Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > USB-Smart > Motorola P2K (USB-Smart)
Old 08-02-2006, 00:34   #1 (permalink)
Member: 166873
Exclamation Motorola C975 shows RS-232 Serial when powered using *#
Hi All
I am trying to unlock a Motorola C975, the bootloader version is 5 something but I always get Switching to P2K and then Cannot Connect.
The phone is from 3 Australia and I believe 3 have put some kind of restriction on the phone so that USB communication is disabled.
I powered the phone using *#, it shows me the boot loader version on the screen and the firmware version and below that it says RS-232 Serial.
Does this mean, I can only unlock the phone using serial RS-232 cable??
Please give your views and ideas on this.
Thanks
Old 08-02-2006, 04:01   #2 (permalink)
vazgsm's Avatar
Member: 111871
Sonork: 100.78975
learn the basics, don´t trip. just plug usb cable before you put phone in boot mode, or use repair cable.
br
Old 08-02-2006, 22:31   #3 (permalink)
Member: 166873
Thanks for suggestion, but thats what i am doing, trying to learn the basics. I have tried what you are saying but doesnt work, also which repair cable are you talking about and where can I get it from? Thanks
Old 08-03-2006, 00:37   #4 (permalink)
vazgsm's Avatar
Member: 111871
Sonork: 100.78975
probably you have bad connection (cable problem). if u plug usb cable (pc and phone), and then put phone in boot mode, it accepts usb connection. when it not happen, it´s because phone is not properly attached to pc, which happens when u have a defective cable or dirty contacts.
repair cable is a normal usb cable, only that pins 13 and 14 are connected. when you have no keyboard to use, for instance, it´s the only way to put phone in boot mode.
br
Old 08-03-2006, 10:35   #5 (permalink)
Member: 166873
You are a legend mate, I plugged the phone and then powered it in boot mode and now software can recognise it but still getting this error. here is the log -
Connecting to phone ...
Connected to: 'Motorola Flash'
Connected OK
Bootloader version: 05F1
Write flashbootloader 0631 ...
ERROR: FLASHCMD invalid command response
ERROR: Send ERASE command
Old 08-03-2006, 10:43   #6 (permalink)
Member: 166873
OK finally it says its done -
Connected OK
Bootloader version: 0631
Write flashbootloader 05F1 ...
Connected OK
Bootloader version: 0310
Sending loader to phone ...
Sending second loader to phone ...
Unlocking ...
Unlock OK
Powering down...
Connected OK
Upgrade flashbootloader ...
Powering down...
All unlock process finished OK
But now the phone is dead, only powers in boot mode???
Old 08-03-2006, 10:59   #7 (permalink)
Arion123's Avatar
Member: 9862
@ technoguy
Try to Flash your phone good Original Flash with RDS Lite 2.7 or 2.9.
I think Pk2 by Zulea don't right for Flash your Motorola Phone, but RDS lite
( Original Motorola Sw) is perfect.
I think it is help you.
Br: Arion
Old 08-03-2006, 11:28   #8 (permalink)
Member: 166873
Thanks a lot everyone, followed the instructions on this link An Unlock And Repair Guide For C975 Lower Than R245_u_82.21.911 Type
Interrupted the process as mentioned on this link and NOW PHONE IS UNLOCKEDDDD. Thanks everyone.
Old 08-03-2006, 12:41   #9 (permalink)
Member: 10125
No luck fone is back alive but still lock what should do now is it important using P2K EASY TOOL 3.4 or version 3.9 will do, any constructive suggestion will be mostly appreciated
thanks n Regards
Old 08-03-2006, 22:10   #10 (permalink)
kidchaos's Avatar
Member: 287042
thanks n Regards
Are you sure that Your C975 contain diffrent kind Bootloader and firmware than 6.3.6/91i?? If your moto has this software than You can't unlock it right now...
Old 08-03-2006, 22:45   #11 (permalink)
Member: 166873
ozcom,mate try 3.7 and follow the instructions on the link I gave in my above reply.
Old 08-04-2006, 14:30   #12 (permalink)
Member: 10125
Thanks for reply will try n revert bck
Boot Loader 0.5.F.1
SW Version : R245_U_82.21.9.1I
Regards
Old 08-06-2006, 00:52   #13 (permalink)
kidchaos's Avatar
Member: 287042
Or maybe it is better to use 3.9 than 3.7???
Old 08-09-2006, 13:30   #14 (permalink)
Member: 10125
Thanks a lot for help but unfortunately have try v2.7 & v2.9 still no luck fone remain LOCK!
Regards
Sabrent SBT-USC6K Hi-Speed USB 2.0 to Serial (9-pin) DB-9 RS-232 Adapter Cable (BLACK IPMART ipmart WebShop 0 06-25-2009 07:30
motorola c975 powers on automatically when battery is inserted djjoy Motorola Hardware Repair Section 0 05-02-2007 10:33
C975 shows Programming mode when Powers on it. Sir_GsM Smart-Clip 8 05-17-2005 10:19
Unable to connect using RS-232 Cable ToM@to Sony Ericsson 5 12-07-2004 10:31
USB to RS-232 cable + mbus cable = ?? cassidy Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 2 05-25-2002 02:36
Page generated in 0.94998 seconds with 11 queries
