Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > USB-Smart > Sharp 3G (USB-Smart)
Old 03-26-2006, 15:53   #1 (permalink)
Crazy Poster
Member: 186463
Unhappy 903sh-2006 was dead after unlock
i flash via TP my 903sh-2006 ok,but when i unlock via TP it appeared :Switch phone ON ...
Send application ...
ERROR 400113
or
Switch phone ON ...
ERROR 400114
or
Switch phone ON ...
ERROR 400110
or
Switch phone ON ...
ERROR 400115
my phone is now no power on,when i flashed it again it also displayed:
Switch phone ON ...
ERROR 400113
or
Switch phone ON ...
ERROR 400115
Can anyone help me please?????
Old 03-26-2006, 22:35   #2 (permalink)
Siemens man's Avatar
Member: 3925
hi guys
i hAve dead 903sh cid73 after unlock. my phone not turn on. now i can't connect to soft. help me. please help me. what is my problem. i'm use full charged battery.
thank you
Old 03-27-2006, 01:00   #3 (permalink)
chuckzster's Avatar
Member: 139924
just like my problem.....i just disaassemble the phone safely and the phone wont power on right now......
Old 03-27-2006, 01:03   #4 (permalink)
cavite_devil's Avatar
Member: 47271
ERROR 400113
or
Switch phone ON ...
ERROR 400114
or
Switch phone ON ...
ERROR 400110
or
Switch phone ON ...
ERROR 400115
Switch phone ON ...
ERROR 400113
or
Switch phone ON ...
ERROR 400115
Hi pls Check your TP Correct
c2r2gsm.com
Old 03-27-2006, 02:23   #5 (permalink)
Crazy Poster
Member: 186463
c2r2gsm.com
Hi c2r2gsm.com,
i flashed via TP before,the phone `s power was on,but when i u unlocked via TP ,it always displayed Error 400114 and the power wasnt on,what is problem with my phone,please help me.
Many thanks.
Old 03-27-2006, 02:57   #6 (permalink)
nctrung_vn's Avatar
Member: 135671
Trying to full battery and connect to test point and reflash then phone is Ok.
I'm have 5 phone to go die and trying more flash alot then Ok.
Hope you enjoy to 2006 Sharp CID 73.
Best & regards
Old 03-27-2006, 02:59   #7 (permalink)
gwaai's Avatar
Member: 49581
Hi c2r2gsm.com,
Many thanks.
check if you have damage the TP ...
even you flash a dead flash into a phone, whenever you wanna unlock or connect the phone, it shoulbe be able to detect your phone
the error you got means USBSmart cannot connect ... 99% that you make mistake, not the USBSmart's mistake ...
1. check if your tp is still soldered onto the board correctly
2. procedure ok? (connect tp then insert battery ... etc)
my experience, on my first CID73 Sharp, I DID damaged the TP and got the same error as you ... after fixing the TP (i broke the resistor's connnection to the board), all went smoothly when connecting for flashing/unlocking .... and my 2nd CID73 sharp, i did TP very carefully, no problem at all ~
Old 03-27-2006, 03:11   #8 (permalink)
Crazy Poster
Member: 186463
hi,
please tell me how to fix the TP,i think i did like you said,so my phone was broken.
Best regard
Old 03-27-2006, 04:05   #9 (permalink)
Crazy Poster
Member: 186463
hi i flashed again,but the screen always display:
Switch phone ON ...
ERROR 400115
please tell me what can i do?
many thanks
Old 03-27-2006, 04:17   #10 (permalink)
noi
noi's Avatar
Member: 49103
sharp 903 / 703 cid73 dead after unlock,
--check your cable and power supply
--check the testpoint
--correct flash file
--last thing is the timing in flashing
a while ago, we've flashed 903 and 703 cid 73 and flashing successfull
br,
MEGATRIO team
Old 03-27-2006, 04:27   #11 (permalink)
nctrung_vn's Avatar
Member: 135671
This is test point good.
I'm have checking and tested.
Old 03-27-2006, 04:57   #12 (permalink)
Crazy Poster
Member: 186463
hello friend,
i flashed via v2 TP,and the phone`s power was on,but sim emp,then i unlocked with the same TP,it always display:
Switch phone ON ...
ERROR 400115
or
Switch phone ON ...
ERROR 400114
or
Switch phone ON ...
ERROR 400113
and now the phone has no power on ,it was dead because the SW cant read,have you got any solution?please help me,
maybe i will try the test point you shew.
many thanks
Old 03-27-2006, 07:10   #13 (permalink)
Crazy Poster
Member: 186463
hi friend,
i tried to do another phone,it is ok and it is unlocked,but my phone still problem,i cant recharge battery by this phone(no power on the lamp)the USB-SMART also cant read the phone,when i flash it normal(NON TP) it always show:
Switch phone ON ...
ERROR 400115
Switch phone ON ...
ERROR 400115
and when i unlock it normal(non TP)
Switch phone ON ...
Get phone info
ERROR 400115
Switch phone ON ...
Get phone info
ERROR 400115
Switch phone ON ...
Get phone info
ERROR 400115
anybody please show me how can i save my phone.
many thanks
Mr Zulea please help me!!!!!!!!!!!!!
Old 03-27-2006, 18:30   #14 (permalink)
Member: 3925
hi guys
please help me. how resolve my problem.......................................... i'm using full charged battery. soft can't detect my phone. zulea help me.....................
need repair solution
thank you
Old 03-28-2006, 01:48   #15 (permalink)
Crazy Poster
Member: 186463
Originally Posted by Siemens man
hi guys
thank you
hi pal,
my phone is same your,it cant detected by usb-smart,i am waiting for repairing solution too.
B.R
help urgently G1157 dead after unlock.. razisamb FuriouS TeaM Products 4 03-29-2010 15:38
T33 sigmatel was dead after format azad4u CPF-Dongle 1 10-06-2009 14:15
KG375 Blink after flashen with infinity (phone was dead after unlock with ultpro) Mounir Infinity-Box 12 02-08-2009 14:32
903sh cid73 2006/1 dead after unlock jay_textelcom Sharp 4 03-09-2007 13:09
Vodafone 903SH dead after Unlock....!!!?? MUNEEB_AKHTAR_RAZA Cruiser Suite 6 01-01-2006 04:59
Page generated in 0.40513 seconds with 12 queries
