Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > USB-Smart > Motorola P2K (USB-Smart)
Old 07-24-2006, 12:10   #1 (permalink)
*phone-company*'s Avatar
Member: 60001
Sonork: 100.106474
Need FF.SHX for V3
Hi,
would anybody be so kind and post a link to fullflash.shx for repair V3...Just do pds repair...can`t download anything from supportserver.....
Problem, after unlock V3 with p2keasy 5.3 no Display in v3.......Any Solutions????
regards, phone-company
edit:
Display outside works normal....Is this Hardware or software-error??? before unlock worx normal both displays
Old 07-24-2006, 18:53   #2 (permalink)
systemworm's Avatar
Member: 68498
Originally Posted by *phone-company*
Hi,
edit:
Here is your link http://motofon.ru/index.php?option=c...sitory&Itemid= &func=download&id=17&chk=09352b9abae7544e4a2b72cef e76476a
Just tick before Я согласен с условиями лицензионного соглашения.
and press Скачать
download will begin
Old 07-24-2006, 19:01   #3 (permalink)
Member: 60001
Sonork: 100.106474
sorry don`t work.....i flashed a few versions but no effect...Display is only white......Small outside display works normal...this happend after unlock with P2K easy 5.3
Old 07-24-2006, 19:06   #4 (permalink)
systemworm's Avatar
Member: 68498
Try to repair pds afterwards use full flashing or unlock once again sometimes the keyboard after unlock doesn't work then I unlock phone once more all is ok
Old 07-24-2006, 19:37   #5 (permalink)
Member: 60001
Sonork: 100.106474
i tried but no result
Old 07-25-2006, 00:30   #6 (permalink)
Member: 127449
the pds repair for V3razr works well with 4.1
trb
Old 07-25-2006, 12:42   #7 (permalink)
Member: 60001
Sonork: 100.106474
i just try 4.1 same result only white display......any other solutions???? Now in Bootloader only black-Screen
Old 07-25-2006, 13:35   #8 (permalink)
zulea's Avatar
Member: 5325
Hi,
edit:
Did you disassembled phone when made repair (and used testpoint)?
If yes, check for hardware damaged and/or wrong assembly.
Also, are you sure phone not had any hardware damage before repair?
Try to write V3_R374_BootLoader_7E0_BinFormat.bin or V3_R374_BootLoader_823_BinFormat.bin
If still same problem try to check flex cable for display or any other hardware problems.
Old 07-25-2006, 14:04   #9 (permalink)
Pecel's Avatar
Member: 123230
Sonork: 100.113333
Bootloader 08.23 in shx format will fix your phone
Old 07-25-2006, 14:09   #10 (permalink)
Member: 60001
Sonork: 100.106474
No before unlock all was ok.....i don`t need to dissamble phone cause bootloader was 8.26...I did a lot of these phones before without any problems....
After downgrade bootloader diplay flickered then no Diplay (only whitescreen)....I try pds repair, fullflash, bootloader from o7 up to 8.26 no result......I`ve ust send it to a friend 8he will try to fix it with smart clip.....
yesterday was a bad day for me One sagem..can`t unlock, one Motorola...can`t unlock Ok, lets see what will happen next
Best regards and many thanx for your help
Need FF file for C75 FlashID:0001,227E! vanhh S-Gold Based Phones 5 04-18-2010 04:03
Need full flash for V3 Smart Clip kasic Smart-Clip 2 11-26-2005 12:26
Need full flash for V3 Smart Clip kasic Motorola Hardware Repair Section 0 11-26-2005 11:35
Need full flash for V3, please !!!!!! DigiCell Smart-Clip 0 11-11-2005 16:12
hellp i need flash file for V3 vis lp0033 Roni1976 P2k Series 0 04-08-2005 12:54
Page generated in 0.31244 seconds with 11 queries
