Unlock Server
Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > USB-Smart > Sharp 3G (USB-Smart)
Old 02-28-2006, 11:12   #1 (permalink)
Member: 238277
903 shutdown after flashed sh903_jap_nov
My 903sh(bought in UK,200512) was Flashed with SH903_v1181_JAPAN_NOV_Unlocked and unlocked using Sharp3G_Tool_v31/v42.
Now the 903 does startup, but on 'please wait' screen, it shutdown everytime.
How can I solve this problem? Somebody please!
Old 03-01-2006, 09:40   #2 (permalink)
Member: 150697
your phone is december right. only use NOV_unlocked if your phone was originally a Japanese 903. If your phone is originally a UK model, then please use sh903_japan_unlocked.
if your phone was originally a Japanese 903 (it has japanese on the keypad), then please follow these directions:
please put in the forum the first 9 digits of the IMEI number.
if the 7th-9th digits are 000, then you are ok and we must figure out why the phone won't turn on.
if the 7th-9th digits are 001, then you cannot unlock your phone. 001 phones are CID73 and are not unlockable at the moment.
Old 03-01-2006, 10:50   #3 (permalink)
Member: 238277
Thank you very much for your reply.
Yes, it is December's one and UK model.
Tried SH903_v1071_JAPAN_Unlocked via Sharp3G_Tool_v21/v31, but the phone didn't start up even using # + power on.
Will try SH903_v1071_JAPAN_Unlocked again via latest v43 and post the result.
I appreciate the help
Old 03-02-2006, 03:48   #4 (permalink)
Member: 144445
does 903 need to be unlocked after flashing? missing steps? just a guess.
Old 03-02-2006, 04:36   #5 (permalink)
TIENPHAT's Avatar
Member: 121801
after flash,please unlock,don't forget!
Old 03-02-2006, 04:50   #6 (permalink)
Member: 150697
use sh903_v1071_japan_unlocked.
use sharp tool v21 (pm me if you need it)
unlock after flash
DO NOT USE #+POWER
Old 03-02-2006, 12:17   #7 (permalink)
Member: 238277
unlock after flash
DO NOT USE #+POWER
Thanks all.
Tried sh903_v1071_japan_unlocked using sharp tool v21, then unlocked, my 903 doesn't start up even pushed power key over 30 sec.
Tried both phone type SH903_EU/SH903_JP, finished all OK but same result.
Only when flashed with SH903_v1181_JAPAN_NOV_Unlocked, the phone start up (shut down on please wait screen though).
What should I do next? Cheers.
Old 03-02-2006, 19:04   #8 (permalink)
Member: 150697
Thanks all.
thats very strange. put in another battery from a charged phone.
make sure SIM card is not inside during flashing.
what are you using for external power? don't say 9v
Old 03-02-2006, 23:52   #9 (permalink)
Member: 238277
Really strange. The battery is full charged, no sim inserted.
Used 3v and 9v alternately to find a solution.
What have I done for this phone....
Old 03-03-2006, 05:11   #10 (permalink)
hema's Avatar
Member: 19267
PLS help me also I ve same problem with SHARP SH703 some says its chinese others says euro, how do I know the difference and now phone re-boot when innitialising what do I do to normalise it...
regards
Old 03-06-2006, 20:45   #11 (permalink)
Member: 150697
post the first 10 digits of the imei number please
N95 vibrate then cutoff after flash [SOLVED - Thanks Crazy Ratata] jus_chillin Cyclonebox 19 03-29-2010 11:57
E63 after flash on light keyboard and shutdown freedomqn MXKEY Nokia Flasher and Unlocker (by Alim Hape) 2 04-17-2009 13:07
sharp 903 problem after flashing hridaya Cruiser Suite 6 12-11-2005 03:56
C25 - "wrong soft " and shutdown after 5 sec Name x1x to x45/x50 15 12-09-2000 19:24
Page generated in 0.63497 seconds with 11 queries
