Dongle Problems (USB-Smart) Dongle probelms and installation support |
07-04-2006, 05:13 | #16 (permalink) |
Major Poster Join Date: Oct 2003 Age: 67
Member: 42456 Status: Offline Thanks Meter: 3 | usb smart feature deactivated after updating dongle sir thanks for the link to access usb-smart dongle support. i have already downloaded that maintenance v40 and accessed the support area however i have a problem because the motorola feature was deactivated. can i recover it without cost? br dingski |
07-05-2006, 12:35 | #17 (permalink) | |
Guest
Posts: n/a
Member: | Quote:
Here is stated verry clear about activation file: http://forum.gsmhosting.com/vbb/announcement.php?f=314 If u lost this file you need to ask your reseller to provide this again. BR, Manole | |
07-18-2006, 00:50 | #18 (permalink) |
No Life Poster Join Date: Nov 2001 Location: Underground Age: 43
Member: 7468 Status: Offline Thanks Meter: 2 | hi, today i install my dongle and i try to update but when i press UPDATE shows 0% and dosent do anything. im using maintence 4.1. i can open all softwares without problem but i cant update my card. is that normal? is the first time im using this dongle. regards. |
07-18-2006, 17:04 | #19 (permalink) | |
Guest
Posts: n/a
Member: | Quote:
Some time is normal if your provider or contry block access to our server IP. BR, Manole | |
07-18-2006, 20:05 | #21 (permalink) |
Freak Poster Join Date: Jul 2006 Location: Sweden Age: 46
Member: 312676 Status: Offline Thanks Meter: 34 | With 4.1 nothing happens when i try to update the dongle. Nothing at all...(no connecting to server, no "working on card") With 4.0 it connect to update server and starts working on card. It stops @ 18% and nothing more happens. I am located in Sweden, and will try to use 4.1 with a proxy and see if that helps. (Got the dongle today, but have read LOADS the last months to know what to troubleshot) EDIT: Well, here is my solution: I started v4.0 and used the update smartcard option. When it frooze i pulled the usb-smart dongle out (this closes to program without the need to reboot as i couldn´t get it to close any other way) I did this ~5 times and then it went to 100%. I started v4.1 and i can now request samsung/motorola activation files. Last edited by JayDee78; 07-18-2006 at 20:23. |
07-19-2006, 19:08 | #22 (permalink) |
Freak Poster Join Date: Mar 2002 Location: BULGARIA Age: 48
Member: 10423 Status: Offline Thanks Meter: 15 | HELLO i have too same problem... here is solution install Usb-Smart Installer 3[1].4.exe start Usb-Smart Maintenance 2.3 press update dongle smartcard after that start mainenance 4.1 how you can activate motorola or samsung activations thats all |
07-19-2006, 19:28 | #23 (permalink) | |
No Life Poster Join Date: May 2005 Location: Bulgaria Age: 49
Member: 142632 Status: Offline Sonork: 100.1589012 Thanks Meter: 459 | Quote:
07-19-2006, 21:01 | #24 (permalink) |
Member: 7468 Status: Offline Thanks Meter: 2 | Manole, Something is wrong with the maintenence 4.1 becouse with 3.1 i can update my card without any problem so looks like a problem with the soft, not with the internet provider. regards. |
All users having problem with Updating dongle or opening software plz post here | NFF Box Team | Nokia Fault Finder Box | 76 | 11-18-2008 05:51 |
problem with update dongle! | lahoucine | Easy-Unlocker | 2 | 07-02-2008 13:43 |
Problem with update dongle | gsavv723 | NSPRO | 5 | 01-12-2006 18:29 |
problem with TotalTool dongle | SVH | Sony Ericsson | 9 | 08-26-2003 09:31 |
About problems with Terminator Dongle!!! | pc.net | Sony Ericsson | 0 | 03-24-2003 07:51 |
