Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | .: Nokia Unlock :. | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Sep 2004 Location: Romania Age: 31
Member: 81232 Status: Offline Thanks: 354
| Flash mode haw can i enter ??? HI i hawe zealot instaled in laptop win xp and when i try to connect a phone in flash mode i can't do it giwes "timeout"...] And in WIn98 it gives me error . I try with fisio 120 and philips 330 . Can someone help me to se what is the problema ??? |
| | #2 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Jun 2002 Location: Romania
Member: 13153 Status: Offline Thanks: 0
| Hi, Romanian: Pas1: Selecteaza COM-ul pe care e pusa iterfata. Verifica daca nu e cumva in share cu alt device cum ar fi interfete FTDI pentru USB2Serial. Daca se contecteaza in oricare mod TAT sau Flash, atunci nu exista probleme fizice. Pas2: Pentru flash mode trebuie tinut seama ce telefon se conecteaza. De la generatia Philips 350 in sus bootul este intern in flash, deci nu se mai uploadeaza un boot extern, este asa numitul "Jack boot". Este impropriu spus "Jack boot" deoarece chiar si modele noi care nu au conector jack au acest boot intern. Deci ca atare in Flash mode trebuie folosit cablu cu conector, in nici un caz cablu test point. Pentru acel gen de cablu, eventual cand telefonul este mort(flash nereusit sau fash gol) si nu mai booteaza cu "Jack boot", trebuie folosit Recovery mode din meniul extins. Pas3: Daca nu booteaza trebuie verificata alimentarea interfetei, in unele cazuri notebookurile nu ofera suficient amperaj pentru functionarea buna a intefetei mai ales daca se gaseste si un hub intre... Pas4: Este neaparat necesara prezenta rezistentelor pe Rx si Tx de 2k2 pana la 10k. Pentru verificare trebuie masurat voltajul sa fie peste 0. Pas5: Unele telefoane booteaza cand se apasa gentil si o singura data pe power on, daca se tine mult apasat, se ****este telefonul. Altele cum ar fi 162,9@98, Alcatel OHx trebuiesc apasata mai mult, aprox 2sec, si imediat dupa ce a inceput bootarea trebuie luat degetul. Regards................Wray |
| | #3 (permalink) |
| Hi, English: Pass1: Select the COM port where th interface resides. Verify if is not in sharing mode with other device like FTDI USB2Serial interface types. If it connects in any mode, TAT or Flash mode then you don't have a hardware problem. Pass2: For flash mode you have to take care what phone are you connecting. From Philips 350 phone generation and higher, the boot is kept inside the flash, so is not longer needed the upload of external boot, this the so called "Jack boot". Is improper caled "Jack boot" because the new models even those without a jack connector have this internal boot. So in Flash mode it must be used a connector type cable, not a testpoint cable. For that type of cable, eventually when the phone is dead(unsucceed flashing or empty flash) and is not booting anymore on "Jack boot", it must be used Recovery mode from Extende menu. Pass3: If the phone doesn't boot you have to check the power on interface, sometimes the notebooks doesn't have enough ampers for proper functioning of interface especially if you are using a HUB between... Pass4: The resistors on Rx si Tx of 2k2 till 10k are a MUST HAVE. To verify it must be measured the voltage, it must be over 0. Pas5: Some phones are booting when you gently push power on once, if you keep pressing you will power the phone on. For others like 162,9@98, Alcatel OHx the power button must be pressed longer, aprox 2sec, and immediately after the phone started to boot, you must remove your finger. Regards................Wray |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| how can i flash motorolla phone which can not enter TEST MODE? | kwasasco | P2k Series | 1 | 07-12-2008 08:50 |
| v220 dead. But can enter in flash mode | RarePearl | P2k Series | 8 | 10-04-2005 16:43 |
| How can I enter to Service Mode on C65??? | syciu | S-Gold Based Phones | 8 | 12-23-2004 22:51 |
| how can i enter dead a920 in flash mode any help | asmar | P2k Series | 2 | 10-13-2004 15:39 |
| can not enter hotline mode ! | Deltas | ARM9 BASED M62 / M62+ | 4 | 07-19-2003 06:48 |
