Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > USB-Smart > LG 3G (USB-Smart)
Old 03-07-2006, 23:27   #1 (permalink)
Member: 163974
lg 8330 USIM locked? help
Please tell me how unlock the phone. It was unlock to 8210 and I use it without any problems 9 months. Yesterday it’s hang up and says USIM locked. What to do? Please help me…
Old 03-08-2006, 08:49   #2 (permalink)
garch's Avatar
Member: 138305
You have problem with 8330 or 8210 ??
Old 03-08-2006, 16:34   #3 (permalink)
Member: 163974
I was wrong – it’s not unlocked to 8210, U8330 is unlock to 8130, because test menu is displayed when I input the service code for U8130 & U8138 : 47328545454#
Well I have problems with 8130, is it possible to unlock to original version u8330 without any hardware devises, only with USB cable? If not, I will be pleased and with 8130.
10x
[Factory version] is
U8330-V10a-Apr-2005-039-01-00-1010
[U8130-PLATFORM_VER.] is
V101_1022
[U8130_FLEX_FILE_VER.] is
039-H3G-FF101
[U8130_flex_gdfs_ver.] is
039-H3g-FG10a
IMEI: 356354-00-126834-2
Old 03-08-2006, 18:10   #4 (permalink)
garch's Avatar
Member: 138305
10x
V101_1022
039-H3G-FF101
039-H3g-FG10a
in the past some tools made the unlock by downgrading 8330 to 8130 with special firmware.now no more need this step.
if You have
8130 :
flash original firmware and make a read all network codes, then insert manually NCK code
8330 :
to make sure about firmware version flash orignial here too, then make fastUnlock
Old 03-08-2006, 18:31   #5 (permalink)
Member: 163974
if You have
8130 :
8330 :
garch,
I have lgu 8330, please tell me how to make original flash firmware (to do Factory Reset?) and fastUnlock? Can I make this only with software and USB cable?
Sorry man, I’m novice in gsm unlocking…
10x
Old 03-08-2006, 18:42   #6 (permalink)
garch's Avatar
Member: 138305
garch,
10x
np,
Batter cable You will need ( up to 921KBps ) is UC-10 or 4 in 1 both named Cruser cables, same drivers, different connectors, as Your choice.
Original firmware You will try in support area ( hope You know how to ... )
After download flash all files to phone.
for fastUnlock just press Unlock All Network Codes on LGTool software
Old 03-08-2006, 19:21   #7 (permalink)
Member: 163974
np,
Where is support area, I find files for flashing, guest is that LG-U8330_356354005730867_GDFS.rar from LG3G GDFS and Unlock Files, Download here but I haven’t a program to use this file LG-U8130_354931006674293_GDFS.gdfs. is that program LGTool software the same that is used for flashing the firmware? Can you give me a link to download LGTool software…
10x man for your responsivcness!
Old 03-08-2006, 20:40   #8 (permalink)
garch's Avatar
Member: 138305
If You have USBSmart You CAN access to support area, running the software You will try HERE and pressing on GO SUPPORT, on LG section dwnld LGTool and ,from there, choose firmware You need.
While You are going in support area take care to have USBSmart plugged-in Your PC
Start LGTool
Select model
Set Comm-Type
Select Flash
Select Firmware files
DO JOB
Help! LG u880 USIM locked After unlock Flash ATIEFUOR-GSM LG 6 03-15-2011 05:11
Lg U8120- Usim Locked raj_cxe LG 17 09-07-2010 13:10
lg ku990 usim locked???????? salsabil25 FuriouS TeaM Products 3 06-06-2008 16:11
Lg U880 Usim Locked dil_PAKISTANI ULT PRO 2 11-03-2007 19:05
LG U8120 usim locked help me. omersegev LG 3 09-30-2006 16:15
Page generated in 0.40190 seconds with 11 queries
