Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| SE Power Clip & Turbo Unlocker SE power Clip & LG Turbo unlocker |
| | #1 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Dec 2007
Member: 655817 Status: Offline Thanks: 68
| k800i Bypass loader not responding ! k800i error flashing 'Bypass loader not responding !' please help to solved... unit problem before: gdfs error action taken: repair via test point flash gdfs,and erom all done,but phone become white screen.... so i flash phone main and fs but i got error.. logs: SIGNED MODE (USING SERVER) CFG:100010000000000 ChipID:9900,EMP protocol:0301 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35427102861196 CERT:N/A FLASH CID:49 COLOR:RED Bypass loader not responding ! Elapsed: 6 secs. thankssssss __________________ |
| | #2 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2009
Member: 1015645 Status: Offline Thanks: 672
| i have got k610 show this error with setool on box plz help me v0.915039/UNI CARD SERIAL: 00038149 Loaded 51 flash descriptors SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:10100000000000 ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0052 Speed:921600 Flash ID check:897E Flash props sent ok OTP: LOCKED:1 CID:49 PAF:1 IMEI:35170901587481 CERT:RED FLASH CID:52 COLOR:RED Model (from GDFS):K610i Brand:Generic MAPP CXC article: R1CB001 prgCXC1250374_GENERIC_TH MAPP CXC version: R1CB001 Language Package: EUROPE_1 CDA article: CDA102514/2 CDA version: R2A Default article: cxc1250376 Default version: R1CB001 PROVIDER: MULTIPLE Network LOCKED RESTORATION FILE NOT PRESENT "R1CB001_CXC1250374_GENERIC_TH" YOU MUST PERFORM FULL FLASHING WHEN "ALTERNATIVE SECURITY BYPASS" ENABLED BYPASS PACKAGE PRESENT FOR DETECTED FIRMWARE SECURITY UNITS BACKUP CREATED. Elapsed: 203 secs. SIGNED MODE (USING SERVER) CFG:10000000000000 ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0052 Speed:921600 OTP: LOCKED:1 CID:49 PAF:1 IMEI:35170901587481 CERT:RED FLASH CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 Flash ID check:897E Flash props sent ok LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader startup: executed loader GDFS startup: executed loader unlock: executed USERCODE RESET TO "0000" Elapsed: 32 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:10101000000000 ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0052 Speed:921600 Flash ID check:897E Flash props sent ok OTP: LOCKED:1 CID:49 PAF:1 IMEI:35170901587481 CERT:RED FLASH CID:52 COLOR:RED Model (from GDFS):K610i Brand:Generic MAPP CXC article: R1CB001 prgCXC1250374_GENERIC_TH MAPP CXC version: R1CB001 Language Package: EUROPE_1 CDA article: CDA102514/2 CDA version: R2A Default article: cxc1250376 Default version: R1CB001 PROVIDER: MULTIPLE Network LOCKED RESTORATION FILE NOT PRESENT "R1CB001_CXC1250374_GENERIC_TH" YOU MUST PERFORM FULL FLASHING WHEN "ALTERNATIVE SECURITY BYPASS" ENABLED BYPASS PACKAGE PRESENT FOR DETECTED FIRMWARE SECURITY UNITS BACKUP CREATED. Elapsed: 28 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:10101000000000 ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0052 Speed:921600 OTP: LOCKED:1 CID:49 PAF:1 IMEI:35170901587481 CERT:RED FLASH CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 Flash ID check:897E Flash props sent ok LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader startup: executed loader GDFS startup: executed loader filesystem startup: executed loader unlock: executed DISCONNECT PHONE NOW INSERT SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN INSTALL PHONE MODEM DRIVERS IF NEEDED SEARCHING FOR PHONE, "STOP" TO ABORT PHONE FOUND AT COM14 SIM CARD NOT PRESENT IN PHONE OR PIN NOT ENTERED. Elapsed: 107 secs. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Bypass loader not responding | Eliass | SETool2 | 1 | 03-11-2010 10:07 |
| k800i Bypass loader not responding ! | john_john | SETool2 | 6 | 03-26-2009 01:48 |
| T303 cant laod id loader loader not responding | Unlocksupport | SETool2 | 0 | 01-15-2009 13:35 |
| K800i embedded flashloader not responds ! | kamransohail786 | SETool2 | 5 | 08-22-2008 08:34 |
| "Ram loader not responding to Commands" problem | thonda | Sharp | 0 | 12-05-2006 16:45 |
