"ERROR: PHONE NOT POWER UP" - please help I am tring to unlock my SE K750I, but every time i go to unlock it (using "Semc_tool_v86", i get the message "Error: phone not power up". I am pretty sure im using the correct COM port, as i checked this using the device manager. I took the sim card out of the phone before attemping to unlock it, and the battery inside it is reasonably well charged. Also, i dont think theres any thing wrong with the cable (cruiser 4in1), as the computer detects it when i insert it into the usb port. I have tried to unlock the phone by having it switched of, and then switching it on as it says "switch phone on", and i have also tried it switched on allready, before clicking on "do selected jobs" - yet neither of these methods work. Is there anything i am doing wrong, or should be doing. Any help/advice would be greatly appreciated, as it is driving me mad. Many thanks, Sam. |
Hi, i think the cable im using is actually the cruiser cable (4in1), any other ideas? Thanks, Sam |
Conect the external power to cable around 3,7v and everything will be OK |
remove the battery and put back thats all remove the battery and put back thats all |
2-k750 unlocking... *check clear SP locks *put the cable now(with 3.3 dc supply),not yet for the battery * then click do selected jobs then put the battery now this should be working now. **if you're still having problem connecting with your phone..be sure you have the correct com port settings and your cable installed correctly.. ***how to check if you have the right com port for your USB smart? - right click my computer...then click properties...hardware...device manager....ports (com and LPT) u may see there what com port to use for your cable and u may change the com port also if u want |
