Dongle Problems (USB-Smart) Dongle probelms and installation support |
02-20-2006, 00:30 | #1 (permalink) |
No Life Poster Join Date: Apr 2005 Location: PAKISTAN Age: 45
Member: 133436 Status: Offline Sonork: 100.1577364 Thanks Meter: 191 | Some of Error Nos. and there Description --------------- ERROR: 303106: You have different flash files versions…Correct this little mistake and try again --------------- ERROR: 30353B: You have tried to flash the three flash files (Main, Fs, Sfa). Flash only= TWO flash files and later if you want you can flash Sfa file in the phone only. --------------- ERROR: 300314: This Error is appears when you have a V600(maybe any phone) with CID’s mismatch. Flash Erom with CID36 from support area for that phone. Also as a suggestion flash with main and fs file after Erom for better result. --------------- ERROR: 003608, ERROR: 00360C & ERROR: 00360C: This errors where showed when the phone had the RSA killed by Twister or Terminator --------------- ERROR: 304314: This error appears when you are using flash files with CID lower than in OTP. You must use equal or higher. --------------- ERROR: 0001A1: Possibly problem due to cable with bad connection. Check the cable or buy a new one --------------- ERROR: 00A405: This problem happens when you have communication/timers problem check that the cable is working and post a thread telling the exactly error if still happening. Problem related to T100. It’s impossible to clear SP locks in this phone. --------------- ERROR: 300301: Bug found in v1.1 in Sony Ericsson z1010, support with CID16. Problem already solved --------------- ERROR: 304107 & ERROR: 304106: Recover Certificate Problems --------------- ERROR: 303002: This problem appeared when you are trying to Complete the phone alter flash. --------------- ERROR: 304100: This error appears when we are trying to flash a phone that’s empty. --------------- ERROR: 302403: reading flash files bug was fixed. --------------- ERROR: 300314: Problem when trying to unlock V600 --------------- ERROR: 003612: Use another cable T28 com cable doesn’t work in AVR phones --------------- ERROR NETWORK CONTACT: You have to Complete phone --------------- Take Care ENJOY |
02-20-2006, 02:24 | #3 (permalink) |
Member: 133436 Status: Offline Sonork: 100.1577364 Thanks Meter: 191 | Here are Some More . i find them in help file, m also attaching here help file ERROR: 302344: Error showed when converting V600 to K600, main file worked, fs failed uploading could be due to file size or different file version. Also showed when flashing K750, EEPROM was damaged ------------ ERROR 304106: Error in k700 low description about the problem. He tried “Recover Certificate”. Follow the procedure showed in this guide in order to recover certificate. ------------- ERROR 00360A: T610 stops uploading MODEM 2%. Strange error, solved flashing with Div. Tested last version flashing and it’s working well with T610. If you have this problem try with a lower version ------------- ERROR 000103: Z600&T630 unexpected error without any information about it. Seems to be problem when unlocking possibly due to cable connection ------------- ERROR 301C06: Problem with some of the phones with Imei changed (download Semc4.2 to solve this problem) ------------- ERRORS 305010, 305011 & 305013: Connection problems with K750i possibly due to cable connection ------------- Take Care ENJOY |
***Here Are Descriptions of NsPro Error Messages And Solutions For That Errors*** | NADEEM GONDAL | NSPRO | 10 | 01-12-2010 06:28 |
Some of the excellent apps I downlaod from there were great, You can check these apps | SurfingFreak | LG | 0 | 05-09-2009 16:36 |
anybody have description of error-codes? | npl | GOT SEMC | 0 | 07-31-2007 07:55 |
Description of Error numbers | talkways | Universalbox | 1 | 07-25-2007 01:06 |
Redbox works with some of my pc's and don't work with others !!! | makroud | Redbox | 5 | 04-25-2006 09:26 |
