Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > JAFWM
Old 03-23-2010, 10:16   #1 (permalink)
kamranas's Avatar
Member: 1154111
Sonork: 100.1620855
Thanks Meter: 158
1208 unlock
JAF version 1.98.65 beta1
Detected PKEY: 9000A005
P-key nokia module version 01.02
Detected JAF INTERFACE version: 01.B2, Driver version: 40000, Library version: 30107
JAF DCT4/BB5 LOADERS DIR: C:\Program Files\ODEON\JAF\Flash\
JAF DCT4/BB5 PRODUCT DIR: C:\Program Files\Nokia\Phoenix\Products\
JAF USB LOADERS DIR: C:\Program Files\ODEON\JAF\FlashUSB\
JAF DCT3/DCTL LOADERS DIR: C:\Program Files\ODEON\JAF\Flash3\
USB Cable Driver version: 7.1.17.0
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Switching to serial...
Powering the phone...
Reading...
MCU SW version: V 5.06
12-01-08
RH-99
(c) NMP
HW version: 2502
PCI version:
UEM version: 1328
UPP version: 8850
RFIC version: 0700
DSP version: P06w45.v45
LCD version: INLX:MYKSv08
ST7507
PPM version: V 5.06
12-01-08
RH-99
(c) NMP
AA
ADSP SW version: V 5.06\n12-01-08\nRH-99\n(c) NMP\naa
Production serial number: IKE126148
Product code: 0546370
Module code: 0203402
Basic production code: 0544418
Flash code:
Order number:
Product specific data:
Long production SN:
ATO:
Default SN type:
IMEI plain: 356982013681597
IMEI spare to net: 3A 65 89 02 31 86 51 09
IMEI SV to net: 33 65 89 02 31 86 51 49 F8
Master Code: 2427312616
Failed reading simlock data...
Phone type: RH-99, Software version: 5.06, Language Pack: AA
User code: ÿ#
Searching for saved ini...
Checking for file C:\Program Files\ODEON\JAF\JAF_RH-99.ini
Saved INI not found, loading INI list...
Setting local mode...
Reading product code...
Product Code: 0546370
Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-99\
Searching for default location of ini...
Checking path: C:\Program Files\Common Files\Nokia\DataPackage\Products\RH-99\
Searching for JAF saved location of ini...
Scanning ini files...
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh99_05.060
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh99_05.06mg
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh990_nai5.06mg
Languages in ppm: English,Hindi,Marathi
Done!
Unlocking...
IMEI: 356982013681597
ASIC: b
SW version: 5.06
Selected flash file: C:\Program Files\Nokia\Phoenix\Products\rh-99\rh99_05.060
Decrypting flash...
Encrypting....
CHK Patch found - Unlock Patch found and are not in same block
Patch status: 01
MCU ID: 0x2292
Algo is ready...
Erasing area: 01140000 - 0115FFFF...
Unlocking...
Checking locks...
Block 1:
Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
MCU ID: 0x2292
Reading...
12-01-08
RH-99
(c) NMP
HW version: 2502
PCI version:
UEM version: 1328
UPP version: 8850
RFIC version: 0700
ST7507
PPM version: V 5.06
12-01-08
RH-99
(c) NMP
AA
Flash code:
Order number:
Long production SN:
ATO:
Default SN type:
User code: ÿ#
Block 1:
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
Done!
Setting test mode...
Setting FULL FACTORY...
Operation took 0 minutes 7 seconds...
Done!
Resetting PRODUCTION TUNE...
Operation took 0 minutes 0 seconds...
Done!
Resetting UPGRADE SOFTWARE...
Done!
Resetting SERVICE CENTER...
Done!
Resetting LEAVE FACTORY...
Done!
Resetting USER DATA...
Done!
Operation took 0 minutes 5 seconds...
Done!
The Following User Says Thank You to kamranas For This Useful Post:
New Updates of NKGsM Partner's 1200/1208 unlocker tong Nokia Digital Core Technology 4 ( DCT-4 ) 9 01-26-2010 15:11
13-12-2007 Second BOMB! Nokia 1200 and Nokia 1208 Unlock released! GSMtricks Multi-Box 54 12-18-2007 10:02
1200 and 1208 unlock? andrew14 MT-BOX 2 12-15-2007 01:47
KS v4.0B Ready, 1200 & 1208 unlock done! karwos Typhoon Dongle 12 12-14-2007 16:41
Page generated in 0.15808 seconds with 9 queries
