Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > USB-Smart > Samsung (USB-Smart)
Old 03-26-2006, 15:20   #1 (permalink)
Crazy Poster
Member: 54567
15 in one cable, problems unlock z500
i ahve the 15 in one cable, all operations work except z500 unlock!!
do i need a special driver? and which one, or can i use the cable that came with?
imused the z140 and z130 connector for it!
greetings hanebatser
Old 03-26-2006, 19:07   #2 (permalink)
Member: 13239
Use the cable included with it.
Regards
Old 03-28-2006, 16:48   #3 (permalink)
Crazy Poster
Member: 54567
Do i need to connect the 2-3 pins together of the com port when i use original cable!!
Why my 15 in one cable not works with z500 but it works with the other models (not umts).
maybe other drivers?
Old 03-28-2006, 17:16   #4 (permalink)
Member: 13239
About connect pins 2 and 3 it is only for winimei soft. Don need to do it with Usb-Smart
About cable I don't know how can't work, yes can be drivers problem, but this cable only work with this models
http://pinouts.ru/data/samsung_z130_pinout.shtml
If you can't unlock it maybe is a recent version and must downgrada before reading codes.
Regards
Old 04-02-2006, 11:15   #5 (permalink)
Dengel's Avatar
Member: 125415
please post drivers here
Old 04-05-2006, 16:20   #6 (permalink)
Member: 223778
where can i buy all cables set needed for usb-smart samsung operation?????
Old 04-10-2006, 12:56   #7 (permalink)
Cheater -Don't Deal with him-
.:GSM International:.'s Avatar
Member: 8879
Sonork: 100.84016
unlock is only by usb i think
Old 04-10-2006, 14:52   #8 (permalink)
Inovator's Avatar
Member: 144433
I think COM for unlock, and USB for flash
Old 04-10-2006, 15:07   #9 (permalink)
ASHIF's Avatar
Member: 8353
Sonork: 113276
z500 will unlock only by usb cable......but u must short the pin 2 and 3 of seraial port for unlocking operatoin
Old 04-11-2006, 08:27   #10 (permalink)
mikiidan's Avatar
Member: 57577
only usb cable works....tested by me
Old 04-11-2006, 10:40   #11 (permalink)
Crazy Poster
Member: 54567
SO i only need original usb cable i not need to short the pin 2 and 3 of serial port?
Old 04-11-2006, 14:11   #12 (permalink)
Crazy Poster
Member: 54567
it worked!!
thanx
Hanebatser
Old 04-19-2006, 09:22   #13 (permalink)
Member: 4675
did you conect pins 2 and 3?
Old 04-19-2006, 16:50   #14 (permalink)
Member: 67562
Sonork: none
What about my Z140 is not detected by computer?
Cable working couse earlier i unlocked ZV10.
And why com short 2-3 when using USB communicatios?
Old 04-19-2006, 17:33   #15 (permalink)
Member: 13239
Short com pins 2 and 3 is only needed to use Winimei soft.
About not detected Z140 if cable works and drivers are instaled only rest phone problem, phone connector or something else.
Regards
crusier all in one cable chhoeng02 Cruiser Suite 34 07-12-2010 22:07
Samsung Z630 unlock problem = 2 in 1 cable problem or.. radez Z3X-Team Products 10 08-27-2008 22:19
can i use firghter cable to unlock Z500? pakstar QUALCOMM Models (3G) 0 04-26-2006 02:17
cruiser 4 in one cable modify so you dont need 3v power nokia_dan Cruiser Suite 2 10-11-2005 18:27
[solved] Drivers for all in one cable sets? James_S NSPRO 2 08-09-2005 21:58
Page generated in 0.35822 seconds with 11 queries
