Dongle Problems (USB-Smart) Dongle probelms and installation support |
08-09-2006, 06:36 | #1 (permalink) |
No Life Poster Join Date: Jan 2006 Location: US
Member: 216515 Status: Offline Thanks Meter: 4 | USB SMART Unlocker Doesnt work |
08-09-2006, 07:35 | #3 (permalink) |
No Life Poster Join Date: Aug 2003 Location: at home
Member: 36951 Status: Offline Sonork: 100.63212 Thanks Meter: 6,247 | if the software starts, means your dongle work. if you have message no phone found, means your cable is not good, you didnt select the right com port or you phone cannot connect with computer. please ceck again pone connector, cable drivers and comport selected. br |
08-09-2006, 17:06 | #4 (permalink) | |
No Life Poster Join Date: Sep 2002 Location: ''Inside your Brain''
Member: 15800 Status: Offline Thanks Meter: 66 | Quote:
ints tall fone driver corectly.. | |
08-09-2006, 21:18 | #6 (permalink) |
Member: 216515 Status: Offline Thanks Meter: 4 | I have the OEM cables that came with the unlocker. Please link me to buy a new cable set. how do i install the drivers correctly? instead of buying new cable set would a OEM sony ericsson USB data cable work? or does it need to be specific kind? Last edited by ExTrEmE99; 08-09-2006 at 21:38. |
08-09-2006, 22:23 | #7 (permalink) | |
Freak Poster Join Date: Feb 2005 Location: scotland Age: 63
Member: 113283 Status: Offline Thanks Meter: 7 | Quote:
buy the cruiser 4 in 1 cable set should work ok after that also try all the com ports jybx | |
08-10-2006, 01:26 | #9 (permalink) |
No Life Poster Join Date: Sep 2004 Location: www.thefonedoc.com Age: 55
Member: 84155 Status: Offline Thanks Meter: 8 | I really doubt its going to be COM1 Open Device Manager and see what port your cable is listed with and select that port on USB-Smart This is definitely a cable related problem, not USB-Smart Best thing to do is open Device Manager and click the plus besdie ports and then plug in the cable and see what new port it adds |
08-10-2006, 22:27 | #11 (permalink) |
Member: 216515 Status: Offline Thanks Meter: 4 | ok im awaiting the new cable set. Once i get that i will re-install usb smart drivers and then try to get this working to make at least 1.00 on this thing. and ill make sure to check the com port |
08-12-2006, 03:02 | #12 (permalink) | |
Insane Poster Join Date: Mar 2005 Age: 36
Member: 127449 Status: Offline Thanks Meter: 1 | Quote:
try com6 or click start, right click on "my computer", select "properties", select "hardware", select "device manager", select "com port", make sure you see "usb serial port" and verify what com port it is. change the speed of the port to a higher setting. Place the battery in the phone right after you click "do selected jobs". or try pressing power once or twice after clicking "do selected jobs" to get the software started on rsa bypass?. | |
08-12-2006, 11:00 | #13 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Japan Age: 42
Member: 150697 Status: Offline Thanks Meter: 7 | as andre said: if software starts, dongle works fine. if it says no phone found or phone not power up, then you have some problem with your connection. cruiser 4in1 is cheap and very useful. after the usb-serial part of 4in1 is installed, just put on the right end and get to work. usb smart is very good and simple software. im sure you will get it. try cleaning your PC as well. also, some people say that AMD based system is not as compatible... i have never bought INTEL, and usbsmart has always worked VERY WELL with my athlon xp and turion 64 based systems |
08-16-2006, 05:08 | #15 (permalink) | |
plz try this.... post back after. | |
j100 unlock with smart clip doesnt work | surfer2go | Smart-Clip | 39 | 03-24-2009 10:15 |
smart-clip doesnt work | speedstarrr | Smart-Clip | 1 | 02-20-2008 08:26 |
USB Smart 1.7 working with USB/Twister | Gsm2Extreme | SonyEricsson (USB-Smart) | 15 | 09-09-2005 22:41 |
Alcatel USB 9-1 and USB Smart. Does it work well? | UnlockerPT | SonyEricsson (USB-Smart) | 5 | 08-29-2005 22:30 |
lg unlocker doesnt work! | tommaso | FuriouS II | 4 | 11-04-2004 20:10 |
