02-23-2006, 19:29 | #1 (permalink) |
Freak Poster Join Date: Jul 2003 Location: Brazil Age: 57
Member: 33736 Status: Offline Thanks Meter: 15 | >>> P2K Easy Tool V22 ERROR with V635 <<< The P2K EasyTool V22 is giving error ( see picture attached ) when i try a PDS backup... the bootloader backup works fine.... Zeula, please check this.... the error occurs at the exactly moment that the Flash Interface is detected by windows.... BR |
02-23-2006, 20:45 | #2 (permalink) | |
Insane Poster Join Date: Dec 2005
Member: 213912 Status: Offline Thanks Meter: 0 | Im getting it too Quote:
02-23-2006, 20:50 | #3 (permalink) |
No Life Poster Join Date: Jan 2006 Location: gsm market Age: 35
Member: 222481 Status: Offline Thanks Meter: 30 | Hi, For connection error problems just read this: 1. before unlocking operation, phone must be powered up with NOT ANY CABLE connected (using power from phone battery) 2. pay attention at repair cables (with pins 13-14 shorted), because if you power on phone with this kind of cable plugged in bottom of phone, it will be initialized (the phone) in another mode, and PC no more see Motorola Modem! 3. now connect phone to cable, and if you not have installed drivers yet, Win-XP will ask you for MOTOROLA MODEM DRIVER! 4. after you connected phone to PC, check in Control Panel if you have Motorola Modem 5. if you started phone in flash mode (by pressing *, #, PWR), this is NOT A SOLUTION! You will receive connection error at unlocking second step (when phone should be powered up in NORMAL mode, and connected to PC as a MODEM) Try first to solve all this steps before make unlock! If software fails at "Swithing to P2K mode ...": 1. check if you have installed Motorola Modem (from Control Panel) 2. check COM port number used by this modem driver 3. you could have some conflicts with other modems or another software who use COM ports, so is better to change the COM port number used by Motorola Modem to a FREE PORT HIGHER value (e.g. over COM 50, ...) 4. close any other tool who could try to connect to Motorola phone, like PST, RSD Lite, ... If you will receive "Connect error" at second step (after software get PDS and ADR info), PLEASE READ AGAIN carfuly this text from beginning! |
02-23-2006, 21:49 | #4 (permalink) | |
No Life Poster Join Date: Jul 2001 Location: Inside Raskal pocket Age: 54
Member: 5325 Status: Offline Thanks Meter: 8,448 | Quote:
02-24-2006, 11:24 | #5 (permalink) |
Member: 213912 Status: Offline Thanks Meter: 0 | Zulea Connection errors Still getting this error Access violation at address 1 aec5146 in module Libusb0.dll write of address 00000227 Tried what u said in last post but cant seem to get around it. The last error " switching to p2k mode " I seem to got it sorted out by downloading service pack 2 |
03-01-2006, 13:51 | #6 (permalink) | |
Member: 33736 Status: Offline Thanks Meter: 15 | Quote:
BR | |
How To Unlock V3r With P2k Easy Tool | ::gsmcoder:: | Motorola P2k | 0 | 07-26-2006 19:56 |
When I can unlock E398, C450 with P2K Easy Tool? | vinny | Motorola P2K (USB-Smart) | 4 | 07-01-2006 19:00 |
P2K Easy Tool v39 Error message HELP!! | colinwatson1 | Motorola P2k | 3 | 06-25-2006 18:47 |
c350 always error with p2k easy tool | gsmbac | Motorola P2K (USB-Smart) | 2 | 03-26-2006 16:44 |
How to unlock V60 with P2k easy tool? | vinny | Motorola P2K (USB-Smart) | 6 | 02-27-2006 08:42 |
