Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > USB-Smart > Motorola P2K (USB-Smart)
Old 02-18-2006, 21:01   #1 (permalink)
Member: 210861
Cannot connecting with C975 at all.
Help, I tried to connected my C975 with the tool but it always reports that
Connecting to phone ...
ERROR: Could not connect
Driver has been installed and is not conflicting with any other port. What might me the problem?
Thanks
Old 02-18-2006, 21:13   #2 (permalink)
Stylo_GSM's Avatar
Member: 177235
Sonork: 111568
Thanks Meter: 138
Unhappy we all waitin
hi
we all ave to wait for a big update 2-3 days time
every1 has a problem unlocking their fones
Old 02-18-2006, 21:14   #3 (permalink)
Stylo_GSM's Avatar
Member: 177235
Sonork: 111568
Thanks Meter: 138
hi
Old 02-18-2006, 21:16   #4 (permalink)
Member: 210861
It seems the other can at least connect the phone but I cannot, wait for the answer~~~~~
Old 02-18-2006, 21:17   #5 (permalink)
zulea's Avatar
Member: 5325
Thanks Meter: 8,448
Did you run and install this:
LibUSB_Setup_v01101.exe ???
Old 02-18-2006, 21:24   #6 (permalink)
Member: 210861
Yes I did. But there is nothing runnable after installation except a test programm. I am not really sure what it is used for?
Old 02-18-2006, 21:24   #7 (permalink)
Stylo_GSM's Avatar
Member: 177235
Sonork: 111568
Thanks Meter: 138
well i run the software
but it connects and then gives a error message or "access violation...."
this happened with v220 , v3 etc pls fix the bug
Old 02-18-2006, 22:21   #8 (permalink)
Member: 210861
V3 was just tried, complete same problem.
Old 02-19-2006, 10:35   #9 (permalink)
Member: 210861
Problem changed to the following:
Detected USB device VID:22B8 PID:4902
Switching to P2K mode ...
I am using XP(SP2). Also tried the other mechine,not working as well.
Old 02-19-2006, 11:40   #10 (permalink)
The Repair Shop's Avatar
Member: 307549
Thanks Meter: 188
same here as well. good start to a new tool?????
Old 02-19-2006, 12:07   #11 (permalink)
zulea's Avatar
Member: 5325
Thanks Meter: 8,448
Hi,
Just use v1.9 and all will be OK.
More details here:
http://forum.gsmhosting.com/vbb/showthread.php?t=272768
Best regards,
Zulea
Old 02-19-2006, 12:26   #12 (permalink)
Member: 210861
Hi,
More details here:
Best regards,
Zulea
1.9 is also tried and got:
Detected USB device VID:22B8 PID:4901
ERROR: Could not set USB configuration : could not set config 1: win error: The parameter is incorrect.
ERROR: Could not open flash interface
What might be the problem?
Old 02-19-2006, 12:29   #13 (permalink)
Member: 210861
Hi,
More details here:
Best regards,
Zulea
I also tried to manually change the phone to flash mode and after that I got:
Detected USB device VID:22B8 PID:4903
Opened Motorola S Flash Neptune LTE OK
Connected OK
Sending loader to phone ...
ERROR: FLASHCMD invalid command response
ERROR: Sending JUMP command.
ERROR: Send loader failed (1)
Old 02-19-2006, 16:42   #14 (permalink)
Member: 210861
V1.9 worked fine. But after unlock the phone is still locked!Why?
Old 02-19-2006, 21:23   #15 (permalink)
Member: 5938
same problem...
Detected USB device VID:22B8 PID:3002
When the tool switching to p2k mode, i hear my pc disconnect the phone (makes PLIM)
cannot connect with spread cpu with new boxes ?? laythjg SpiderMan 1 04-03-2009 14:14
N91 cannot be powered on at all eugenemon Nokia Hardware & Hardware Repair 1 12-27-2007 18:38
Sony Erricson Phone cannot connect with UFS3 hasheeb UFS2 + UFS3-Tornadoflasher 6 05-15-2006 12:24
my phoenix cannot connect with 5185 GSMsell Various CDMA/TDMA Cell Phones 6 08-09-2004 17:38
Even cannot connect with T10s:HEELP GreEn Old Ericsson Phones & Sony Phones 1 07-09-2000 13:23
Page generated in 0.23526 seconds with 11 queries
