11-24-2005, 17:26 | #1 (permalink) |
Junior Member Join Date: Nov 2005
Member: 201810 Status: Offline Thanks Meter: 0 | Convert K608i to K600 which files?? Thanks a lot to everybody |
11-24-2005, 18:27 | #2 (permalink) |
Member: 201810 Status: Offline Thanks Meter: 0 | So using search options and looking in the support area i think these two files are the right ones K600_R1K001_EAL_ZONE1_STANDARD.mbn K600_R1K001_EAL_EU5.fbn So i flash with only these 2 files using testpoint and check option Complete phone to unlock it too... Everything is correct?? Thanks a lot |
11-24-2005, 23:42 | #7 (permalink) |
Freak Poster Join Date: Sep 2002 Age: 38
Member: 15999 Status: Offline Thanks Meter: 0 | no. you can flash this phone with these flashes (cid 36, yes?), but don't change erom. phone will be alive. i flashed my k608i (cid49) with all possibles flashes, and sometimes phone would not power on, but you can always back to original (backup eeprom. fs and main flash). i did not make backup and some time have problem with gdfs area, but flashfile from imei change solved my problem, so, all can be repaired btw, if you flash erom (for example cid37) it make any problem, because erom you must flash and unlock via testpoint. |
11-24-2005, 23:53 | #8 (permalink) |
Crazy Poster Join Date: Dec 2003 Location: Italy
Member: 45791 Status: Offline Thanks Meter: 0 | Great news kakrysa! And do you have infos about phones with Intel memory and glued TP? Someone tells that TP works removing glue and someone not... A found a phone where TP does't work (removing glue film)... maybe I make a mistake... |
11-25-2005, 10:37 | #9 (permalink) |
Member: 201810 Status: Offline Thanks Meter: 0 | So finally i can do flash with files that i write in post and only that but is better to do backup of eeprom. fs and main flash before flash.... How much is long all flash?? Thanks a lot |
11-29-2005, 11:57 | #10 (permalink) |
Member: 45791 Status: Offline Thanks Meter: 0 | If I try to backup I get: Switch phone ON Get phone info Flash CID (TP): 29 Phone KEY (TP): TEST_POINT OTP CID (TP): 29 Send FLASH application Read MAIN to file: "main.mbn" ERROR: 302616 |
01-10-2006, 14:25 | #11 (permalink) |
Freak Poster Join Date: Aug 2004 Age: 49
Member: 79152 Status: Offline Thanks Meter: 9 | Switch phone ON Get phone info Flash CID: 36 Phone KEY: A1_DB2010_36_BROWN OTP CID: 36 Phone IMEI: 35833900029234 Flash ID: 890D Switch phone ON Send FLASH application Read MAIN to file: "Z520i_main.mbn" ERROR: 302616 me too..... |
01-10-2006, 14:27 | #12 (permalink) |
Member: 79152 Status: Offline Thanks Meter: 9 | Z520i backup Switch phone ON Get phone info Flash CID: 36 Phone KEY: A1_DB2010_36_BROWN OTP CID: 36 Phone IMEI: 35833900029234 Flash ID: 890D Switch phone ON Send FLASH application Read MAIN to file: "Z520i_main.mbn" ERROR: 302616 me too..... |
Which Flash File to Convert K750i to W800i | spudpickermcfly | SonyEricsson (USB-Smart) | 5 | 05-23-2006 11:04 |
how to convert k608 to k600?~! | Gozha | SonyEricsson (USB-Smart) | 4 | 03-29-2006 07:48 |
How to convert binary to motorola S file record for LG flashing? | d_bug | LG | 2 | 12-08-2003 03:33 |
how to convert wav to poly midi files? | softis | GSM Programming & Reverse Engineering | 0 | 11-22-2003 15:05 |
