Unlock Server
Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (Non-Official Support) > Griffin Products
Old 07-11-2011, 09:39   #1 (permalink)
Crazy Poster
Member: 38861
mt box ....
hi all , many years ago I bought a mt box nokia , and it worked very well , now unfortunately I install the new version 2.83.3 and , for example the sw doesn't find the product file... (which is the path? before it was ..... C:\Programmi\Nokia\Phoenix\Products ) have I to put it in the trash or may be exist a file that can help me to unistall and re-install it ? thanks a lot bro
Old 07-11-2011, 11:48   #2 (permalink)
Crazy Poster
Member: 38861
ok gotcha i'll put in the trash
cheers
Old 07-20-2011, 10:50   #3 (permalink)
Crazy Poster
Member: 38861
hi all I undertand that nobody MUST answer me but I saw that 85 people read my post. is it possible that nobody can help me ???? I'd like to know how to unistall and reinstall correctly with the last upgrade my Nokia MT box
example "you need these files and beware this procedure...."
I installed last nok mt version but the box doesn't reach the products files and I don't know the path file . thanx in advance
Old 07-20-2011, 11:01   #4 (permalink)
:Aishur:'s Avatar
Member: 1315677
Open the griffin.ini and correct the yellow line with the correct address
products_folder=C:\Program Files\Nokia\Phoenix\Products\
flashldr_folder=C:\[Boxes]\GriffinTeam\MT-Box\FlashLoaders\Flash\
flash3ldr_folder=C:\[Boxes]\GriffinTeam\MT-Box\FlashLoaders\Flash3\
flashusb_folder=C:\[Boxes]\GriffinTeam\MT-Box\FlashLoaders\FlashUSB\
The Following User Says Thank You to :Aishur: For This Useful Post:
Old 07-20-2011, 11:24   #5 (permalink)
Crazy Poster
Member: 38861
thank you a lot , your suggestion doesn't change my problem , can you tell me which is the best way to unistall and reinstall correctly the box
thanx again
Old 07-20-2011, 11:40   #6 (permalink)
:Aishur:'s Avatar
Member: 1315677
no need to uninstall, check only if the paths are correct in the griffin.ini,
if some models are missing, upgrade the phoenix.ini from Griffin Team Support Forums - Powered by vBulletin
That is all
I can suggest to test
create the folder C:\Program Files\Nokia\phoenix\products
drop in the above folder any old product
test if mt-box can see it
Old 07-21-2011, 09:05   #7 (permalink)
Crazy Poster
Member: 38861
i checked the paths and everything is ok, so the only thing is to unistall and reinstall it, so the best way is to unistall all the version that are on my pc or .... i don't know which is the best procedure to reinstall with the new version
thanx
Old 07-27-2011, 17:50   #8 (permalink)
SenUnlock's Avatar
Member: 1415435
Sonork: 1595155
add this line :
products_folder=C:\Program Files\Common Files\Nokia\DataPackage\Products
exactly under the line :
that is what i did to solve the problem.
FLASH BOX WANTED!!!!!! J Wanted Products 9 07-14-2012 20:42
i WANT TO BUY NOKIA BOX !!! Eric Wanted Products 8 02-14-2011 12:23
NOKEY BOX FOR SALE - FULL Zorz Main Sales Section 0 12-05-2000 09:56
New NOKIA BOX - New Prices gsmEsteve Main Sales Section 0 12-03-2000 02:43
New Nokia BOX for you!!! gsmEsteve Main Sales Section 0 11-18-2000 16:09
Page generated in 0.32110 seconds with 11 queries
