02-19-2006, 12:06 | #1 (permalink) |
No Life Poster Join Date: Jul 2001 Location: Inside Raskal pocket Age: 54
Member: 5325 Status: Offline Thanks Meter: 8,448 | ...::: P2K Easy Tool v5.3 - full flash read/write :::... Released P2K easy Tool v1.9: - improved connection on 3G phones (switching to P2K mode) |
02-20-2006, 13:36 | #2 (permalink) |
Member: 5325 Status: Offline Thanks Meter: 8,448 | 20-Feb-2006: Released P2K Easy Tool v2.0: - improved unlocking on LTE based models (completely new method used) - corrected bugs on unlocking V3 and E1 models Best regards, Zulea |
The Following User Says Thank You to zulea For This Useful Post: |
02-21-2006, 20:57 | #3 (permalink) |
Member: 5325 Status: Offline Thanks Meter: 8,448 | 21-Feb-2006: Released P2K Easy Tool v2.1: - improved flashing on V3 and Rainbow 3G models - improved swithching all phones to flash mode |
02-24-2006, 13:29 | #5 (permalink) |
Member: 5325 Status: Offline Thanks Meter: 8,448 | 24-Feb-2006: Released P2K Easy Tool v2.3: - solved unlocking problems on 3G phones - added support for 3G phones with flash bootloader 6.31 without testpoint - added info when select phone model about phone category (Neptune LTE, Rainbow POG, ...) - added info when select phone model if required testpoint for unlock - automaticaly upgrade flash bootloader on 3G phones to 6.31 after unlock - check if testpoint is made corectly on 3G phones (on bootloaders higher than 6.36) - check flash bootloader version on 3G phones and inform user if required testpoint - check if selected filenames where to save readed data when read Bootloader and PDS - improved protection and EXE file packing |
03-21-2006, 16:14 | #10 (permalink) |
Member: 5325 Status: Offline Thanks Meter: 8,448 | 21-Mar-2006: Released P2K Easy Tool v3.1: - LIBUSB no more needed to connect to phone ( PLEASE uninstall LIBUSB !!! ) - improved USB communication with drivers - improved switching to P2K mode and modem detection |
03-22-2006, 15:33 | #11 (permalink) |
Member: 5325 Status: Offline Thanks Meter: 8,448 | 22-Mar-2006: Released P2K Easy Tool v3.2: - working unlock with TP on L6, U6 and E1 - removed bug from v3.1 when unlock LTE2 - working flashing for A835 |
04-06-2006, 15:52 | #12 (permalink) |
Member: 5325 Status: Offline Thanks Meter: 8,448 | 06-Apr-2006: Released P2K Easy Tool v3.4: - added V540 and V557 unlock support via TP - improved communication in USB P2K mode - improved unlock function on A835, A920, A925 - improved unlock function on all Neptune LTE models - added support for PCSC based smartcard readers (JAFWM kind readers) |
05-17-2006, 16:14 | #13 (permalink) |
Member: 5325 Status: Offline Thanks Meter: 8,448 | 17-May-2006: Released P2K Easy Tool v3.6: - added L2 and V235 unlock support via TP - added Flash ID reading for all LTE and LTE2 based models - added Flash ID type recognition on all LTE and LTE2 based models - now avoid damge phones if Flash ID is unknown or unsupported - used completely new bootloaders for LTE and LTE2 phones - support for unlock new PDS layout for LTE2 based phones (V360, V360v) - added message to disconnect testpoint before sending boot to phone - new bootloader for A835 (need report result from somebody on H3G phone) ------------------------------------------------------- Last edited by zulea; 05-20-2006 at 18:43. |
05-20-2006, 18:50 | #14 (permalink) |
Member: 5325 Status: Offline Thanks Meter: 8,448 | 20-May-2006: Released P2K Easy Tool v3.7: - added fast language flashing support - LNG files (files located in folder Language_Files on support) - added support for 20xxxxxx Flash ID on LTE and LTE2 models - added support for V555 - added message to disconnect testpoint on RAINBOW POG models (when unlocking this models using testpoint) - removed some bugs on flashing SHX files on RSA based models (now flashing V3x, E770, ... should work well) ------------------------------------------------------- |
06-04-2006, 12:14 | #15 (permalink) |
Member: 5325 Status: Offline Thanks Meter: 8,448 | 04-Jun-2006: Released P2K Easy Tool v3.9: - added PDS repair for all Neptune LTE2 based models: L7, V3i, V3r, V235, V360, V360v (this procedure also repair flash bootloader damages) - added V3r phone model on selection list - corrected V235 bug on selection (this is LTE2 phone) ------------------------------------------------------- |
l6 flash with P2K Easy Tool v5.3 cracked plz help urgent | bd_planet | Motorola P2k | 0 | 01-07-2010 05:01 |
P2k Easy Tool v5.3 small bug; | ddgsm | Motorola P2K (USB-Smart) | 0 | 07-20-2006 10:29 |
p2k easy tool v5.3 problem | astar0th | Motorola P2K (USB-Smart) | 9 | 07-19-2006 07:58 |
