04-25-2006, 19:18 | #1 (permalink) |
Product Supporter Join Date: Dec 2001 Location: in my skin Age: 47
Member: 8086 Status: Offline Thanks Meter: 180 | V360v unlock problem,plz help! I am fu_c_king with 2 V360v phones,both of them are: V360v Boot Loader 08.A0. R4513_G_08.B7.ABR the problem is: Connecting to phone ... Connected to: 'Motorola Flash' Connected OK Bootloader version: 0300 Sending loader to phone ... ...and here the P2k Tool freezes and even can not close from task manager. P2k drivers are v2.9 installed OK and rsd lite recognizes phone as S Blank Neptune LTE2. In control panel phone shows up as Motorola Flash Interface. TP is OK. The strange is that I have already done some L6 's with TP method without any problem.And now these sh_itty V360v's are making me crazy. Tried on another PC too,where P2k Tool freezes at UNLOCKING... message and phones are still locked. |
04-25-2006, 21:10 | #2 (permalink) |
Member: 8086 Status: Offline Thanks Meter: 180 | Just tried on 3rd PC, from clean install XP, Connecting to phone ... Connected to : 'Motorola Flash' Connected OK Bootloader version: 0300 Sending loader to phone ... Loader sent OK. Unlocking ... and here STILL FREEZES |
04-26-2006, 12:07 | #4 (permalink) |
Member: 8086 Status: Offline Thanks Meter: 180 | Tried with older versions of P2k Tool: ... Error reading PDS VARS (2) ERROR: Unlock failed I think it's due to new version of PDS zone, unsupported 'till now. Contacted Zulea... |
04-27-2006, 10:21 | #6 (permalink) |
No Life Poster Join Date: Apr 2003 Location: Bled lekhla
Member: 27291 Status: Offline Thanks Meter: 81 | tested with the same phone and the same boot Connecting to phone ... Connected to : 'Motorola Flash' Connected OK Bootloader version: 0300 Sending loader to phone ... Loader sent OK. Unlocking ... unlock ok powring down... All is OK without problem ! try to restart action from first ( test point ,cable,battery...) |
04-27-2006, 10:51 | #7 (permalink) | |
Registered User Join Date: Aug 2003 Age: 41
Member: 36653 Status: Offline Thanks Meter: 336 | Quote:
1 connect test point 2 connect cable to phone and pc 3 (when phone detected by the pc ) desconnect test point 4 unlock and it will work perfecly you problem is that you don't desconnect test point when you unlock | |
04-28-2006, 19:51 | #8 (permalink) | |
Member: 8086 Status: Offline Thanks Meter: 180 | Quote:
Thanx,but I am not a begginer, I have done a few pcs different moto phones with TP method. I have released TP from gnd. The problem was something different. Anyway, contacted some colleague and done them with a different moto unlocking product. | |
05-14-2006, 19:51 | #11 (permalink) |
Member: 8086 Status: Offline Thanks Meter: 180 | Problem solved, when noticed the same situation on an V3r (Neptune LTE2) phone again and figured out that it was caused by usb driver failure ('coz I was using older p2k drivers before and then upgraded to v2.9. but it seems that upgrading drivers was not 100% succesful). Reinstalled (clean install) WinXP with SP2 and P2k Drivers 2.9 and unlock was done in 2 sec. |
05-18-2006, 19:41 | #13 (permalink) |
Member: 8086 Status: Offline Thanks Meter: 180 | @nekbil: it's your private problem that you can not release TP from GND while unlocking. My problem was totally different,the thread I started was different too and as you can read I have solved my problem myself as no one could help me. |
05-30-2006, 11:39 | #14 (permalink) |
No Life Poster Join Date: Oct 2004 Location: Tbilisi Age: 42
Member: 87722 Status: Offline Thanks Meter: 112 | V360v now is dead with P2K_Easy_Tool_v37 Connecting to phone ... Connected to: 'Motorola Flash' Connected OK Bootloader version: 0300 Sending loader to phone ... Loader sent OK. Read Flash ID ... Flash ID: 89001088 Unlocking ... Error reading PDS VARS (2) ERROR: Unlock failed phone cant power up. by pressing *# on display shows only "critical error 00" test point and procedure is ok I need help. |
!!x 70 unlocking problem plz help!! | rajabrotherscom | Infinity-Box | 7 | 08-03-2008 12:09 |
V3r unlock problem, plz help! | Saff | Motorola Hardware Repair | 6 | 06-02-2007 07:01 |
W810i unlock problem plz help !!! | A-H-T | Cruiser Suite | 7 | 03-01-2007 14:41 |
Panasonic VS2 unlock problem plz help | adi2002 | FuriousGold | 0 | 08-11-2006 22:40 |
Nec 343i unlock problem PLZ HELP!.. | MARKLOS | NEC | 2 | 06-20-2006 13:39 |
