Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > USB-Smart > LG 3G (USB-Smart)
Old 03-13-2006, 16:07   #1 (permalink)
Member: 21937
U8330I still locked after direct unlock. ??
hi
got a U8330I (israel)
i do direct unlock with lgtool , usbsmart say all unlocked o.k , but usim still locked.
do i need to reset phone after ? or do i need testpoint for unlocking it ?
Old 03-13-2006, 21:01   #2 (permalink)
garch's Avatar
Member: 138305
Give a Read All Codes commands
Make Reset with 47328545454#
If You can change language, You may flash several firmware from support
Old 03-13-2006, 21:15   #3 (permalink)
Member: 21937
friend , i dont have read all codes option for this model
Old 03-13-2006, 22:21   #4 (permalink)
garch's Avatar
Member: 138305
Was not to see the codes, just to rewrite gdfs area.
Old 03-13-2006, 22:52   #5 (permalink)
Roni1976's Avatar
Member: 51403
I try naw to unlock this phone and reset 47328545454#
not work
Old 03-13-2006, 22:59   #6 (permalink)
oOXTCOo's Avatar
Member: 2878
just flash it and then unlock it again.
i have the same problem, but after this, it is unlocked.
Old 03-13-2006, 23:18   #7 (permalink)
Roni1976's Avatar
Member: 51403
ok but i need stay with hebrew,i dont whont flash
phone with another langech
Old 03-14-2006, 01:00   #8 (permalink)
garch's Avatar
Member: 138305
Try this :
read and save all 4 firmware files
flash with a firmware from support
make unlock
reflash the 4 files just readed.
Old 03-14-2006, 08:46   #9 (permalink)
Roni1976's Avatar
Member: 51403
Try this :
make unlock
ok man tnx i will try naw
Old 03-14-2006, 10:18   #10 (permalink)
Roni1976's Avatar
Member: 51403
@garch
I flash phone with U8330_v10A_Italy and he opened
when i flash back Hebrew it's stil Locked.
What we can do naw
Old 03-14-2006, 15:33   #11 (permalink)
garch's Avatar
Member: 138305
@garch
What we can do naw
are you shore phone was unlocked ?
normally to relock phone You need to re-write gdfs area and making a relock function, after that phone will be locked to the provider on first usim You will put on phone.
Old 03-14-2006, 18:53   #12 (permalink)
Member: 21937
this phone is original from orange .il .
after all testing as roni said , things are like that.
1.originl flash , direct unlock with usbsmart - phone still locked to orange .il
2.flashing with italy unlocked flash , reset phone . phone is unlocked np.
3.flashing back with original flash , phone locked again.
4.unlock phone with hwk and test point , then read info. phone say all locks are open , but when insert other then orange .il sim , phone still say usim locked.
please help us here guys , this phone from he;;
Old 03-14-2006, 19:36   #13 (permalink)
garch's Avatar
Member: 138305
Very strange phone Ser,
as I suppose You have v10a Israel inside phone, so no big difference between v10a Ita You flashed .
Not sure, but try to make a Read All Codes from v10a Israel and manually insert NCK.
Old 03-14-2006, 21:51   #14 (permalink)
Member: 21937
dear friend , there is no option in usbsmart read codes for this model
Old 03-14-2006, 22:14   #15 (permalink)
garch's Avatar
Member: 138305
Yes you reason, but after made Unlock
U900 still locked after direct unlock msa Easy-Unlocker 1 07-05-2008 02:00
u880 still lock after flasing unlock file dsakun899 ULT PRO 0 01-26-2008 21:15
k510i Still Locked after 3 unlock attempts mishaelwillo Cruiser Suite 8 10-18-2007 08:37
myC4-2 still locked with direct unlock.... ZIYAAD STRYKER ARM9 BASED M62 / M62+ 3 06-29-2007 19:09
Sagem 920 still locked after valid unlock code. GSM_Kraker Infineon C16X M51 & ARM7 M52 BASED 0 10-27-2000 14:16
Page generated in 1.26824 seconds with 11 queries
