Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Alcatel O.T.U.F
Old 03-21-2008, 00:40   #1 (permalink)
Member: 6142
Sonork: i dont use it
Thanks Meter: 47
C651 language change problem
I had a dead c651 , i made full repair and phone will be good! After it i try to change language( because repair flash doesnt contain hungarian lang),but after writing lang ( langpack is same version as phone soft) phone is power on but there isnt any number and character. If i write back original lang,phone is working good again! Maybe lang pack is not good or lang change producere is not perfect.
How can i solve this problem? Im waiting for help!
Regards Roniri
Old 03-22-2008, 09:58   #2 (permalink)
Member: 527885
Thanks Meter: 59
Regards Roniri
Have you tryed different repair flash file ?
Regards,
Old 03-23-2008, 15:22   #3 (permalink)
stepw's Avatar
Member: 39097
Try resetting to factory defaults after changing language
Old 03-25-2008, 09:36   #4 (permalink)
Member: 6142
Thanks Meter: 47
I try to use full repair flash and clone flash too and after writing full repair flash or clone flash phone worked perfectly,but if i try to change lang to hungarian than phone had a problem. I used two different langfiles,because version of clone flash and repairflash is not same ,so i think there is problem with language changing. I made full factory reset too,but it didnt help too.
Maybe i read full flash from good working phone (with needed language) and send you to make full repair flash from it.
Regards Roniri
D830 display disturb Problem when language change irfanamin2 UST Pro II 5 05-10-2008 15:27
language change 6300 problem coolmax UFS2 + UFS3-Tornadoflasher 3 01-19-2008 14:36
S700i Language Changing Problems PTR999 Sony Ericsson 0 12-03-2005 20:38
CX70 Change language pack problem!!!! drdjolens S-Gold Based Phones 1 10-23-2005 11:32
BE4 135 language changing problem psych0 Alcatel & TCL Old Models 2 05-14-2003 08:14
Page generated in 0.16805 seconds with 9 queries
