot more than just the name.
You also need original firmware and CDA, or EMMA would kick you in the a$$.
Old 05-01-2006, 14:03   #9 (permalink)
Crazy Poster
Member: 170471
usbsmart can do cda, i've found k608 firmware, i just cant get the phone model to change back to k608i from k600i
Old 05-01-2006, 14:07   #10 (permalink)
Stylo_GSM's Avatar
Member: 177235
Sonork: 111568
Thanks Meter: 138
what do u mean warrent purposes, well when u unlock the fone the warrenty is voided straight away.
Old 05-01-2006, 15:24   #11 (permalink)
Member: 229358
Thanks Meter: 12
try to write the k608 GDFS to phone !
Old 05-01-2006, 17:22   #12 (permalink)
Crazy Poster
Member: 170471
where can i find a k608 gdfs, there is not one on the ftp last time i checked.
just tried the k608i flash files on topsony.com, phone still says k600i as the phone model.
Old 05-02-2006, 20:23   #13 (permalink)
Crazy Poster
Member: 170471
Ok, wondering where I should post this...
I've got the k600i gdfs, what steps do I need to take to turn it into a k608i gdfs.
All i need changing is the phone model identifier and it's just one digit from k600 to k608, I've read of it being done with the v800 and z800 models.
All it should require is decompiling the gdfs, editing the relevant information and recompiling the gdfs, but I'm lost as to what I could use to do this.
Where can i find eno flash file for nokia n95 sunshinelin Cyclonebox 1 07-30-2009 21:18
where can i find arabic flash file for MOTOROLA C113??? tsarkh Motorola ODM 3 05-08-2007 09:39
where can I find w810 flash files for usbsmart ambt SonyEricsson (USB-Smart) 6 05-03-2006 07:23
where can i find/get flash files for sony t610? redmint UFS2 + UFS3-Tornadoflasher 1 09-24-2004 05:44
Where can i find a flex file for C330? turbo_slug Motorola P2k 0 08-04-2003 09:09
Page generated in 0.24687 seconds with 10 queries
