UFS and USB-smart problem 2 Attachment(s) i am having a problem with my USB-smart dongle.. i have a P4 1.5Ghz system with MSI -PM8M-V motherboard using via chipset .. my ufs is working Ok but when i connect my USB-smart and try to run the SEMC tool and interface as UFS Twister then it gives error that (cannot connect to UFS Twister).. please help me ... my motherboard link http://www.msi.com.tw/program/produc...il.php?UID=683 |
I have this problem before i solved it by uninstall new ufs drivers and use the old one thats all br |
Just copy ufs drivers from saras soft directory to directory where you have installed usb smart and your problem gone. |
my idea you use higher version ufs2xx.dll and you must replace your ufs2xx.dll with usb-smart's ufs2xx.dll |
i did have that problem to.. just buy a hub and it will work.. msi motherboards is tricky.. they gat nvidia nforce on tham and that is what couse the problem. buy a usb hub and plug it in. install the drivers and it will work Br Struggler |
or just detach other devices (like JAF Vygis etc.) I got that problem too but when detached other usb ftdi devices it worked :) |
awwwwwwwwwwww done Hi mates i copied ufs2xxx.dll file to SMEC folder and now getting error message any more u guys can try it WBR :) Ejaz Khan |
One minute ago i have the same problem, can not connect SEMC_tool_Vxx via UFS interface, but with Sharp_tool_v50 it connect well! Then i found the problem is UFS2XX.dll file in SEMC_tool_Vxx folder, just delete it and everything will be OK! Let try! :D :D |
1 Attachment(s) replace UFS2XX.dll this inside semc with ver 3.1.6.1 now u not get error |
