Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > USB-Smart > Motorola P2K (USB-Smart)
Old 07-06-2006, 10:48   #1 (permalink)
kiriazy's Avatar
Member: 50456
a920 unlocking problem
i am trying to unlock a920 with p2k tool v41 but it always fails when the program tries to switch the phone into flash mode so is there any testpoint should i use or somthing ?
here is the log:
Connecting to phone ...
Switching to P2K mode ...
Connected to: 'Motorola Test Interface'
Switching to flash mode ...
ERROR: Could not connect
BR,
Kiriazy
Old 07-06-2006, 11:50   #2 (permalink)
viru's Avatar
Member: 222198
Sonork: 100.102981
u have to press the top two buttons together to got flash mode
Old 07-07-2006, 09:00   #3 (permalink)
kiriazy's Avatar
Member: 50456
when i press the 2 play buttons the program doesn't detect the phone so what do i have to do ?
Old 08-13-2006, 21:37   #4 (permalink)
Member: 5202
Finaly...after smart clip unlock fail, for motorola a925, i `succes unlock` with Usb smart cyclone v3.9 cracked version...
here is a log
Connected to: 'Motorola Flash'
Connected OK
Bootloader version: 0581
Sending loader to phone ...
Sending second loader to phone ...
Get info from phone ...
PDS info: PDS V1.0
ADR info: 080F9647
Powering down...
Connected OK
Unlocking ...
Unlock OK
Powering down...
Connected OK
Powering down...
All unlock process finished OK
But the phone is still LOCKED!!!!!!!
Old 08-14-2006, 01:26   #5 (permalink)
xiaoyuz's Avatar
Member: 76767
Sonork: 100.1594567
yes usb-smart can't unlock a920 and a925
can't Switching to flash mode or disp All unlock process finished OK
pls try cyclone smart-clip not need computer hehe
Old 08-14-2006, 01:29   #6 (permalink)
Member: 307245
Have you tried P2K Easy Tool 3.7 cracked? there is apparently bugs in 3.9 and many people have had problems unlocking with 3.9
Old 08-21-2006, 10:16   #7 (permalink)
Member: 287609
here is the log:
BR,
Kiriazy
Just Want to say thank u to Mrtinlertrain for his graet support and am pasting this cos i know it will help someone too.
mrtinkertrain_smartclip: have you performed Unlock procedure correctly?
Unlock procedure for A920/A925/A1000
1. Power the phone on.
2. Connect the phone to a powered clip. Phone display should give "USB cable connected" message.
3. Press UNLOCK button on the clip.
4. Phone reloads. Within 5-10 seconds phone display gives "Waiting for PST" message.
5. Press 1 and 2 keys simultaneously in upper part of the handset. The phone enters boot mode (if you don't press these 2 keys during "Waiting for PST" message, the clip will give red E/G led and you will have to start with step 1 again).
6. After A and B keys have been pressed E/G green led will blink and phone reboots. Meanwhile E/G will give frequent green blinking and phone will turn on.
Do not disconnect cell phone from Smart-Clip while green led indic
mrtinkertrain_smartclip: 7. Green E/G led glows. The cell phone is unlocked.
A920 flashing problem bachirDraria P2k Series 9 02-07-2007 08:42
A920 Gprs problem Egypt Unlocker P2k Series 1 12-18-2004 20:05
Next update can unlock A920 without problems! :-) laxxe Smart-Clip 8 11-24-2004 20:14
A920 - unlock problem ;( AndRe DCF-gsm Smart-Clip 15 11-22-2004 17:47
a920 unlock problem Siemens man UniMoto 2 11-03-2004 03:53
Page generated in 0.27813 seconds with 11 queries
