V3i Dead after PDS Repair This phone was unlocked OK (TP was not damaged, bcos I drilled a hole on top od shield, and 100000000% no contact with phone PCB) But phone restarts when accessing network if phone is open. So I decided to do PDS repair. But immediately after doing this, phone is dead: ONLY the green charging light shows permanently when I put battery. Worst still, when I connect cable, PC shows unknown usb device. Also with TP, phone cant enter Blank again. How can I resolve this (BTW, I did not use the newest version of p2k (I think the last 3 updates i dont have) |
Chk the test point resistor u might have damaged it B.R Viru |
But as I said, the hardware is 100% sure OK. Make a search with this topic, and you will see others too have same problem, but non stated how to solve it. Its surely a software problem, but how to resolve it is a problem now. B4 I did PDS repair I must use TP to get it into Blank mode, and until that, phone went into blank mode 1st attemp. Immediately after PDS repair says phone is repaired OK, then phone could not power anylonger. Thanks though, but I still need help |
It is not solved yet. V3i pds repair for p2k tool 4.1 - 5.3 do not work. Do not use V3i pds repair with p2k tool. |
it must enter in blank flash mode with TP if no HW damage, even if flash IC is empty! |
